Question about Sony Cyber-shot DSC-T90 Digital Camera
My DSC-T90 Sony Cyber-shot won't turn on and the battery is fully charged.
  • 188 Answers
SOURCE: Sony Cyber-shot DSC-U10 low battery indication.
possible short circuit that is draining battery at a speed. get your camera tested at some good repair shop,
Posted on Jul 02, 2006
SOURCE: Sony Cyber-Shot DSC-F707 ...No flash.
Mine started to do that too. I charged the battery and then played with it taking the battery out and placing it back in and it just started to work again. Try placing it in manual mode as in shutter or appeture, rather that automatic and see if it makes a difference. These are things i played with before it started to work again.
Posted on Apr 16, 2008
  • 10 Answers
SOURCE: Change language display on Sony Cyber-shot DSC-W220
try under the settings menu
Posted on Jul 19, 2009
virtualhost
  • 2185 Answers
SOURCE: NEED DOWNLOAD FOR SONY CYBER-SHOT DSC-W80, I LOST
Would you like to open your pictures from your Sony Cybershot to your computer? Your cybershot cam is usually plug and play so you dont need a software for that. All you do is to plug in your camera to your computer's usb port using the usb cable. When the computer detected the new usb device, open a Windows Explorer. Right click your windows Start button, and choose Explore. From the list of Drives from the left, you need to find the Drive letter associated with your camera. Just click on that and it will show you the files on the right. The pictures are located somewhere inside those folders. You just need to click and drag them to your computer's local drive.
Should you have any questions, please let me know. Good luck!
Posted on Nov 13, 2009
  • 11967 Answers
SOURCE: Cyber-Shot DSC-W120 won't turn on.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 16, 2010
How much is Sony Cyber-shot DSC-T90 12 MP?
Please log on to the following sites to get information
www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&???storeId=
www.amazon.com/???Sony-DSC-TX7-Digital-Stabilization-Blue/dp/???B00328HR80
Sep 17, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
How can i find dsc-t90 skd 694953 serial number
The serial number on the Sony DSC-T90 is located on a label attached to the bottom plate of the camera.
Hope that helps,
BAX
Mar 21, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
Red light appears at bottom right corner when turned on
The DSC-T90 contains a focusing light that turns on when the shutter is depressed half way down. This allows the camera to focus in near darkness.
Mar 10, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
Sony cyber-shot T90 is making noise and vibrating
The only motorized part I am aware of is the lens focusing mechanism. If it's making a noise loud enough to be heard and vibrating, it is most likely defective. I suggest sending it back to Sony for service if it is still under warranty.
Mar 02, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
I wish to Aquire an Instruction Manual for
sony has all their manuals online. You can download a free copy at the website. Your particular model is located ON THIS PAGE.
It's a pdf type file and you can download a free adobe acrobat reader from the sony support site as well.
Jan 02, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
Need help with sony cyber-shot dsc-h2
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.
Hope its helpful to you
Oct 18, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot DSC-T90 Digital Camera Logo
75 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
