Question about BenQ PB6100 Multimedia Projector
Where are the filters?
I have taken the bulb out and am looking all around the innards of this thing and do not see anything that looks like filter media anywhere. Where are the filters located, and how do i get to them?
  • 395 Answers
They are usualy located at the vents and above the lamp housing
Posted on May 05, 2008
My stihl ms390 chainsaw starts and runs for around 20-30 seconds then stalls, i've taken off and cleaned the air filter and carburetor which both look fine, the diaphragm is intact too.
cleaning the carb might not clear problem may have to rebuild it also check fuel is correct and look at fuel filter inside tank
Oct 11, 2016 | Stihl Garden
Air filter replacement weed eater
on your weed eater there should be a lil bubble looking thing called the primer somewhere around tht should be a black box with a screw of some sort on it take the lid to the black box of and theres your air filter
Aug 17, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
I have a Bosch Vision 300/500/dlx and it cant get rid of the water, It had a message E 13, and i have cleaned the drain hose, I want to clean the Filter but I dont know where it is. when running the rinse...
I don't know your model, but the filter will be accessible without getting into the innards of the machine.
Look for something that looks like it might turn to unlock, then pull out located low down at the front or the back of the machine.
On my top loader the filter is housed in the spindle of the agitator post. Pulls out and reveals lint bag etc.
Dec 30, 2017 | Bosch Nexxt 300 Series WFMC2201UC
Where is tge filter of the GMC sierra 1998
Look anywhere and everywhere on the engine block, it should be attached to that. it could be covered and camoflauged with dirt and grease so look carefully. look around suspension members, steering components, anything, it will either be sitting vertical or sideways on the right or rear of the engine, (if your looking at it from the top) (look at your new filter for a reference of what it actually looks like)
Aug 15, 2010 | 1998 GMC Sierra
I can't locate my oil filter on my 92 ford aerostar it's a 4l can you help me. Where do I look around?
Look anywhere and everywhere on the engine block, im not a ford expert but it should be attached to that. it could be covered and camoflauged with dirt and grease so look carefully. look around suspension members, steering components, anything, since its a straight block it will either be sitting vertical or sideways, (look at your new filter for a reference of what it actually looks like)
(in some cases your filter will be just a filter, with no metal casing. if this is the case look on top of the engine, there should be a cap with a large hex nut on it, turn it counter clockwise. note this example i have only seen on the new chevy cobalts so there is a VERY low chance of this being on your ford too)
Feb 08, 2010 | 1992 Ford Aerostar Extended
I broke the handle of my vacuum mod. fm741b. How much cost replace it?
Unfortunately shark, euro pro doesnt sell any replacement parts. I just checked the schematics and the only things for that model available is belts, filters, light bulb and brushroll. I would look for a used one. in fact, let me look i might have a used one laying around. Email me if you want me to try and find you one.
Jan 16, 2010 | Vacuums
How do you change the air filter on a 2005 Mazda 3
After you take off the battery cover, then you can lift the air scoop thing, then you pop the clip on the other cover that's there on the right of the air scoop and in front of the battery and yes - look for those 4 silver clips - that's how I did found mine. You pop those clips and CAREFULLY jiggle the lid while lifting - replace the filter being sure to seat it correctly into its spot - the clips should snap on EASILY - if you are gorcing it, you'll need to check to be sure you have properly seated the filter.
Jan 13, 2009 | 2005 Mazda 3
I have a 2003 Yukon XL with 70K miles. What maintenance is required.
coolant flush and fill.. differential oil changed out ( assuming you have done trans service already also ) .. driveline (u-joints) and steering linkage lubed , fuel filter(s)..and all belts /hoses inspected ... have fun :)
Oct 20, 2008 | 2003 GMC Yukon XL
Where is the fuel filter located
coming from the back of the car look past the rear axel. You'll see a box type thing. Look around there for a filter.
Jun 19, 2008 | 1999 Pontiac Grand Am GT
BenQ PB6100 Multimedia Projector Logo
77 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
