Question about Toshiba Computers & Internet
My laptop, toshiba satellite, suddenly shuts down. It is about 2 years old.
Hi Annes26's
I’ve had the same problem since the very first moments I bought this weird "thing"; I sent it to fix under guarantee for twice; the problem persisted and ended up with no solution; Then they gave me a brand new Satellite Pro A40, but the thing has also happened in the new machine after a while; the only solution was to lose all my stuff because the XP Pro software disk is not a “real thing”, it is a kind of OEM "XP Pro for Toshiba" and there is no option to reinstall Windows keeping your software and data (how stupid!!!) and so did I carried out the clean install; This solved the problem. I cared about keeping the fans & heat sinks clear as suggested by the previous guest (I actually made a stand to keep it 2 inches high!) and put an external fan fully dedicated on blowing beneath my laptop. Very bizarre…lol… for nothing. It keeps happening: 1) overheats; 2) the funs go crazy and … 3) kaput!
The only solution that has worked to me so far was set the TOSHIBA POWER SAVER PROPERTIES with this configuration:
Profile: Normal
CPU control method: fixed
CPU processing speed: level 2 (out of the 4 levels, i.e. 50%) (Sorry, that’s Toshiba)
Cooling method: 50% performance.
It looks like anything above this setting sucks most of the 3 GHz for running the system itself (???), not to be used by the user.
And all this is very sad. A sluggish 3 GHz machine (not talking about my self-destructive keyboard and unreliable cd-rom (it decides in its own whether wants to work or not), the “not responding” reaction to my right-clicks and similar claims from other people I’ve seen on the net. Do any of these also happen to you?
Toshiba is enough for me. And enough is enough.
Good luck
The Second Guest
Posted on Jul 16, 2008
Try blowing the fans and heat sinks clear, could be full off fluff and dust if tosh's get hot they shut down
Posted on May 21, 2008
Toshiba Satellite P205d S7479 shuts down suddenly when on battery. The battery is brand new.
Try to turn off the laptop
Remove cables and battery on the pc
Press and hold the power button for 5 seconds
reinsert battery and cables on the laptop
Turn on the laptop
Check if the PC still shuts down. If it is, try to connect the power cable without the battery. If it turns on, call your pc manufacturer to replace the battery....
Jun 21, 2010 | Toshiba Satellite A135-S4527 Notebook
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 04, 2010 | Toshiba Computers & Internet
My toshiba laptop computer has very short battery life when it is not plugged in. It will also shut off quite frequently at times and will take a while to restart (it will turn on but it takes a few tries...
How old is the battery? Most laptops and notebooks only have a 3 year battery life, and if you have run it down too far, or never ran it down at all, the life can be even shorter than that. With nicad they say it is best to use them until they stop working. But lithium batteries are best kept topped up I hear. If the batter is over 2 years old, time to replace I think.
Jan 18, 2010 | Toshiba Satellite Notebook Computer...
Satellite a205 died. will not power up at all. 2
Go to the Toshiba web site. They often extend the warranty on laptops with common problems.
Jan 09, 2010 | Toshiba Satellite A205-S4617 Notebook
I have a 2 year old Satellite Laptop runnng Vista and thru
try starting the computer in safe mode by pressing f8 and see if that works
Jan 08, 2010 | Toshiba Computers & Internet
My Toshiba Satellite A75-S211 computer, will suddenly shut down.
Mine did this and I thought it was overheating and vacumed the back vents. This fixed the problem.
Nov 20, 2009 | Toshiba Satellite A75-S211 Notebook
Found a Toshiba laptop, about 2 years old. Screen
at two years old it is basically exctinct already and the costs of laptops coming down so rapidly you can probably go on craigslist or ebay and find a cheap laptop that is working and ready to be portable. you can also try and sell the toshiba online for parts
Sep 02, 2009 | Toshiba Satellite A135-S4427...
Toshiba Satellite A105 laptop keeps shutting off for no reason.
I think your fan might be broken....if the fan doesn't cool the pc,the processor or the chipset will automatically shut down the pc to prevent burning hardware.Or your hard drive might keep crashing.Oh yeah and abstract from this i don't recommend ever using mcaffe
Oct 25, 2008 | Toshiba Satellite A215-S7422 Notebook
Computers & Internet Logo
156 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
