How do I install netgear range max duo wireless wndr3300 router on my 64bit dell inspirin 530 computer?
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Then if you want to secure wifi then enable WEP security in Wireless security then enter code it is your password to connect wifi. Then on your computer wireless lan adapter you can connect your wifi. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 25, 2010
Netgear 3300 does it work as a wireless repeater?
http://reviews.cnet.com/routers/netgear-wndr3300-rangemax-dual/4505-3319_7-32863752.html
sounds like that router isn't really well liked.
I do not recommend using wireless repeaters because your "second" network is only as good as the uplink to it, and I find you often can't move the repeater too far from the first router without sacraficing a lot of quality.
plus that router has bad range to start from what I hear
Oct 14, 2012 | NetGear WNDR3300 - RangeMax Dual Band...
Trying to make my Dell Inspiron 580 computer wireless with Netgear N600 adapter. I run Windows 7,
hello,
check if the router has support for win 7 ,if not search for win vista,the instalations(i mean the configuration page you should run in internet explorer) look at the link provided with the router and follow the instruction
Sep 22, 2012 | Dell Inspiron 580 Desktop Computer (Intel...
Where can I buy a power cord for my netgear duo wierless n router wndr3300?
I see the WNDR3300 needs 12v at 1.5A according to the Manual, Maplin do a 12v 1.5A power supply (L47BL) for £19.99 see:-
http://www.maplin.co.uk/ac-dc-fixed-voltage-switched-mode-power-supplies-48484?tabid=1&criteria=usb&c=so&u=strat15
if you DO get one of these (or simular), Make sure the centre connector is POSITIVE!
the maplin one has reversable adapters so it's easy on that one (once you have set it i'd suggest glueing it in position)
Feb 15, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
I want to set up my wifi dvd player to one of the wifi connections and leave the other for my lap top. don't know how to use both of the wifi connections.
This is NOT a DVD player. The Netgear RangeMax Dual Band Wireless-N Router WNDR3300 features a rather misleading name. The router doesn't support true dual-band wireless-N, nor does it offer very good range. It's a basic router with two separate access points (AP), one of which supports Wireless-N and can operate in either 2.4GHz or 5GHz frequencies--similar to the D-Link DGL-4500--while the other is a regular 802.11G 2.4GHz-only AP. The result is that when in dual-band mode the router is able to offer Wireless-N only in the 5Ghz frequency, while the 2.4Ghz frequency is maxed out at the 802.11G speed. Still, if you have a growing stable of 5Ghz-based devices and want a router that supports both frequencies, the WNDR3300 is the cheapest router on the market (at about $100) that will suit your needs.
While its max throughput is relatively low, the router offered very consistent and considerably high throughput speeds on both our mixed-mode and long-range throughput tests. Unfortunately, its range is possibly the shortest among Wireless-N routers. If range is not important to you and your network primarily consists of 5GHz-based clients, the WNDR330 is a good bet. Otherwise, for the same price, we'd recommend the 2.4GHz-only Linksys WRT310N; or you can pay $50 more for the true dual-band Linksys WRT610n.
Dec 27, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Needing the pass code for our laptop computer for
Is there any computer online using the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Jan 13, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
I have two range max dual band wireless-N router wndr3300's. I want to set one of them up to act as a repeater. How do I do this
HI,
Visit the below link to know about the required settings to configure repeating between WNDR3300:
http://kb.netgear.com/app/answers/detail/a_id/2745
Let me know if you need any further help.
Regards
Anand
Oct 30, 2009 | NetGear RangeMax Dual-Band Wireless-N...
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 11, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
