Question about Dell Latitude D600 Notebook
LIGHTS COME ON WHEN BUTTON PRESSED BUT GO OUT WITHIN A SECOND AND NO SCREEN
  • 70 Answers
This is a typical issue on the latitude d600. I have seen several laptops with this problem. What happen is that the computer at some point overheated, causing a cold solder. Unfortunatly the solution is to replace the motherboard, but you can try pressing the power button and at the same time putting some pressure like in the middle of the keyboard to allow the solder to make contact with the motherboard and make it turn on. It doesnt always work but I think you should try it.
hope, this helps
Posted on Aug 25, 2010
GE Spacemaker microwave makes groaning sound when start button is pressed for a second or two then blows the internal fuse. After replacing the fuse everything seemed to work, lights, exhaust fan, cl
Could be a lot of things but most probably a shorted high voltage diode assembly. If not that then the magaetron or capactors. Remember be careful there are high voltages even when the oven is unpluged. The capactors are usually charged and must be discharged. If you don't know what yor doing then time to get a qualfied tech.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Intermittent Start (expanded explanation)
Lint will jam the start/run switch on the motor. Vacuum out the motor real good and check that the switch moves freely, and all the wires to it are plugged in good.
Nov 30, 2013 | Maytag Dryers
How do i reset the service light on a 2001 mercedes E240
i dont know if the procedure works the same as the c-class but try the following
turn electronic key to position 2 in the ignition lock and immediately press button 0 (the 0 you would use to put the trip odometer to zero) twice within 1 second
turn electronic key back to postion 0 in ignition lock
then press and hold 0 button turn key to position 2 keep 0 button pressed after 10 second beep sound will be heard then release 0 button should reset service time
hope this is of help
Sep 02, 2012 | 1999 Mercedes-Benz E-Class
Pressed the sleep button..how do I get it to w"wake-up?"
Is there an actual button on your keyboard that is the sleep button? Or did you put it to sleep within Windows?
If you pressed the sleep button on your keyboard, you should be able to press that button again, and it should wake up. If you pressed it within Windows, then pressing any key should wake it up.
If neither of those works, then sometimes you need to press the power button. Don't hold it down, just press it, and your computer should wake up.
Hope this helps!
Thanks for using FixYa.
Aug 27, 2011 | HP Computers & Internet
I need to reset the service alert on the dash (mercedes ML ,2002)
Within the first 4 seconds after moving the start switch to position 2, press the reset button for the trip counter twice within one second. The display for the service request is activated for about 10 seconds.
Within these 10 seconds, move the start switch into position "0". The service request continues to be displayed.
Press the reset button for trip counter and keep it pressed.
Move the start switch into position "2".
Continue to hold the reset button for the trip counter pressed until the signal sounds and the new start distance appears in the display (it takes about 10 seconds).
Nov 08, 2009 | 2006 Mercedes-Benz ML-Class
How to make reset for service alert for my mercedes ml 320
To reset the service alert light, perform the following:
Computer is plugged in, but won't turn on
HI,
POWER ON POWER DOWN PROBLEM,ITS DUE TO AC TO DC INVERTER CIRCUIT IN RIGHT SIDE, INSIDE OF LAPTOP,IT IS SHORTED,APPROACH LAPTOP CHIPLEVEL LEVEL LAB FOR REPAIR.
TNKS
RABBANEES
Nov 04, 2009 | HP Compaq Presario F756NR Notebook
Power
When i try to turn it on the power button flashes a code. The power button lights up once for a second, then turns off, then flashes quickly nine times and lights up once again for a second before turning off. The screen doesnt turn on at all, nor do the speakers. Any help would be highly appreciated.
Feb 11, 2008 | RCA D61W130 61" Rear Projection Television
Control locked
try pressing the buttons (with your monitor turned off) if they have allowances for switching (if it is a push button then each should be pressed slightly and you should feel that it switches through!) if you pressed it and felt hard ( like something was stuck) then the buttons might have misalligned from the switches on the board. do not open your monitor unless you have electronic servicing experience. other causes might be the monitor's sync. processing IC. it could be defective.
Nov 15, 2007 | Samsung 793S 17" CRT Monitor
Dell Latitude D600 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
