Question about ViewSonic Computers & Internet
When trying to turn the unit on, the green power light flashes on and off, there's no picture. After several times of pressing and re-pressing the switch, and holding it down for varying amounts of time, I finally hit the right combo and the monitor comes on. Then it's fine, it stays on. VX922, model VS10162, serial PXU060201825
  • 11,361 Answers
Do as Louie suggested and then look for bad caps first: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX924/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 25, 2010
  • 732 Answers
Cnauroth, I would suspect this 4 to 5 year old VX922 has developed an intermittant "thermal cycled" hairline thin fracture of a solder joint somewhere on the "switch-mode-power-supply/Cold-cathode-fluorescent-lamp ballast circuit board". You or qualified electronics technician will need to inspect unit with large magnifying glass or 5x to 10x inspection microscope to locate problem and resolder it. Also inspect unit for failed CapXon brand electrolytic filter capacitors that may be swollen, bulging, leaking from their top of can vent seals!!! Lots of pic's on web if you don't have a clue as to what all this means. If not into DIY refurbishment, then just trade-in for new wide-screen. In any case let us know what you will do. Read my fixya profile for more info and links. DIY repair about $10 Contract out work $50-$70. Do some reading first. Follow links. Then return to fixya to rate this response and leave comment or testimonial if this helps you out. 12fixlouie
Lg flat screen shows solid green but no picture
Theres a great possibility
that your Power supply unit has problems
Although the fact that somehow turns on
tells us that you may find some bad capacitors and maybe replacing them might fix your problem
Jul 02, 2014 | LG Televison & Video
I have a pioneer pdp-r05XE, on the plasma, the light flashes green and red alternately whilst on the receiver it flashes green 6 times. I can't get the tv to turn on...
Unplug if you have not done so BOTH units from power for several minutes (any cable or satellite box also connected.
wait several minutes and restore power to all units which may allow them to reboot.
Cannot hurt and may help.
Dec 06, 2012 | Televison & Video
On/off green light flashes. Picture comes on for
the timer is set for a short time, try to get to the menu quick and turn off the timer it may take several tries.
Mar 06, 2010 | Televison & Video
Black ink ran out and printed one photocopy without producing any black. Change the cartridge several times BUT still does samme thing - no printing in black. Colour is fine, just no black despite changing...
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
All the best Pineworks
Feb 09, 2010 | Canon PIXMA iP2000 InkJet Printer
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Computers & Internet Logo
284 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
