Question about La Pavoni LaPavoni Bar S3 Semi-Automatic Espresso Machine Espresso Machine
La pavoni Bar S2 Manual I have no pressure, no espresso will come out but I do have steaming wands
SOURCE: pavoni, no steam from steam wand
Unplug the machine. just unscrew the nut of the steam shaft. Take out the shaft by turning anti-clockwise the plastic knob until the whole shaft comes out. clean the inside of the attached shaft with a small wire brush. rinse under running water until water comes out the other end. try to straighten the bent shaft (one with the plastic knob) put it all back. The shaft that
Posted on Feb 07, 2008
SOURCE: Steam wand works, but no water for espresso
I have found that I have to remove the group valve assembly about once every 1 or 2 months to clean out the .030" to .040" opening in the valve body. The manual gives instructions on how to do this. It becomes clogged with a thick paste like substance.
Posted on Jan 30, 2009
  • 14 Answers
SOURCE: Starbucks Barista Espresso Maker
This is a general comment for people having problems with leaks and pressure in their espresso machines. If you do not used filtered water, the minerals and other materials suspended in the water will bond to the moving parts and tubes of your machine (e.g.: scale). The problem will be worse if you live in an area with particularly hard water. In some cases the pressure pipes can get completely blocked and if the pump is powerful enough, the pipes can rupture, otherwise, the pump will simply not put out any water. The solution is to regularly flush out the system with descaler. The frequency of cleaning depends upon how often you use the machine. You can get descaler from any decent coffe place (like Starbucks), an appliance repair place, or the hardware store. I use CLR which is sold at hardware stores. CLR stands for Calcium-Lime-Rust, and it effectively cleans all of these and is cheaper than specialty scale removers. Simply dilute some in water and pour the mixture in the machine, then cycle the pump and run it through. Collect the spent liquid and run it through again 4 or 5 times (or more if you've never cleaned your machine before...) Allow the liquid to sit for 10-15 minutes between flushes so that the solution has a chance to eat away at the scale. Once you have done this a few times, flush out the machine thoroughly with clean water 4 or 5 times, using CLEAN water each time you rinse. If you want to get an idea of the scale that has been removed, keep a small amount of the original clean solution in a glass and then compare the spend cleaning liquid with unused cleaning liquid to see the difference. The spent liquid should be foggy/muddy compared to the clean stuff and if you let it sit, the scale will settle to the bottom of the glass and will be clearly visible. You can prevent some of the buildup in your machine by using filtered water as they do at Starbucks.
Posted on Jun 05, 2009
  • 7 Answers
SOURCE: Starbuck's Barista steam wand leak
DPcurry is right. You may have to plug it in to get a "feel" for which way and to what degree to rotate the shaft, but works like a charm.
Posted on Jul 08, 2009
SOURCE: Steam Wand Leaking on La Pavoni Espresso Si
I HAD the same problem. I fixed it for 50 cents. It takes the removal of 4 screws (2 phillips on top, 2 long standard on bottom by the group) to remove the top to access the steam wand valve. Once the the top (and the chrome bezel) is removed, then screw out the valve counterclockwise buy ALL THE WAY until it comes out. There are 2 O-rings on the stem of the valve that wear out, Cut these off with a sharp knife, go to your local hardware store, buy 2 new ones for 50 cents, install new O-rings, and reverse the disassembly procedure. Voila, no more leaky steam valve!
Posted on Jul 24, 2010
Espresso machine problems
Hello les laj,
You should first try to take a look at the manual. If you coninue with problems, let me know.
 Manual: http://www.lapavoni.com/PDF/MAN_barENG.pdf
You can find the installationsection on page 7
Jul 17, 2008 | La Pavoni LaPavoni Bar S3 Semi-Automatic...
La pavoni stops boiling water
Run some WHITE vinegar through it, followed by plain water a few times. The heating system gets a buildup in it and requires cleaning from time to time.
Feb 06, 2012 | La Pavoni Coffee Makers & Espresso...
Steam wands on espresso machine wont work
There should be a boiler pressure and water pressure guage. If there is no pressure on the boiler guage that could mean a heating element or pressure stat problem.
www.kaldi.com
Jun 12, 2010 | La Pavoni LaPavoni Bar S3 Semi-Automatic...
Jun 20, 2009 | La Pavoni Espresso Si PAB-16 Espresso...
Unregulated pressure then safety valve releases pouring out steam
It seems to me that your pressure stat which is inside the base of your machine needs replacing. I would try to give it a good descale and if this doesn't do the trick then a new pressure stat is what you need. Prob around £20 if you buy it and do it yourself. www.theespressoshop.co.uk and just click on the little la pavoni machine for full parts list.
All the best
LaPavoniBoy
Apr 13, 2009 | La Pavoni PC-16 Espresso Machine
Pavoni, no steam from steam wand
i havent heard of this issue , it could posibly be the bent steam wand , but the nozle is made to be that way, because the pavoni eurpicola doesnt produce enough steam pressure , it enables you to create better froth
Oct 25, 2007 | La Pavoni PC-16 Espresso Machine
No pressure
I have the same problem are awaiting reply from la Pavoni direct...I suspect there is a fualt with the pressure gauge as it is steaming up too!!
Jun 10, 2007 | La Pavoni PC-16 Espresso Machine
La Pavoni LaPavoni Bar S3 Semi-Automatic Espresso Machine Espresso Machine Logo
172 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
noel
noel
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
