Question about Whirlpool Washing Machines
Removing pump filter - Whirlpool Washing Machines
  • 92 Answers
Just press tightly the broken-like part and pull it softly and here you got it
Posted on Aug 25, 2010
How to remove Zanussi ZWF14581W Filter - Drain Pump
Sometimes a larger object prevents pull out the filter and then is only solution to remove drain pump from the filter housing and remove the foreign object from opossite side.
26176372-mqizlhaqplgaehwd1f10tdku-3-0.jpg Dado
Apr 26, 2016 | Zanussi Washing Machines
Where is the fuel filter located on a 2001 Hyundai elantra
That fuel filter is in the fuel tank, attached to the fuel pump. Not a very difficult job. Remove the rear seat cushion, then remove the access panel to the pump. Remove the gas cap to relieve any pressure. Remove the ground wire and fuel lines, then remove the filter.
Nov 16, 2014 | 2001 Hyundai Elantra
Fuel pump and fuel filter location
fuel filter located in fuel tank with the fuel pump.to remove fuel filter with fuel pump you can remove fuel pump from the trunk area.just remove spare tire and jack.then remove floor trunk liner.now you are at the fuel pump reach.
May 20, 2013 | 2008 Pontiac Grand Prix
How do i get my filter out of my bush a127ldw washing machine got E03 error am working my way through your list but cant get filter out
Water inlet filters
On the tap part of your machine's water inlet
hose and at the ends of water inlet valves, there
are filters to prevent entrance of the dirt and
foreign materials in the water to the machine. If
the machine is unable to receive sufficient water
although your water tap is fully opened, these
filters should be cleaned.
x Remove the water inlet hose.
x Remove the filters found on the water inlet
valves by using a pincer and wash thoroughly
with a brush. (1)
x Clean the filters of the water inlet hoses
located on the tap side by removing manually
together with the seal. (2)
x After you clean the filters, you can fit them
the same way as you have removed them.
Pump filter
The pump filter system elongates the life of your
pump, which is used to drain the dirty water. It
prevents lint to enter the pump. Cleaning of your
pump filter in every 2-3 months is
recommended. To clean your pump filter:
x Open the kickplate's cover, by pulling the
handle. (2-A & 3-A)
x Before opening the filter cover,place a cup in
front of the filter cover to prevent flow of the
remaining water in the machine.
x Loosen the filter cover by rotating it counter
clockwise and drain the water. (4-A)
x Remove the foreign materials from the filter.
x Check for the rotation of the pump manually.
x After you have cleaned the pump, fit the filter
cover by rotating clockwise.
x Put the kickplate cover into place.
x Do not forget that if you do not fit in the filter
cover properly, it will leak water.
Jan 21, 2013 | Washing Machines
Kenmore Elite HE3 - Washer stopped - door locked - did not drain and spin - Getting error message F02
  1. Unplug the washer.
  2. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer.
  3. The drain/filter/pump is right in front.
  4. You can see a diagram of the pump at http://www.repairclinic.com/PartDetail/Drain-Pump/1200164.
  5. First remove as much water from the washer as you can. Place a large towel under the pump - a lot of water will come out when you remove the filter cover cap.
  6. Remove the drain filter cover cap by turning the filter cover cap counterclockwise.
  7. Remove the filter and check the housing and pump impeller vanes for debris (see if you can move the pumps impeller by hand).
  8. Clean the cover cap gasket and the gaskets mating surface.
  9. Replace the filter and close the cover cap firmly.
  10. Run a short wash cycle and check for any leaks at the filter cover cap. If the error comes back, you may need to replace your drain pump.
  11. Replace the kick panel if none are found.
Feb 27, 2011 | Kenmore Washing Machines
Hello, I was just wondering how to change the fuel filter on a 2005 mazda 6 v6?
Mazda Car 2005-06 Repair Guide
Fuel Filter Removal & Installation
The fuel filter on most Mazda cars can be located on a bracket in the left rear of the engine compartment, next to or beneath the brake master cylinder fluid reservoir or as part of the fuel pump assembly.
The filter on Mazda3 models is part of the fuel pump assembly.
The fuel filter is part of the pump assembly. Once the fuel pump is removed, remove the filter retainer and filter. refer to the fuel pump procedure or removal and installation.
Hope helps with this (remember rated this help) Good luck.
Jan 12, 2010 | 2005 Mazda 6
Need to remove external oil pump on a 95 ford tauras 3.8 v6.what all is involved doing this??
Oil Pump
Removal
  1. If necessary, remove oil bypass filter (oil filter).
  2. Remove oil pump and filter body to engine front cover retaining bolts and remove oil pump and filter body from engine front cover.
  3. Inspect oil pump body seal (6C639), oil pump and filter body and engine front cover for distortion and wear. Replace components as necessary.
Installation
  1. Position oil pump and filter body on engine front cover and install retaining bolts.
  2. Tighten the small engine front cover retaining bolts to 8-11 Nm (71-97 lb-in) . Tighten the large retaining bolts to 23-32 Nm (17-23 lb-in) .
  3. If removed, reinstall oil bypass filter (oil filter).
Dec 04, 2009 | 1995 Ford Taurus
Fuel filter location/replacement My car is cutting out at 4000 RPM
2006 Mazda MX-5 Miata 2.0L MFI DOHC 4cyl
Mazda Car 2005-06 Repair Guide - Removal & Installation
I hope help you. Good luck.
Oct 12, 2009 | 2006 Mazda Miata
Zanussi IZ 12 pump access
You should not need to remove anything to check and clean pump filter.
Open the filter door at the bottom right front of washer, there you will see the pump filter cover, unscrew the filter anti-clockwise, and remove the filter, and clean same.
With the filter out, you will see the filter housing, which is fastened directly on to the pump, have a good look inside the housing, and see if anything is stuck in there.
Refit filter, and test.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Zanussi IZ12 Front Load Washer
LG front load washer has blocked drain line which is located in
take top off remove three srcews in back ..remove 4 screws hold control console ,,dont remove connection just flip console on top of drum,,make sure unit is unpluged..your looking at 4 screws across to panel remove them open door remove spring wire clip around the out sid bellows where almost there..now careful down in the filter acess panel remove the frist screw the filter cover comes off after the cover is out remove the pump filter housing screw..and last remove thebottom panel screw,,remov panel,,pump on left is drain pump..pump on right is recrulation pump
Dec 13, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washing Machines Logo
15 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
