Question about NRS Fleck 5600 - 64,000 Grain Timer Water Softener
In sevicemode it keeps backflushing - NRS Fleck 5600 - 64,000 Grain Timer Water Softener
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 306 Answers
The main piston is frozen up or broken. It needs to be replaced. Parts are available at softnerparts.com.
RJ
Posted on May 08, 2011
Can i backflush my 2002 Steel Uno Pro
You need to check if you have the solenoid valve, if you do, then back flush regularly to avoid group blockages.
You would want to descale regularly as well to avoid the solenoid blocking.
JURA descaling tablets
Sep 23, 2014 | Ascaso Steel uno prof Espresso Machine
How to backflush 2000 vw beetle gls 2.0l
What do you mean by "backflush"? I've never heard of that term before. What system are you trying to work on?
Oct 15, 2013 | 2000 Volkswagen Beetle
I want to install a Prestone backflush "T" but
HEATER HOSE IS THE TOP HOSE LEAVING WATER PUMP GOES INTO FIREWALL TOWARD HEATER CORE. PUT T IN THAT HOSE.
Jan 10, 2011 | 1993 Toyota Pickup
Sometimes my 2003 S10 blows cold air out of the heater. At those times, I notice one of the heater hoses is cool while the other is hot. Suggestions?
Try backflushing the heater core - sometimes they plug up and will not allow the water to flow. You can go to an auto parts store and get a backflush kit which should include a backflush connector, clamps and an additive to put in your coolant system as well as directions to install connector. Pour additive into your radiator after you install the connector and use some vice grips to pinch off the heater hoses so you don't lose all of your coolant when you cut the hose to install the connector. Clamp off both hoses to prevent premature drainage and make sure you drain radiator and coolant system afterwards, adding the proper mix of antifreeze and water when you're done to prevent engine damage during a freeze.
Good luck!!
Nov 22, 2010 | 1998 Chevrolet S-10 Pickup
How to repair a brother . show on screen clear Unable 46
unable to clean 46 is showing because of its waste ink absorber count is full. u have to go to sevicemode and can reset it on funcyion 80
Jun 12, 2010 | Brother IntelliFax Fax/ Phone/ Copier
I have La Mazocco 2 group and when backflushing,
Machine is saying it cannot get water, turn knob to 0, wait a few seconds and make sure water is turned, then turn it to 1, wait 20 secs, then turn it to 2.
Apr 12, 2010 | La Marzocco Linea Group 1 Espresso Machine
Zoeller M53, pump keeps pumping half the power
try backflushing with high pressure water(carwash) if that doesnt work you have to remove the bottom plate to expose the impeller and remove debri,gasket will probably have to be replaced(silicone) will do
Oct 31, 2009 | Zoeller M53 Mighty Mate Iron Body, Poly...
2000 Olds Silhouette (3.4L) coolant change/flush.
Power flushing is usually not a good thing as the heater cores can become blocked.I would suggest to remove the lower rad hose and drain as much coolant as possible.Refill with clear water with lower hose reattached.Bleed system of air as you fill with water and keep filling until operating temp is reached.Drive and return and drain it again the same way,now refill with at least 1 and 1/2 gallons of dexcool and don't forget to add the vegetable based aluminum protector required in your vehicle available from gm and make sure you bleed the air from the system from the valve just to the rear of the rad filler neck on the engine at the end of the coolant pipe running across the front of the engine.
Mar 24, 2017 | 2000 Oldsmobile Silhouette
Pump stopped woking when I turned it off to backflush
You have got stuff in your impella.
Take pump away from pipes and 'elec' power lines - empty skimmer filter inside pump - turn over and remove all 'stuff' from inside skimmer filter section.
If you can - turn impella using knife or screwdriver see if it runs smooth and silent.
Jun 26, 2009 | Hayward 1.5 Hp Northstar High Performance...
I was backflushing my machine and now the portafilter is stuck
The brew solenoid is not discharging the pressure from the group, the line might be clogged, if you remove the top and then side panels of machine you will see the discharge tube flowing into the drain tray, try unclogging hole, then backflushing to see if the solenoid discharges.
May 13, 2009 | Pasquini Livia 90 Espresso Machine
NRS Fleck 5600 - 64,000 Grain Timer Water Softener Logo
43 people viewed this question
Top NRS Home Experts
john h
Bill Boyd
Mike
Mike
Are you a NRS Home Expert? Answer questions, earn points and help others
