Question about Brady LABELIZER PLUS INDUSTRL SYSTEM Printer
Print preview looks exacltly like I want, when I hit the print button I get a blank label
    Problem Solver:
  • 10 Answers
Printhead is shot
Posted on Oct 23, 2013
SOURCE: TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Posted on Jan 05, 2009
SOURCE: machine sends out blank labels when asked to print a label
I've had this problem several times and it seems that you need to push in the lock ring of the spool as far as you can tightly because if the end of each label is not seen by the sensors than it just keeps pushing the papaer out. Also make sure that there are no labels loose inside the machine that are covering the sensors.
Posted on May 28, 2009
  • 31 Answers
SOURCE: I have a zebra TLP 3844-Z printer. My printer
Sounds like it is set to do a label length check at power on. Go into your printer preferences and set it to "do nothing" on power up.
Posted on Jun 27, 2009
RoryMRP
  • 111 Answers
SOURCE: Zebra M4 is printing blank labels
Did you switch your ribbon as well?
Posted on Jul 07, 2009
  • 31 Answers
SOURCE: Zebra 2746e will skip leaving a blank label while printing.
You need to calibrate. Hold down the feed key while powering the printer on, then let go. The printer will calibrate, print a config label, then fo into dump mode. Press the fee key again to go out of dump. Of your issue persists, there could be a problem with yoru media, or with the commands that you are sending to the printer.
Posted on Jan 31, 2010
Print preview looks fine but just get a blank label from label mark. prints ok when not done from pc
You likely need to use Brady's software to create the label on the PC, and your PC will need the correct printer drivers to communicate with the Brady. The software and drivers should be available from Brady.
Apr 02, 2015 | Brady TLS 2200 Label Printer
Epson 310 runs but the paper is blank
Do a "Print Preview" and adjust the size % of the print. While in Print Preview, you see what the document looks like as you adjust the image. When you like what you see, hit print!
Apr 29, 2014 | HP DeskJet 3740 InkJet Printer
Print preview
What program are you trying to print from? What method are you using to print? More information is required in order to assist you with your issue.
Please note, the "print screen" button does not send information to your printer, but saves an image (screenshot) to a specified location on your device.
If you're looking for a quick print, and if your printer is compatible, you could try Ctrl + P, or right click and choose print/print preview.
Nov 27, 2013 | Acer Computers & Internet
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
I guyz. my hp officejet printer works very fine as in you send document to the printer but the most amazing thing is that afetr printing and you discover there is no ink on the printer page. Please...
Hello
Before actually printing your report, use the Print Preview function to see how it will look. If there are blank pages, you will see them in Print Preview.
To use the Print Preview function, simply open the report, click on the "File" menu and choose "Print Preview" from the file menu. You will then see your report just as it will look on the printed page.
Scroll through the report for blank pages. If you see blank pages, it is an indication that the data on the report is wider than the paper you are using. You can use your printer properties to change the size of the paper if you wish. If you have access to legal-size paper, you may be able to print the report on the larger paper. If legal-size paper is not an option, you will need to adjust the margins so that the blank pages are eliminated.
To adjust the margins of your report, click on the "File" menu and choose "Page Setup" from the drop-down box. Go to the Margins tab and adjust the margins as needed. It may take a bit of experimentation to get the margins just right; toggling back and forth between Print Preview and Page Setup will make the process faster and easier.
Click on the "Page" tab and choose either portrait or landscape orientation. Changing the orientation to landscape may allow all the fields to print on the same page, thus eliminating the blank pages and saving your paper.
Nov 05, 2010 | HP OfficeJet d145 InkJet Printer
Can't print in landscape no matter what I do - have tried setting, print screen, print icon. It looks fine on the screen but it will not print out in landscape. Help!
Before you print, can you do a Print Preview from the File menu?
When you choose print preview, there should be a button or menu choice that says Page Setup. In Word for Windows, it's the 4th button from the left and it looks like a little gear.
Choose Page Setup. You should see a button that has chosen Portrait. Click the button that changes it to Landscape. Then hit okay. Good luck
Aug 09, 2010 | Office Equipment & Supplies
Gaps in barcode with Zebra S4M
The gaps run in the direction of the label feed? You have a bad printhead. Bad dots on the printhead prevent it from printing your format in the areas that you see the blank lines.
There is no easy fix other than replacing the printhead. You can prevent (or actually prolong the time between failures) in the future by periodically cleaning your printhead. It's recommended that you clean the printhead after every roll of labels. The printhead is underneath the hinged assembly. Over time, ribbon or adhesive from the labels builds up and causes dots to go bad - creating the blank lines you see. Clean your new printhead with rubbing alcohol.
May 15, 2010 | Zebra S4M Thermal Label Printer
Can only print one label when I set up Avery Labels
Hi. Look at the label contents. I believe the top corners of the group is touching the header. Meaning it should only print 1 time.
Make the content smaller and be sure it is inside the body area.
Jan 23, 2009 | FileMaker Pro 7 for Mac, PC
Printer won't print
Printer doesn't print, just feeds the label.
Check your Labels and Ribbon, ensure you have the right ones.
If you have the right ones, here's what you try.
Hit the "setup/exit" button once. Then hit the "+" button repeatedly until you get to Print Meth. It will say Thermal Transfer. That setting can be changed by hitting the select button and the + button. Change it to Direct Thermal Transfer. Then use the setup/exit button to Temporary save the changes. You can change it back to Thermal Transfer doing the same method.
You will get an error, because the ribbon is in. But you can see it it prints.
Try going to the manufacturer website and read the manual about the printer.
If the printer feeds ribbon and doesn't print, more then likely it's a print head problem. When I mean it doesn't print, I mean from the printer control panel without the computer connected.
If you cannot figure out how to print the internal print fonts or setup from the Zebra 4m+ printer, you again need to go to the manufacturers website and read the manual.
Did a little research, appears that I can get a rebuilt print head for about $400. Instructions to install should be with the print head, if not reverse engineering.
Feb 22, 2008 | Zebra Z4Mplus Label Printer
78 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
NOEL
NOEL
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
