Question about Kenmore Ovens
When you try to use the oven the breaker trips.
  • 2,382 Answers
Hi, this sounds like a main control problem. More specifically like one of the relays is shorted. You will need to acess the main control and carefully inspect it for any burn marks. If you don't see any disconnect the main power supply wire going to the main control. Then plug it back in if it trips the breaker the problem is in the power cord or wiring from the cord junction to the main control. If it does not trip the breaker the problem is the main control.
Posted on Aug 25, 2010
Have a chef fan forced wall oven model number EOC624W - everything working except there is no heat
Check the house circuit breaker for the oven. If 240 isn't present, everything else will work except the heating element. The circuit breaker will have it's handles joined so if one trips they both trip. Unfortunately, this doesn't always work, Meaning one can trip without tripping the other so only 120 volts is supplied to the oven.
Dec 13, 2016 | Ovens
Flavel milano e50. Why does everything except the oven work?
Check the circuit breaker for the oven. 220 volts are necessary for the heating element. 110 volts for the light and clock controls. The 220 volt breaker looks like two side by side breakers with their trip levers joined. Sometimes one will trip without tripping the other. Try resetting the breaker or better yet replace it.
Feb 02, 2016 | Ovens
Main oven wont come on or the light but the fan does
Hi, I hope I can help you. If you're referring to the overhead fan above the oven, that fac is usually on a separate circuit. The oven itself is connected to a separate circuit breaker, hence, that is why the oven and light won't come on.
Check your circuit breaker box, and see what circuit has tripped. Check to see if there are any burn marks around the breaker before resetting it.
The reason the breakers may trip, is the breaker is old, may have the incorrect rating, or may be linked to other circuits, such that when too many items are all drawing power at once, it will trip the breaker.
Hi,my belling model 664 wh is tripping out just as it reaches set temp on main oven dial,i have just replaced the main oven element, any solutions I would be grateful. Thank you.
Sounds like the amperage draw of the oven is right at the breaker size. Circuit Breakers should not be loaded more than 80%. Breakers take time to trip when they are close to the limit. IF the problem started with the replacement oven element, it may be the wrong one and could be tripping the breaker by drawing too much power.
Otherwise: Wiring or breaker not sized right, maybe another load on the breaker in addition to the oven, possible bad connections causing extra amperage, or wrong the oven element made for a higher amperage oven. In rare cases the breaker might be bad, but this is not likely.
Someone experienced needs to a) identify the breaker size b) verify the wire connected is appropriated sized c) verify the oven's current requirements and d) look for bad connections.
Normally another load would not be on the oven circuit unless a diy person changed the wiring. With those items verified, a clamp on amp meter would be used to verify actual current draw when the oven is on to ensure the load is appropriate for the breaker, wiring and oven. If at this point the load is less than 80% and the breaker still trips, change the breaker.
May 25, 2014 | Ovens
The power comes on the clock works but the cooktop nor the oven will heat
It is very likely that one side of your power to the stove has tripped at the breaker. Shut off both breakers together and snap them both on. This should reset the breakers and your stove will be working. If the breakers trip often Have the breakers themselves checked. They can be tripping at a lower curent load than rated.
Mar 10, 2014 | Ovens
Tried removing element from bottom oven, with the bottom oven selector on to provide some light. As I pulled the element out one of the terminals touched the casing and caused the light to go out, the...
More than likely you have tripped the house circuit breaker or fuse. If you know where the house fuse box or circuit breaker panel is check to see if either one side of the two 240 fuses is blown or one of the two tied together circuit breakers is tripped. If it is a breaker then shut off both breakers completely and then snap them both on completely or they won't reset. It is rare that an oven has a fuse internally. There can be thermal fuses but they will trip when the temperature is out of range.
Feb 25, 2014 | AEG U7101-4 Electric Double Oven
Broil trips circuit breaker every time
I would start by replacing the breaker. They do become weak over time.
Dec 05, 2012 | GE JRP28 Electric Double Oven
Oven heats up but wont get above 160 degrees
I assume you mean it trips the circuit breaker. If the circuit breaker is good, that means the heating coil is bad, and pulling too much electrical current. Sometimes circuit breakers fail, and trip at say 5 amps when rated at 15 amps. Have you electrician switch that breaker with another one and see if there is a difference. If not, it is a bad heating coil.
Oct 19, 2012 | Bosch HBN5046AUC Electric Single Oven
Double oven keeps tripping circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Oct 24, 2009 | Jenn-Air JJW9830D Electric Double Oven
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
