Question about Homelite Mighty Lite Lawn Trimmer
The trimmer starts but do not continue to run
  • Homelite Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Turn the carburetor upside down with the bottom still off and be sure that the float is level and the correct distance when you reassemble the carburetor
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Posted on Aug 25, 2010
32cc trimmer stars but wont continue running
Hi donald, if your trimmer is starting but not running it sounds as if the problem is lying with either one of two things. Firstly locate the air filter and make sure it's clean. If it is then the problem is most certainly with the carbrettor. It may need the gaskets replacing to allow the suction from the engine to pull the fuel through.
Aug 31, 2013 | Craftsman 25cc Gas Line Trimmer
GHT 225 Trimmer Replaced primer bulb, Starts OK but, will not keep running.
Try adjusting the low side screw on the carb. Back it out about 1/8 of a turn at a time until engine continues to idle. If this this doesn,t solve your problem then you will have to disassemble the carb and replace the diaphragms and fuel filter screen.
Nov 26, 2010 | Poulan Ght225 25cc Gas Hedge Trimmer
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
Have zrry30550 Ryobi Hedge Trimmer (reman.) I have good spark,good prime-up, but no fuel into the cylinder. Please help.
Hello. Get a can of starter fluid and a helper. Spray some into the air cleaner and start it up. Have your helper continue to spray a little starter fluid to keep it running for a minute or so. This will clear whatever blockage you have. Once it sounds like it is running well stop adding starter fluid and see. Joe
Jun 12, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
How do i adjust the homelite carburetor , the trimmer starts and continue working but has no power to cut the grass
if you have had this trimmer for a wile you might check the little muffler to see if it is cloged up with carbon i had on and adjusted the thing till i was blue in the face and pulled the sreen of the muffler cleaned it now it runs great
Jan 29, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Will not idle
May be time to get the carburetor rebuilt. Sounds like the diaphragms are not working properly to pump fuel. You may need some lubrication on the throttle cable too. A little lubrication on the throttle arm would not hurt.
Good Day.
Oct 14, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
High Wheel trimmer starts but won't run
Check inline fuel filter..blocked with sediment.
Sep 09, 2009 | Garden
Husqvarna 324LDx 4 cycle string trimmer. Have
Probably needs a carb kit, check main jet and main fuel inlet jet, is the spark crisp, fat and powerful, try running it with a borrowed coil as this may have an intermittent fault. Is fuel cap breather working or blocked, these small carbs are very sensitive. Make sure all is well with gaskets and diagrahms. Good luck the Yeti
May 17, 2009 | Husqvarna 28cc Gas Line Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
