Question about Sony KDS-50A2000 50" HDTV
My LED starts blinking green 3 times pauses blinks green 4 times then I hear a slight clicking sound and it blinks red 4 times.
  • pcards Aug 29, 2010
    cuasi, Thanks for your reply - I just had a chance to check out the door safety s/w and the fan did not start up ( this was after a new bulb was installed) the second s/w you refer to appears to be
    some kind of thermo sensor?? It is located above the bulb. if this is the s/w you refer to it has 4 wires white,grey,black,white which wires would I tie together to check this s/w
    Champion:
  • 453 Answers
U have 2 problems if u already replace the lamp for this unit , the problem with u tv is a safety swicht and a bad fan , take the back cover off and u would see this little s/w one for the door and another one for the lamp follow those wire , do one s/w at the time cut the wire and puthen together after u have than with the one s/w for the door do the next one this one is little be difficult , do the same way as the first one after that turn the tv on and u would see the the big fan is not ruaning u need to replace this fun , u can get this fan by the model # good look if u have any q? just let me know
Posted on Aug 25, 2010
Testimonial: "Cuasi was extremely help full - right on the "money" "
    Cuasi, Thanks for your help. I just had a chance to test the door switch and the fan did not start after a new bulb replacement. The second s/w you refer to appears to be some kind of thermo sensor it is located above the bulb??? is this the right s/w and if so there are 4 wires which one would I tie together to test?
  • Jose Garcia Aug 30, 2010
    not is not the themo , if u already did the door s/w is only 2 wires grey and black , this s/w is under the lamp is very small , when u take the back cover off and the fan u would see this little s/w is right under the lamp looks likethe door s/w jump the 2 wire , ( grey and black ) for this s/w not the thermo
TROUBLE SHOOT LC-60E78UN TV
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 30, 2016 | Sharp Televison & Video
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
STAND BY BLINKING LED 6 TIMES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. For more information go to http://electronicshelponline.blogspot.com/
Nov 23, 2013 | Sony KV-35S26 35" TV
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Screen went black no sound no picture when i turn the power on power light comes on green i hear a click and then it goes blinking red
How many times red light blinks? It is error code of problem in TV.
There would be pause of 3 seconds between blinks so count from pause to pause and let me know to find out solution.
Aug 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Tv wont trurn on
Re-check the lamp door alignment. If the door is not installed properly, the interlock switch will open causing a no start condition. Also observe the red LED on the front panel. When you turn on the TV, a gree LED will blink on and off until the image appears. If the image fails to appear the green LED will give way to a red LED that will flash a specific number of times in between pauses. 3 blinks means the door is not installed correctly. 4 blinks means that a fan has stopped working, etc.
michtech
Feb 17, 2009 | Sony KDS-50A2000 50" HDTV
Philips 37PF9431D/37 No Picture
While I can't tell you what this particular code means I know from experience that power boards fail frequently commonly on those TVs. Do you hear a clicking of the power supply first on and then off after a few seconds?
There's a guy or a company on eBay that offers trade-in for faulty power supplys, you should check them out:
http://stores.shop.ebay.com/TechFetch
Search for 37'' Philips in the title or contact them to ask about it. Used to be $99 flat including return shipping.
Nov 20, 2008 | Televison & Video
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Sony KDS-50A2000 50" HDTV Logo
87 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
