Question about Intel DG31PR Motherboard
Intel desktop board DG31PR sound card installation problem. sound card does not show on device manager. bios setup sound setting ok. i can not solved this problem. please give me the perfect solution. i am waiting for reply
Http://www.intel.com/support/motherboards/desktop/sb/CS-020642.htm
Intel has a program to run to help fix this.
Posted on Nov 23, 2011
I have intel desktop board D865GSA. From few days ago , my on-board realtek sound is not working and also not showing in device manager and task bar even after the proper installed updated driver for...
check in BIOS , is Realtek Audio ENABLED or not, if not then enable it, all would work fine. if this not solves then try uninstalling the driver of the device and after restart try installing the one with which it was working fine. also try checking with other audio output devices.
Sep 06, 2013 | Intel D865GSA (BOXD865GSAL) Motherboard
Usb device not recognize
Hello visit intel here:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+3+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG31PR
And install the missing mainboard drivers.
Try also to enter the bios function, and look for the usb function is maybe set to off.
Remember to save your work when leaving bios.
Run also windows update.
Good luck
Aug 05, 2013 | Intel DG31PR Motherboard
Install iso cpu bios
Hello here is the download page:
Here is a youtube video how to change the boot order:
http://www.youtube.com/watch?v=yrk0t8IuY88
In the BIOS Setup program, the user can choose to boot from a hard drive, optical drive, removable drive, or the network.
The default setting is for the optical drive to be the first boot device, the hard drive second, removable drive third, and the network fourth.
Remember to save your settings, when leaving the bios.
If the boot order change when you power off, the cmos battery must be renewed:
The battery is a watch type Cr 2032, and cost a few dollars.
Remember to place the new battery, as shown on the picture.
Good luck
Jun 25, 2013 | Intel DG31PR Motherboard
AUDIO SHOWS NO ACTIVE CONTROL DEVICE FOUND
down load audio driver from realtek web site - realtek 97 audio
Dec 04, 2009 | Intel DG31PR Motherboard
Sound card is not showing on device manager
ftp://ftp.us.dell.com/audio/R58182.EXE
Thats the link to your audio driver. Try installing that and see if it fixes your issue. If it doesn't, then the sound card on your motherboard may be defective, or the sound is turned off in the BIOS.
Aug 05, 2009 | Dell OptiPlex GX270 PC Desktop
Intel dg31pr board says have no audio device
I spent months trying to figure this one out on my own PC. I finally have the solution. Go to device manager (right click my computer, go to properties, Then hardware, then device manager. Click on the"+"  in front of system devices. Find "microsoft uaa bus driver for high defintion audio". Right click that and select, "disable". Then right click it again and "unintstall" the device. This will allow you to install the audio drivers on your disc, or ones you have downloaded to install without an error message. Once done install your audio drivers and restart your PC and windows should start dectecting your new hardware. An installation wizzard pops up. Install the files needed yourself from a specific location, not a disk. It will ask for location of file name "hdaudbus.sys". That file is in C:/Windows/System32 folder. If it's not there, which it should be, just find and download that one file but it should already be there. I have done all this on xp home ed, sp3. I now have sound, and my front audio panel works. Please let me know if you have any problems by emailing me at chadmon10@hotmail.com
Jan 21, 2009 | Intel DG31PR Motherboard
Did you get an error message during install of the (system with the SATA 160GB drive)? Make sure the 160GB drive is shown in the bios. Than go to the title, Boot in the bios & make sure the SATA 160GB is listed in the boot order. (Preferred 3rd. boot device)
Please go to the SATA drive's manufactures site & download either their bootable floppy or CD setup software. (It’s free)! Use their software to setup the FAT & cluster size on the drive. You can even set other features that neither the bios or windows can do. Format the 160GB drive with the software as well. The manufacture's software does a better job than windows. If the 160GB drive is a SATA 2.0 leave the jumper on the drive alone. The Desktop Board supports four Serial ATA channels (3.0 GB/s) via ICH7, connecting one device per channel.
Again, please run the manufactures setup software for your SATA 160GB drive. (Disconnect any other drives that may be in the system until windows is installed).
Intel's web site here: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839&lang=eng
Good luck ameyaniks!
If I missed something, just let me know.
Mike
Sep 11, 2008 | Intel DG31PR Motherboard
Audio device not working in INTEL DG31PR board
2)Right Click My computer
3)Click properties
4)Select Hardware Tab
5)Click Device Manager
6)Click on the cross of System Devices
7)Right Click Microsoft UAA Bus driver for high definition Audio
8)Uninstall this (this is the problem making place and this might indicated as yellow color explanation mark before you uninstall it)Just uninstall it
9)Now install your newly downloaded drivers which i have asked you to download in the previous post.
10)System will ask to restart momentarily just follow the instructions and reassert .
Once all the installation and restarting are done your Audio will work with out any issues
Hope this will work and please let me know if my post able to fix ur problem.
Jul 28, 2008 | Intel DG31PR Motherboard
Audio Driver issues
Right click my computer icon, click properties, select hardware then click device manager, check the audio device you can see the yellow question mark,insert mother cd driver then right click the yellow question mark and update the driver. otherwise change the audio driver..
Jul 02, 2008 | Intel DG31PR Motherboard
Audio device is not working
I have been working on this for months and finally got everything including front audio panel going. First Download the latest realtek audio drivers available  from intel's website or go here and download #3 http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=Windows%2A+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21. Next goto control panel and add/remove programs then look for realtek audio drivers that have been previously installed. Remove program if one is found. Then go to device manager (right click my computer, go to properties, Then hardware, then device manager. Click on the"+" in front of system devices. Find "microsoft uaa bus driver for high defintion audio". Right click that and select, "disable". Then right click it again and "unintstall" the device. This will allow you to install the audio drivers on your disc, or ones you have downloaded to install without an error message. Once done install your audio drivers and restart your PC and windows should start dectecting your new hardware. An installation wizzard pops up. Install the files needed yourself from a specific location, not a disk. It will ask for location of file name "hdaudbus.sys". That file is in C:/Windows/System32 folder. If it's not there, which it should be, just find and download that one file but it should already be there. I have done all this on xp home ed, sp3. I now have sound, and my front audio panel works. Please let me know if you have any problems by emailing me at chadmon10@hotmail.com
Jun 22, 2008 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
126 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
