Question about Husqvarna Chain Saw 20" Bar
I have a Husqvarna model 444 chain saw. The fuel pick up line disolved in the fuel tank. How do I replace?
Order new fuel line and filter from www.randysenginerepair.biz
remove top cover, remove air filter, remove fuel line from carburetor, empty gas tank, pull remains of fuel line out of tank and replace with new.
Posted on Nov 06, 2010
Where to find vent line on 359 husqvarna
Husqvarna chainsaw fuel line check and replace - YouTube
? 3:44
https://www.youtube.com/watch?v=8FyU_fG9qwc
Feb 6, 2012 - Uploaded by mweba1
359. ... Husqvarna chainsaw fuel line check and replace. mweba1. SubscribeSubscribed .... You will want to inspect the tank vent and fuel line.
Husqvarna common air leak - YouTube
? 1:51
https://www.youtube.com/watch?v=Z7f9zNQTJBQ
Apr 11, 2012 - Uploaded by mweba1
Husqvarna common air leak ... Husqvarna 136 ChainsawCarburetor Rebuild & Fuel Line Repair - Duration: 22:39. by donyboy73 59,377 views.
Husqvarna 359 Professional Chain Saw Review
Dec 14, 2015 | Husqvarna Garden
How do you replace a fuel filter for 235e husqvarna chain saw
They are kinda hard to get them out but it is in the fuel tank on the fuel line just get it out the gas tank filler hole then pull off and replace with new one..
Jul 15, 2014 | Husqvarna 235e 16-inch 34.4cc 2-stroke...
How to replace pickup fuel line in craftsman chain saw?
The lines fit tight to prevent leaking. You must disconnect the fuel filter and pull the line out. Cut the new line end "v" shaped to allow you to push back into tank. Long needle nose pliers will complete the job.
May 01, 2014 | Husqvarna Chain Saw 20" Bar
The fuel pick up line came off in my tank\
Hi brian
You will need to drain all the fuel from the tank.
Then if you have a long nose pliers or a hemostat remove the fuel filter.
You will need to trim the fuel line to a point and insert it into the fuel tank and keep inserting till the fuel line can be retreived and install the new filter on the line, slowly pull the fuel filter back into the fuel tank,leaving some slack in the line to not kink the line.
Please take time to rate me
Bud
Apr 09, 2013 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Will not stay running
Check the fuel line from the tank to carburetor. Ethanol fuel has caused many problems with fuel lines cracking, causing poor fuel pick-up issues. I'd start with replacing the fuel line and filter first. If you know the year of it (check serial number) go to partstree.com and it will give you a parts breakdown and ordering capabilities for this saw.
Sep 16, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My model 50 saw will work for about one minute then stops as though the fuel was turned off . if iwait for 5minutes it will start again any ideas would help me
Start by removing the hose from the tank and replace the filter on the end, check the fuel hose up to the carb for signs of cracking, or fuel escape, if so replace the hose, if no better, try slackening the fuel filer cap when the saw sarts to die, if it picks up again you need to replace the fuel tank breather.
Mar 20, 2011 | Husqvarna Chain Saw Handle Models 50 51...
Describe your Husqvarna "Chain Saw -
Remove the spark plug and test for spark. If ok, try some starting fluid in the plug hole, install the plug, and try to start. If it runs a short time, it is not getting fuel. Check fuel lines including inside the tank. Clean or replace the air filter. If this saw is fairly old, the carburetor probably needs a re-kit and cleaning. Does it have good compression? Check the muffler for plugging. Make sure the fuel/oil mix is fresh. Good luck!
Sep 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 65 fuel line
This is Husqvarna.com manuals. You wlll need to find the IPL that applies to you. The exploded diagrams should help you trace the fue lines.
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Lou
Aug 06, 2009 | Garden
Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Feb 13, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
Nov 30, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
405 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
