Question about Lutron Electronic Low-Voltage Multi-Location Dimmer by Electronics, Inc
Dimmer switch seems to be broken as of yesterday. cant get light to turn on, by using dimmer or push switch. want to pull plate to compare. Little on/off switch at bottom won't initiate light
  • Al Kupchella
    Al Kupchella Aug 25, 2010
    I can't tell what you want to know. Are you asking how to remove the plate or what?
  • rcrozier599 Aug 25, 2010
    yes at least I could see what if anything I could fix
  • 843 Answers
I haven't used this one and I couldn't see anything specific on the Lutron site about how these plates attach, but if there are no visible screws they have to just snap on and snap off. I can't believe they would have any luck selling a product that required special tools to remove the wall plate good luck, Al K
Posted on Aug 26, 2010
Brake & turn signal lights
QUICK PRELIMINARY CHECK:
  • If neither brake light works, go here.
  • Check all the connections to the signal switch and trailer relay.
  • Turn on the parking lights. Make sure that each light is equally bright (side-to-side). The signal filament is brighter than the parking light filament, so if one light is "extra" bright the bulb may be inserted 180 degrees out in the socket, or the contact plate in the light may be reversed.
    To reverse the contact plate for the front parking light with staggered pin bulbs:
    Remove the lense and the bulb
    Pull back the boot as far as possible. Some boots require that you remove the parking light completely.
    Push the wires into the back of the light housing.
    Turn the contact plate 180 degrees and engage the tangs as you pull the wires out.
    To reverse the contact plate for the rear round parking lights with staggered pin bulbs (You can simply reverse the leads on the rear rectangular lights):
  • If you don't have brake and signal lights on one side, disconnect the red and yellow (or green) wires from the light. With the parking light switch on, touch the red wire to each connection on the light. One connection should be bright, the other less bright. Connect the red wire to the dimmer connection and the other wire to the brighter connection. More possibilities here.
  • Use only a Signal Stat brand flasher, #180 (it comes with the kit). Some others don't consistently indicate flashing on the dashboard, or may not flash at all.
Sep 14, 2013 | Harley Davidson FLHTCUI Electra Glide...
Using 3 way dimmer, lights don't appear to go to full light
Hi Gene,
When two 3-way switches are used to control a light - and you wish to install a dimmer, you replace only ONE of the switches. If you replace both switches with dimmers, and one dimmer is set to 50%, the light will only be able to get to 50% bright; regardless even if the other switch is set to 100%. The light can only get as bright as the current lowest dimmer position of either switch.
Most modern dimmers are solid state, and should be able to get full power to the lamps. Older dimmers aren't very efficient and work a little differently - but should still do a good job as far as brightness of the lamp. You can run into trouble trying to dim CFL (compact fluorescent lamps) if they are not labeled specifically for use with a dimmer. Even those that are labeled for use with a dimmer have a noticeably short range of dimming when compared to standard tungsten lamps, and tend to have an audible buzzing sound.
If this doesn't answer your question, please provide the wattage, type and number of lamps in the fixture. Your dimmer is rated for up to 600 watts, but may be less if it is in a switchbox with other dimmers or you have broken off portions of the heat shield as directed by the instructions.
Mar 17, 2012 | Lutron AY603P Ariadni 600W 3way Dimmer...
Hi, my 1988 c4 corvette dashboard lights seem to turn off as soon as i turn my headlights on, my dim switch doesnt seem to be doing anything. what could be the problem and the solution? can someone please...
The fuse block is located under the right side of the dash. Check the fuse called "INST LPS" fuse # 15, it's the one located in the 5th row across and 3rd one down. If the fuse is good, with the ignition in the on position check for 12 volts at the dimmer switch assembly this is a dark green wire. If you have 12 volts replace the dimmer switch assembly, if not repair the dark green wire. Hope this is helpful to you.
Sep 04, 2011 | 1988 Chevrolet Corvette
I cant seem to figure out how to turn the dome light on it comes on when you key off or open door but cant figure out how to turn it on manually while driving all i can use is the map lights and that dont...
Find your dash light dimmer switch....... usually some kind of a roller/dial type of control.
This can turn your dash lights off and make them nice and bright, well at the end of the "bright" side if you just keep turning it will turn on your interior light.
Jan 16, 2011 | 2006 Chevrolet Monte Carlo
Help - The dome light in my 1998 Cavalier wont turn off. We have checked all the door switches, turned the dimmer switch for the dashboard with no effect and basically pushed every other button, switch we...
there is a plunger switch on each door and one on the dimmer you can disconnect each switch one by one until you find the problem. I would check the condition of each switch first making sure none are stuck, broken or bent
Dec 29, 2010 | 1998 Chevrolet Cavalier
I recently installed a aspire rf9534ds dimmer and a 9542ab accessory dimmer in my home. Everything works, but on the accessory dimmer the amber light stays lit all of the time. On the master switch the...
I was reading one of the Lutron Maestro accessory dimmer manuals yesterday, and it showed how that little light was also a fuse that you could remove to turn off power. I didn't read exactly why it has that fuse.
You might check your manual to see if that is the same feature on your accessory dimmer.
Oct 23, 2010 | Cooper Wiring Devices Aspire Smart Dimmer...
Trying to uninstall a light switch. The two black wires are covered by a gold color metal plate where the screws go in and the wires will not pull out of switch. Can't seem to remove the metal plates. ????
Of course you have the power turned off, right? Assuming you don't plan to re-use the old switch, just cut the wires. Your wires are probably plenty long enough if your cut them as close to the switch as possible. Then you can strip then new ends of the wires. It's easiest to strip the wires using a stripping tool, but it's not necessary to go buy one, as you can do this easily enough with a knife. Good luck, and thanks for using FixYa. Al Kupchella
Apr 21, 2010 | Cooper Wiring Devices ACE6001V-K "ACE"...
How to dissable a pre-existing dimmer switch
You don't want to disassemble the dimmer ... you want to remove the dimmer and replace it with a toggle switch
Get a switch at the hardware store or at the big box place. You only need a standard wall toggle switch - color to suit your taste ... gray, ivory, white, brown or red usually. Expect to pay less than $3.00 and maybe as little as 75 cents.
It is simple ...
turn off the power to the light at your circuit panel.
Remove the knob (pull it off) - remove two little screws that hold the cover plate on. There may be a nut under the knob ... remove it (leftie - loosie -- righty - tighty)
Remove the two screws that hold the dimmer in the box,
Pull the dimmer out.
loosen the screws that hold the wires onto the dimmer ... you may have wire nuts holding the wires together. if so, remove them
set the dimmer aside.
you should be working with two black wires in the wall. What ever is attached to the dimmer is the wires you will be using. It does not make any difference which colored wire goes on which brass screw - more below - except the green ... the green goes only on the ground screw.
put one wire from the wall on one brass screw
put the other wire from the wall on the other brass screw.
put the bare wire (or green wire) on the green screw on the switch frame.
arrange the wires behind the switch and screw two screws into the wall box ... make sure the switch is straight.
put the cover on -- two screws ...
turn on the power.
If you have more question, attach to this post.
Thanks for using fixya.com
a
Oct 26, 2009 | Electrical Supplies
Overhead lights
check you dimmer switch. the dimmer switch is what controlles the interior dash lights and dome lights. you might have acidently hit the switch and it may have pushed it up from the position it was at. if you push the switch all they up than you interior light will come one even if you shut the car off and pull the key. turn the dimmer switch all the way down and see if it still does it. if not than wait until it gets dark and go outside and turn the swich up until ou can see the dash lights. but remember if you turn it up to far the interior lights will come on.
Aug 01, 2008 | 2004 Pontiac Montana
Lutron Electronic Low-Voltage Multi-Location Dimmer by  Electronics, Inc Logo
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
Craig Butler
Craig Butler
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
