Question about Lexmark X83 All-In-One InkJet Printer
Scanner Creates a Very LARGE PDF file 1.8 meg for one page
The outpout of the Scan Function using LEXMARK All in One software is too large. I have tried lowering the scanner DPI count and it is a little smaller but the file is still too large. Anybody solved this problem?
  • 3 more comments
  • Anonymous Jun 06, 2008
    Yip - I have the same issue .... any help?
  • matthew_cian Oct 23, 2008
    making them jpeg is not an option any other help, im in the same boat
  • lexmark_woes Feb 12, 2009
    I have exactly the same problem. Other people send me a small pdf file. I print it out, and then sign and scan it using Lexmark All in One. It then turns into a HUGE pdf file. How to make it smaller? (I cannot make it a jpg file - has to be in pdf format).
  • Anonymous Apr 01, 2009
    Same exact problem... do I need to buy the newer Adobe acrobat or something?
  • Anonymous Apr 28, 2009
    lexmark 10 page scan black & white word doc. 48mb. Help
I have an old X7170 and have the same problem when using the doc feeder. I scan using the flatbed the size is much much smaller.
Posted on Sep 08, 2008
  • gasman1010 Oct 15, 2010
    You are right - flatbed 1.08 MB and feeder = 25.8 MB - still too large but really weird and LEXMARK has NO SOLUTION!
  • Noni
    Noni May 29, 2014
    did you just say "NO SOLUTION", does this mean i need a new printer now? because my business depends on scanning documents to clients. please give a positive solution
I just bought a Lexmark 5495 for scanning purposes. One page scan with no graphics is 2 megs !!! It was scanned to us and was only 14 kb.
Used 75 as dpi lowest setting.
Also a 14 page contract (black/white 75 dpi-no graphics) which we bought machine to do turns out to be 21 megs. Other people have pdfed same item to us and less than 1 meg. How can I resolve? Making it jpeg does not work.
Posted on Aug 18, 2008
  • 86 Answers
Save them as jpg with no more than 200 DPI
Posted on May 05, 2008
How do I scan multiple pages on an HP Deskjet 1055 and make it one large file? or upload several pages to this site?
If you use HP Software to operate the scanning from the deskjet then you can set the scan settings to compile a number of document pages into one file.
Best to download the full set of software for your printer from this site and let it install. Sometimes older version may not have the new features you need.
HP Deskjet 1051A All in One Printer Drivers
Aug 08, 2014 | HP Deskjet 1055 All-in-one - Multifunction...
When i scanned a 2-page text document using productivity suite's "scan to pdf", it created a 48 MB file which is way larger than it should be, and much too large to send via e-mail. any...
You can try to update your printer driver by downloading the Lexmark X7170 driver from the Lexmark website at http://bit.ly/fWPweq. Select your operating system, download and execute the file.
You can also try to decrease the scan resolution. Launch Lexmark All-In-One Center application on your computer. Select Scan mode > See More Scan Settings > lower the scan resolution value to 200 or 150 dpi. Note: This will decrease the scan file size and affect the scan output.
Or you can use a third party scan software to decrease scan file size. You can search the web for free scan softwares.
Jun 15, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Hi, when I scan a document through the feeder in the top of my laser jet 3055 it creates individual pdf's for each page. I know it is possible to have one pdf for the entire document but not sure...
Yes, it is possible, all you need to do is one of two things:
One is use the feeder, that inherently knows multiple copies.
Or use the HP scanner software, (installed on each computer) and add a page.
One detail to watch is the size of the file. it gets quite large easily and certainly with multiple pages.....meaning you cannot e-mail the file sometimes...
Reset your output resolution for your document in the 100 to 150 range. Higher resolutions may be needed for some documents, but not most. This keeps the file size usable with a smaller file size.
May 11, 2011 | HP LaserJet 3055 All-In-One Printer
Unable to save a scanned document to a PDF file. I am using Lexmark X5650
when you scan a page, the scanned image is now a photograph and can't be converted to a PDF, if you want a PDF you need to scan test in and have the scanner software convert it to text.
Mar 16, 2011 | Lexmark Office Equipment & Supplies
Konica Minolta bizhub C451
yes in your scan setting select scan type in there you will see compact pdf.That will make a 10 meg file be 900k even if it is color.
1twig
May 19, 2010 | Konica Minolta bizhub C450P Laser Printer
Lexxmark x8350 PDF file is to big
I would start by looking at the actual data size of the file.
Next step, I would determine is the flow control between the printer and the PC is working correctly.
If the file is very large or intensive (lots of graphic images), I would break the file into several segments.
For example, pages one to five I would highlight and then do a "Save As" and name the new file as filename1.pdf.
Once the file is saved that way, I would move to page six and do a "Save As" filename6.PDF and so on until I have broken the file into more useful segments.
If you have the file and can send it to me at don.farr@hotmail.com, I'll be happy to see if I can structure the file for you.
Don
Dec 11, 2009 | Lexmark All-in-One Printer with PictBridge
When I scan a 1-page letter typed in MS Word from my Lexmark X3350, the PDF docuement is about 2MB - too large??
Go to scanner options, settings
Please change the resolution, set it to 75.
also please check if the setting set to original size x 2 or anything.
It should be original size also.
Cheers
Nov 03, 2009 | Lexmark OfficeCenter X3350 All-in-One...
Scanning files to large
It's the resolution you are using to scan. Try a lower setting. for documents, 150-200 dpi is fine. That will produce smaller files.
Aug 25, 2009 | Dell 922 All-In-One InkJet Printer
Scan file from Lexmark 6100 is very large
If the documents you are scanning are black and white, make sure you are selecting that in the scanner dialogue box. If you need to keep gradiants, but don't need color, try selecting grayscale. If you are adjusting your DPI (dots per inch) to the maximum (300), try using something lower (recommend 150). Lastly, check the settings in the software you use to create PDFs to ensure they are the same as what you use at the office.
Dec 24, 2008 | Lexmark X6170 All-In-One InkJet Printer
Scanner DPI issues
well..that's fine, but the virtual memory dance, is not just about size(which we all know is not the only issue, right)?..smiling.
at any rate, you'll need to allocate the VM to this function through your admin panel. You familiar with that?
Also, more printer resources are here
Jul 27, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
1,836 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
