Question about Janome 4623 Mechanical Sewing Machine
What type of bobbins does the Janome 4623LE use? The manual does not indicate, just that bobbins were included.
Does the janome 5 have a low bobbin indicator, if so, where is it? Thank you
If it does, it would be in the owner's manual. (I'm unable to locate information on "Janome 5," so there must be more information to the model.)
https://www.moores-sew.com/tip-how-to-know-when-your-bobbin-is-low-when-you-dont-have-a-low-bobbin-indicator
Jul 17, 2018 | Janome Sewing Machines
I am a beginner sewer, l have a 7318 machine i am having problems pulling up bobbin thread please help i can't use machine till i learn
when you put he bobbin in the holder make sure that the thread is coming out the right way , slide it down the slot and under the spring and leave about a foot of thread out
for beginners it is advisable to join a local sewing club as practical experience is a fast way to learn
Jan 26, 2018 | Sewing Machines
My janome sew mini sewing machine is very slow can I fix it
First clean it thoroughly bobbin case included then oil it according the owners manual, i hope it be ok because the thread got caught in bobbin case and lint that causes it slow down.
Sep 25, 2014 | Janome Sewing Machines
My janome 625e came with one metal. Do I need to use metal or can I use plastic
Are you talking about feet or bobbins? Did you buy the machine new? Do you have a manual?
In my experience of this type of machine, the bobbins were plastic
Oct 18, 2013 | Janome Sewist 625e
What type of bobbin should I use in my Memorycraft 4000.. Plastic or metal..I have been using metal, is this ok?
You should be using plastic bobbins for the MC4000, see: http://content.janome.com/index.cfm/Machines/Accessories/All/Bobbin_-_Plastic . Usually the machine comes with a handful of the correct size and type bobbins. Using the wrong bobbin could result in the needle hitting the bobbin and damage may occur. (Broken needles are the most likely possibility; damage to the bobbin case or timing could occur and would require the machine be serviced.)
When you buy more bobbins, make sure that they are labeled for Janome or a machine that takes the same size bobbin. See this site for a list of machines that also take this size bobbin: http://www.sewingmachinesplus.com/102261103%20-20pk.php
I hope this helps.
Mar 01, 2011 | Janome Memory Craft 4000 Sewing Machine
What type of bobbin does the machine use. I checked the book but cant seem to find a number. Janome memory craft 9000
they are called janome bobbins, but need to be flat ( there are some out there with a curve). the best place is to try an janome store as i have had a few that will not fit
Jan 31, 2010 | Janome Memory Craft 9000 Computerized...
How to thread bobbin in a Janome 415?
Here is a link to the manual that shows how to thread the bobbin. :)
http://www.janome.com/documents/File/ManualFile/415_Instr_book.pdf
Mar 31, 2009 | Janome Sewing Machines
Owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
Jan 25, 2009 | Janome Mini Compact
The LED light won't show up
Check your bobbin winder spindle. It may be engaged. (pushed to the right). Push it to the left, if it's pushed to the right and the LED will go on.
Jan 01, 2009 | Janome 4623 Mechanical Sewing Machine
Janome 4623 Mechanical Sewing Machine Logo
54 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
