During bootup, the screen shows: 1. server raid-7k on board power-on self test takes up to 60 secones. after 60 seconds, displyed another line shows: status - not responding properly - error-code 2807
    Scholar:
  • 85 Answers
It means that your raid is not seeing its drives. Usually after a power failure.
Rebooting the server will fix it in the short term.
To fix it long term you need to update the servers firmware.
Posted on Aug 25, 2010
IBM Server not detecting hard drives
You know i find this all very suspicious. For one thing a ups is designed to take the hit so it will get fried and your computer will be fine. Suspicious to me but not an answer to your question so i will try this. The new raid card was installed (might be off on this part, haven't kept up with this) were the hard drives and the raid assembly matched back up. IE raid 1, 2, 3 etc. Do believe they are up to raid 7 now. So if hard drives were not put back in the original position and and raid card setup for the original raid array you might have this problem. Hope this helps, but it's been a long time since i worked with raid arrays.
Feb 11, 2014 | IBM System x3250 M3 4252 - Server -...
Raid 7k controller not responding properlly error 2807
This could be an issue with the Raid backplane. If under warranty I would replace the backplane.
Even if no warranty you might be able to find one cheaply used.
regards,
Mike
Oct 10, 2012 | IBM X236 Server
Hi, within the previous 12hrs my e-series server bombed out - there are two issues (1) Memory DIMM malfunction (2) serveRAID-7k error 2807... I removed the faulty memory DIMMs, but the RAID error still...
You can recover RAID data from hard drive with RAID recovery software easily.
Tenorshare Data Recovery Enterprise is a comprehensive data recovery software that supports RAID recovery for RAID 0 and RAID 5. Lost data in RAID 0 and RAID 5 can be deeply scanned and restored immediately. Meanwhile, files and folders in RAID 0 and RAID 5 can be copied to other partitions directly. http://www.any-data-recovery.com/product/datarecoveryenterprise.htm
Aug 29, 2011 | IBM ServeRAID-7k Controller (71p8642) SCSI...
We have a Dell Poweredge 4400 & a Dell Poweredge 2300. Both have amber lights blinking - hard-disk failure indicators. They are using RAID. What do I need to do?
Go into the RAID setup during bootup (not always in the BIOS), but will post somewhere on startup (should say SCSI/SAS Controller card press CTRL + M to enter setup) or similar.
When in the raid setup check to see the status of the drive(s).
Was the machine running and it's just happened etc or are these machines you have obtained and are plain not working?
Sep 07, 2010 | Dell PowerEdge 2300 Server
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
"how to change write through to write back in 7k" Problem Now!
You need to use download, boot from and use the ServeRAID Support CD and the RAID controller tools on that disc. You cannot modify RAID controller features on the 7k while it is operational and/or in use.
See ServeRAID support page at http://www-947.ibm.com/systems/support/supportsite.wss/docdisplay?brandind=5000008&lndocid=MIGR-62462
Feb 11, 2010 | IBM xSeries 346 Server
Wont boot says array controller wont start and no bios dell power edge 2500 server
Sounds like the RAID controller has failed. I would replace this first as RAID controllers are less expensive than replacing the system board, or the server as a whole.
Suggested: PERC 5i (RAID 0/1/5) or PERC 5iR (RAID 1 or 0 only)
Jan 03, 2010 | Dell PowerEdge 2500 Server
LG W1952T LCD monitor power save mode during bootup?
called customer service - see other post for details
May 11, 2009 | LG L1915S 19" LCD Monitor
Problem with creating array
The Perc RAID controller in a 2600 doesn't support RAID 4.
You can do RAID 0, RAID 1 and RAID 5.
With 3 HDD's your best bet would be a RAID 5.
Mirroring is RAID 1 (which would only use 2 of the drives)
Aug 31, 2008 | Dell PowerEdge 2600 Server
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
