Question about Insignia 42" Flat-Panel Plasma HDTV
My tv keeps flashing product info at the bottom of the screen & whenever I press display it shows it in the store demo mode. How do I correct this?
  • Scott Frye
    Scott Frye Aug 25, 2010
    Do you have the manual?
    The insignia web-site has them if you dont
2 Suggested Answers
SOURCE: the store demo mode is
Are you using an HDMI cable? Go to input and select TV. Then you should be able to access the Plug & Play option and be able to turn off the Demo Mode.
Posted on Jan 07, 2011
Why does TV not come on After previously watching it. It appears that after a long delay that I found sometimes the TV will come on can you advise me of the fault and what's required to remedy it.
It sounds like your tele maybe in store demo mode..To remedy this press the side button for volume up & whilst the volume up is displayed on the screen press & hold menu...On screen should be either Store/Shop mode Or Home/Standard mode select your preference & it should be ok.Good luck.
Aug 16, 2016 | Samsung LN32A330 32 in. LCD TV
Sony bravia lcd digital color tv
Press and hold the HOME button on bottom right side of TV for 10 seconds. It will toggle the demo mode ON/OFF
http://community.sony.com/t5/Television-General/How-do-I-get-out-of-quot-Store-Display-Mode-quot-Demo-mode/td-p/29979
Jan 21, 2014 | Televison & Video
How to remove auto visualisation n digital noise filter on and digital noise filter off features from screen of samsung lcd 21 inch....this feature is always there on the screen..........
My TV had the same problem and I have managede to get rid of it. The solution is very simple. This displays mean that your TV is in the " Store Demo" mode and any changes you make will last only for 30 minutes and when the TV is turned off the settings will change back to the normal. Whether you TV is in the "Store Demo" mode can be confirmed by pressing the "Info" button on the remote and you will see that "store demo" appears on the screen. To change this mode to the "home mode" you will have to press the "Volume button" on the TV and when the volume sign appears on the screen then you will have to press the "Menu" button on the TV (not on the remote)and hold it down for about 7to 10 seconds. This changes your TV mode from "store demo" mode to the home mode. Confrim whether the store demo mode has been put off by pressing the "Info" button on the remote to see whether the store demo sign appears on the screen. The store demo is set by sales persons in the shops so that any demonstratation/changes that they make while showing to customers will be temporary as the settings revert back to the original.
Aug 03, 2011 | Samsung SyncMaster 215TW 21" LCD Monitor
WHEN IM WATCHING TV, ICONS APEARING FROM THE LEFT OF SCREEN ,DISPAYING INFO ABOUT LED TV SERIES THEN ANOTHER ICON APPERARS ECO FREINDLY AND SLIMLINE TV. THEN IT DISAPPEARS AND AFTER A FEW VSECONDS IT...
I do not see a Samsung TV with the model UE40B7020. (What country are you in?) I do have documentation for the UE40C7000WW.
Is the TV in Shop Demo Mode? Press the Info button on the remote to see the mode. If it reads "Store Demo", try resetting it. Press the Volume button on the TV or the remote. While the Volume circle is displayed on the screen, press and hold the Menu button on the TV for about 7 seconds (the remote will not work for this). Home Mode should display on the TV screen.
Alternatively, you can set this from the TV menu system. Make sure that the current input is TV. Press Menu then select Setup (up/down arrows followed by Enter). Select the Plug and Play sub menu and follow the on-screen directions to reset the tv to the Home Mode.
The FAQ for the TV that I used as a reference is available at: http://www.samsung.com/us/support/owners/product/UE40C7000WW#
I hope this helps.
Jun 08, 2011 | Samsung UE40B7020 40 in. LED TV
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
The brand name Samsung is in the middle of the screen. I wish to remove it and with no manual I do not know what to do. Also there are other messages fliping on and off the screen too.
Method 1
  1. Press the Volume + button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
  2. With the volume bar displayed on the screen immediately press and hold the MENU button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the MENU button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Method 2
Method 3
  1. Change your TV to the "TV" source. The TV source is the coax (RF) source. It does not matter if you do not have anything connected to this source.
  2. Press the MENU button.
  3. Use the ??² or ??¼ button to select the "Setup" portion of the menu, and then press the ENTER button.
    Note: On many TVs the menu sections name is displayed on the left side of the menu and sideways.
  1. The "Plug & Play" option should be highlighted if it is not use the ??² or ??¼ arrow to select "Plug & Play" option, and then press ENTER.
  2. Note: If the "Plug & Play" option is grayed out and can't be selected this means that you are not on the TV (Coax (RF)) source. Please return to step 1.
  1. Follow the on screen instructions. When the options comes up select "Home" instead of "Shop".
  2. Finish going through the plug and play option and your TV will no longer be in Shop Mode or Store Demo.
Feb 01, 2011 | Samsung TXD1972 19" TV
Digital Noise filter off , digital noise filter on and auto visualization is always displayed in my Lcd samsung series 4 even though i turned it off in Picture options , digital noise filter is changed to...
Aug 13, 2010 | Samsung LE40R74BDX 40 in. LCD Television
My toshiba 36in crt tv's demo mode keeps turning it self on
Since I do not have your tv model number so can't be specific, check Demo mode option in Menu and turn it off. Some tvs have selection like Store/ Display and Home mode, store or display mode is demo mode so set tv on home mode to turn off demo mode.
Let me know model number of your tv if you have additional question.
Thanks.
Jul 22, 2010 | Toshiba Televison & Video
Samsung LCD picture adjustment... Store Demo...WTF...?
Push the volume button on the television set (not the remote) up once.
Then press the menu button (TV, not remote) for about 12 seconds.
It should flash once and go to dynamic mode (center, bottom of the screen), which will indicate that it is now in the "non-store-demo" mode, allowing you to save your picture settings, and access the menus.
Sep 24, 2008 | Televison & Video
Insignia 42" Flat-Panel Plasma HDTV Logo
241 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
