Question about Hisense TC24FS2H TV
I replaced the fuse on my Hisense TC2108D TV, but now its show EEPROM ERROR PLEASE CHECK
  • 70 Answers
It due to EEPROM IC fault the iC is 8 pin and mark as 24CXX here XX -is 02 ,08 or 16 like that
just replace new one and see the error cord some time you need programmed EEPROM to resolve the problem
Posted on Aug 26, 2010
Hisense 54 model tc2108d I replaced eeprom but still saying eeprom check
After EEPROM replacement, its initialization should be done. If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Try type in the key word "EEPROM" too, in the search box.
Jul 06, 2016 | Hisense Televison & Video
MY Hisense LEDN32D33 is not coming on,its only showing the red light flicking next to the power button,i don't know if is the power supply dead and its seems like there is no fuse inside,please Help
Hi there!
The problem is with the power supply some capacitors have gone bad need replacement ,Replace swollen capacitors and the TV will turn on.
good luck buddy .
Feb 27, 2016 | Hisense Televison & Video
My Hisense F46V89C, 46inch LCD TV no longer turns on, and only Clicks. Can anyone tell me which component is the EEPROM i'm supposed to replace on the main board?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 29, 2015 | Hisense Televison & Video
Power supply problem
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Feb 01, 2015 | Hisense Televison & Video
My hisense tv is saying eeprom error
Main system control memory IC [EEPROM] fault. Contact any service technician.
Electro help
Aug 18, 2014 | Televison & Video
Hisense 54 cm tv
You have to reset the EEPROM with initial values. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 02, 2013 | Televison & Video
Programme eeprome 24c32 tv lcd 32v68aeu hisense
After replacement the EEPROM, it should be re-programmed. Check this link http://electronicshelponline.blogspot.com/ to see the re-programming procedure. Pull up previous posts.
Jun 10, 2013 | Televison & Video
Our 40' hisense tv keeps blinking sometimes it goes for an hour or two without and sometimes it blinks continuously
Hello
You haven't given the exact model number to your Hisense TV here. Yet, i posts this solution, as this is a common problems to all TV, irrespective of Brrand and model.
Check its power supply regulator board, for any loose solder points. Resolder all the suspected solder terminals to this board, by applying a little more solder, without making any solder bridge short in between adjecent solder terminals. You have to take the board out from the TV to do this job.
Reset it and see whether it helps you. If not, power retgulator board must be replaced as card basis. OK.
Feb 15, 2012 | Hisense Televison & Video
Error ##334., its my problem
The error code ##334 represents a EEPROM check error. The manual says this means the Printed Circuit Board may need replacing, however, try this procedure.
Insert paper into machine.
1)To enter service mode press Menu, copy, #
2) Select Test Mode with the + or - keys
3) Press OK
4) Press 8, lcd shows 'Please Wait', after wait, press 3, the lcd then alternates between 3-0 (EEPROM clear), and 3-1 (Purge flag)
5) When EEPROM clear (3-0) shows in lcd, press 0, then OK, then Stop then press the OFF button.
Repeat the above from Step1 to step3
in step 4 this time reset the Purge flag by pressing 0 when 3-1 shows in the lcd, OK, Stop, Off.
If the red fault light is still blinking press Resume.
hope this helps
Sep 05, 2011 | Canon SmartBase MP730 All-In-One InkJet...
Televison & Video Logo
214 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
