Question about Cell Phones
A few days ago my 4gb mem card was working good but now its not reading on mobile or even on computer !!!!
    Sergeant:
  • 132 Answers
Your memory card has been corrupted..try another memory card
Posted on Aug 25, 2010
The PNY Optima SDHC 4G mem card cannot be formatted on the camera and can't be read on the computer.
Check write protection on side of card. Plus, was the card formatted on a MAC or Linux? Window and most devices use FAT or FAT32 formats.
Jul 15, 2012 | PNY 4GB Secure Digital High Capacity...
My camera and the memory card got wet a few days ago. When i try to load the card onto my computer it doesnt read the card. Does this mean all the photos are gone for good?
The card is most likely done for but there are a few tricks you can try. If the card is still wet then no device will be able to read it and while it might appear dry there could be residual water inside the unit. The most effective way to get water out is to put it inside a container of white rice (not that you will eat after using it this way) so that the card is completely immersed and leave it in for at least a week. The rice will act like the little packs you see in boxes of electronics and **** the water out of the air and nearby items. You could also use those gel packs if you happen to have any lying around.
If this doesn't work, take the card to a local geek repair center (most electronics stores have their own versions now) and they might be able to do emergency recovery for a fee.
May 23, 2011 | SanDisk ULTRA II 4GB Compact Flash Card...
My 4gb mem. sick pro duo wont work in any of my sony devices anymore, whenever i put it in it says something like no disk is inserted and idk how to fix it
The memory stick is probably dead. The most common cause for this is ESD (Electro Static Discharge) to test, use a USB card reader to look at it on your computer. if the computer sees it, try formatting the card.
Mar 11, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
SanDisk memory stick pro duo 4GB not reading
does ur camera recognize ur mem stick if yes then copy all ur pics to a computer then format it an insert the stick to ur cam and u can copu it again to the stick. check it out.
Oct 13, 2009 | SanDisk 4GB Memory Stick PRO Duo Memory...
My T-Mobile Dash won't read a 4gb SD card
Most T-Mobile Dash phones will only recognize a 2gb sd card. I've only heard of some 4gb cards working, what type of card do you have? Unfortunately it's probably a compatibility issue and you'll need to get a 2gig scandisk, a 4gb scandisk might work, I'm not sure though.
May 09, 2009 | T-Mobile Dash Smartphone
SD memory card and cell phone problems
To my knowledge, razr's can not handle a 4gb card.  I believe 2GB is the highest.
Mar 06, 2009 | SanDisk 4GB microSD High Capacity Memory...
4gb memory card but when songs are bluetoothed sayes mem full
Hi there
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Feb 23, 2009 | LG KS20 Smartphone
    Nokia N95 Orange Too Slow.
    hi.. the reason for ur slow operation of ur mobile might be due to some software problem...The only way to get rid of this problem is that to format ur entire mobile...Or the other one may be due to full use of ur memory card...I mean for example if u are using 1 gb memory card u are not suppose to fill ur mobile completely for 1 gb.. try to some keep some memory space which will ease ur mobile opeartion...
    thank u
    Feb 01, 2009 | Nokia N95 Cellular Phone
    What's max mem size for ipaq 1950
    Mem cards are added as storage cards and do not add up to your iPaq RAM.
    You can use mem cards to add up space to install applications. (ie. it is something similar to installing a new Harddrive on your PC). However the physical RAM of your iPaq cannot be extended.
    PocketPC programs have small RAM requirements so your PDA's built-in RAM will suffice.
    As far as the maximum card size if I understood your question right, if your iPaq comes with Windows Mobile v5 or earlier, it supports SD cards up to 2GB and perhaps some non SDHC standard SD cards up to 4GB. If you can upgrade to WM6, then WM6 supports SDHC cards, so you can install >4GB cards.
    Hope this helps.
    Feb 16, 2008 | HP iPAQ rx1950 Pocket PC
    Memory Card
    check if your e2 can handle a 2gb mem card, most unit made three years ago cant handle even a 1gb mem card. check your unit capability first before buying a new mem card . [:0)
    Jan 04, 2008 | Electronics - Others
    Cell Phones Logo
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
