Question about RCA HD52W59 HDTV Projection Television
Picture is wavey and tri colored. - RCA HD52W59 HDTV Projection Television
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
The convergence board is not working , this is a ease fix , u take the back cover off and you would see a black big pice thats the flyback transformer , pull the board out flip over do the solder connection on the flyback and than repace the fuse location# fl231 , this fuse is not a regular fuse it look like a little squer brow box next to the flyback just look for the location #
Posted on Aug 25, 2010
Why is my color distorted on my 60737 hd tv???????
Try resetting the tv By pressing the power button on the set for 8 seconds if that doesn't work try unplugging your video source (cable box, sat box, ect) for 20 sec then plug in. if all those don't work then service is needed. the formatter board needs replacement.
Feb 21, 2015 | Mitsubishi WD-60737 60 in. HDTV
Magnavox ms 3252s431 Bad picture and turns off by itself
Hello, Change horizontal driver buffer transistor's and capacitor's. 7461 7463 transistor's. Caps 2455 2405 near transistor's. Please leave your email address, I will try to find the service manual for you. Best regards, Arpi
Jul 26, 2007 | Philips Magnavox MS3252S 32" TV
The picture is wavey and color is blurry
Convergence problem....$300-$500 repair. This TV is a great unit,
Jun 01, 2011 | Toshiba TW65X81 65" Rear Projection...
I have a Mitsubishi WS-65869 65 in. Rear Projection Television and it has created a wavey line and has distorted the image. i have a picture of it i can send. Any help. i can send pictures of screen.
If you see separation of colors (red, green) in this wavey line most likely you have problem with convergence circuit. Two convergence amps have to be replaced. They located in a middle of the TV boards attached to big aluminum radiator and they part number starts with letters "STK".
I would recommend to let professional with this repair. Should cost you about $250-$300.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Wavey line at bottom of tv
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments any where,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it reistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Philips 60PP9363 60" Rear Projection...
Wavey color lines at bottom of picture. Crackling noises coming from back bad picture
Howdy;
The "crackling noises" from the back is causing the picture to distort. 1) Either locate source of "noise" and correct or 2) Call a Service Company and get corrected. I would recommend that you DO NOT USE TV until this corrected. It may cause a fire inside your TV.
Good Luck, Big Irish.
Nov 22, 2009 | Televison & Video
Wavey lines in the picture
Ok I have had this same problem before sadly unless you now how to configure everything you will need to call a close repair man for it they come re-aline the colors But note: this is not free! i'm Sorry But this is the best i can do hope it helps
Nov 26, 2008 | LG 42LC2D 42 in. LCD HDTV
Wavey lines
Sounds like your set has dried caps in the Power Supply, take it to a decent tech, its not something you should try to do yourself as dangerous voltages can still be present evn if the set is unplugged.
Jul 25, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Tv screen
u must have schematic diagram for that and check all the vcc of jungle ic.
Apr 09, 2007 | JVC AV-32F802 32" TV
RCA HD52W59 HDTV Projection Television Logo
18 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
