I have a Whirlpool Quiet Miser desinger window unit. The unit works fantastic except it doesn't ever cut off by itself while on "energy saver" mode. It just constantly runs. Is there a part I should look for to replace ?
2 Suggested Answers
  • 587 Answers
SOURCE: freezes over
If the coil is freezing up it's either a dirty filter, coil or low on refrigerant. Unless somebody went in and changed the fan speed to a lower speed.
Posted on Apr 20, 2009
I have a Whirlpool Gold Quiet Series Plus, Model GU940SCGT3, not working. It ran a cycle, cleaned the dishes, but the water didn't drain and the "CLEAN" light is stuck on. It is now...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gold quiet 3 dishwasher flashing clean light nothing works i had to push 2 button and cant remember code to reset unit
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or high temp wash-heated dry-high temp wash-heated dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 28, 2011 | Whirlpool Dishwashers
My airconditioner has been on energy saver for almost 2 days and will not come on what should be do
If this is a window or wall unit. Turn the Master ON/OFF Switch to OFF. Unplug the unit and wait 12-15 minutes. Then, plug the unit back in and turn the Master ON/OFF Switch to ON. Set the controls on anything except energy saver. If the unit then operates as it should, let it run for at least an hour before switching it to Energy Saver Mode. If that's the way you want to operate it. If it doesn't restart and run like it should or it shuts OFF on Energy Saver Mode, there is a problem with one of the setting sensors and needs to be replaced.
Also, while you have the unit unplugged, check the outlet to make sure it's still active. You can do this by plugging in a lamp. If the lamp doesn't work, the circuit breaker for that outlet has been tripped in your home's circuit breaker panel and needs to be reset. When you plug the AC unit back in and it trips the breaker again, there is an electrical short or overload in the AC Unit.
Please keep in mind everything I suggested is based on your AC being a 120 volt window or wall unit.
Hope this helps you solve the problem.
Apr 13, 2011 | GE Heating & Cooling
What happens if we press the novo option in lenovo laptop
It is usually a short cut for Energy Cut.
You can press to shift between the power schemes namely High performance, Balanced, Power saver.
Quiet mode option is not there.
Let me know, if need further clarification.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 06, 2009 | Lenovo IdeaPad Y510 Notebook
Freezes over
Apr 20, 2009 | Heating & Cooling
Which setting on an Energy Miser saves energy?
OFF is the Energy Saver mode.
To reduce moisture, there is a heater around the door seal that stays turned on, using energy. If you switch to ON, you use more energy.
It is confusing though.
Jan 17, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
ENERGY SAver is stuck on
I know it's an older post, but you still may be waiting an answer:
What is probably happening is Your power board is failing to maintain power enough to run the bulbs and the rest.
That is why it takes long to start up and why it goes into sleep mode.
Does the power button stay lit (getting signal) or turn to amber (sleep mode) or does it flash.
powerseller
bammbammfran
Sep 04, 2008 | Proview PL926WBi 19" LCD Monitor
Heating & Cooling Logo
443 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
