SOURCE: how can I scan to a PDF file?
for inserting clips to your pdf file you require pdf maker. download it her
www.cutepdf.com
SOURCE: I get an error 0x00000015 when i try to scan from
Uninstalled the printer. Reinstalled using the cd that came with the printer instead of using the drivers off the internet. Configure the printer to work with windows 7.
SOURCE: Scanner error in HP officejet Pro L7590
These instructions will fix the majority of scanner problems and networking problems using ethernet:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01849855&lc=en&dlc=ro&cc=ro&product=3643612&rule=4124&lang=ro
The key is to assign a static ip address for the printer. The install problems of trying to get the HP printer to be found will go away. You can then use the scanner. Also...it is crucial that when connecting other laptop's and PC's on the same network that you use the hp printer'rs host name to find the printer on the network. I find that the IP address can and usually fails to find the hp on the network. Mostly likely you cannot search the network for a hp printer until you go the route of find the hp network printer with the host name of the printer. You will also need your install disk when installing on other networl laptop's and PC's since windows xp and Vista machines don't have the drivers in the list. You will need to point the add printer gui driver to the disk and look for autorun.inf
file. After selecting that file...you can then see your drivers.
SOURCE: Error 0X00000015. HP laserjet 3050 won't scan
If you need more help come back.Post /
thumbs / testimonial are
welcome!
Solution two: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
NOTE:
The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (
Figure 2: Example USB connection (your product might not look exactly the same as this example)
