Question about Toshiba e-Studio 282 Printer
Won't power up. Looks like the hard drive crashed.
  • 1,110 Answers
It won't power up? Or is it just that it will not finish "booting" up? If your display screen lights up and you get the initial screen but that is all then this indicates as you suggested a hard disk failure. You will need to call your Toshiba service center as the hard disk on these machine also contains the operating system for the machine so it will have to be loaded onto the new drive. This is why on Toshiba's that when the hard disk fails the machine just "hangs up" on the warm up sequence.
Posted on Aug 25, 2010
Dban problem ( crash : "dev/sda" )
Use fdisk and / or format from command prompt. Easy and no fuss. gl
Nov 03, 2012 | Computers & Internet
NEW MacBookPro crashes! I just bought a new macbookPro and it has crashed on three different programs; won't download the manual from online (get the beach ball) and makes a sound when power-ing u
The two "whirring" noises that you hear on power up is normal. The beauty of having a new macbook is you can reinstall the software very easily and a fresh install should fix your problem. Put the disk that came with the machine into the disk drive and turn the computer off. Turn it back on and press and HOLD the "alt" button until you are given the option of booting from your hard drive or your disk. Choose the disk and when it boots up, FIRST go to disk utility and verify the hard drive. If it comes back with no problems, proceed with the fresh install of the system by following the prompts on the disk.
Jul 07, 2012 | Apple Computers & Internet
My computer drive crashed. How can I retrieve the data?
If the operating system program was all that crashed, then yes, you may be able to recover data. If the hard drive itself failed totally, then your only possible option is to take it to a data recovery specialist. They can often recover data off these devices as they have special tools and software to do it. They are expensive, though, so unless the data you are looking to recover is very important to you, it;s probably not worth the cost.Now if the hard rive itself still runs, but just won't run Windows, you can remove the hard drive and connect to to another PC as an add-on drive and access the files that way.
Jan 14, 2012 | Computers & Internet
My brother has a presario CQ62 ,without the webcam ,windows 7, 64bit and it crashed on him right before the crash the screen froze up and all it was all scratchy copy of a image like as if it just copyed a...
What happened is that your hard drive has died. The hard drive is the only moving piece of machinery inside a computer besides obviously the fans that can make that type of noise. The best course of action would be to buy a new hard drive, install it, then install Win7 again. Here is a good replacement drive.
Jul 21, 2011 | Compaq Presario CQ62-215DX Laptop
I have a dell dimension 3000 series desktop and when I turn it on it does not get passed POST and tells me the following: primary drive 0 not found primary drive 1 not found gives me the option of F1...
This normally means that the Hard Drive is not recognized, and most likely can be attributed through a crashed hard drive. If it's not POSTing, then I think you need to look for loose cords/cables as well. That can cause the hard drive to not be recognized.
Jul 07, 2011 | Dell Dimension 3000 PC Desktop
Drive won't spin up
WD drives are very vulnerable to overheating, power surges and streaks. Quite often bad power supply unit combined with power streak is usually enough to fry the spindle driver chip on the electronics and make the data inaccessible...you can try to swap PCB from another WD drive of the same model but your chances of success are close to zero. Sorry for the bad news, but your drive is most likely toast. I hope this helps.
Jul 04, 2011 | Western Digital WD Caviar Blue WD6400AAKS...
HDD Failure
The HDD ( Hard Drive ) is mounted on the back of the copier behind the rear cover. It looks like a regular hard drive from a computer. It sounds like your hard drive has crashed. It will need to be replaced. You can try to disconnect & reconect the hard drive... Good Luck
May 29, 2010 | Toshiba E-STUDIO 720 Copier
My WD My Book is not working. It looks like the
if you locate the same hard you can retrive data by changing the controller of the hard drive
Jan 02, 2010 | Western Digital My Book Essential Edition...
I have a sony vaio pcg. it powers on and does nothing else. the 2 little cooling fans come on but the hard drive doesn't run and screen won't come on. can anyone help me out. thanks
Its possible that you already have a bad hard drive. It may have crashed. Your system will not boot without the hard drive running. The computer will keep on trying to look for the Hard drive that's probably why it looks like its doing nothing. Bring your machine to sony and have them fix it. If you know how to open up your Vaio, try to check the Hard drive connection and see it its loose, if its not loose. its time to replace the hard drive.
I hope this helps. Thanks and have a nice day.
- HotRatchet
Dec 14, 2009 | Sony VAIO PCG-K35 Notebook
Toshiba e-Studio 282 Printer Logo
119 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
