Question about Air Tools & Compressors
I own a model A IR 231 air impact wrench that suffered an open stuck trigger. I took the body apart to try to fix the problem. The trigger is now free but in my haste I did not observe the assembly order of the various parts. Is there an assembly diagram that I may refer to and is there a refresher kit that will bring the 231 up to max torque? Thank you.
brainyass
  • 242 Answers
SOURCE: Impact wrrench disassembly
Check to see if #27 is holding it in.
Posted on Oct 24, 2008
Idaho_Biker
  • 32 Answers
SOURCE: IR 2135TI repair manual
Go to: http://www.irtools.com/contact/?pro=&cat=&sbu=&formType=ussales
make a Request for schematic, they have always given me great assistance.
Posted on Jan 17, 2009
  • 24 Answers
SOURCE: just blows air when trigger is pulled.
Dave The rotor is too tight on the plate. Tap shaft with fiber mallet to open the clearance
Posted on Apr 15, 2009
  • 583 Answers
SOURCE: I DESPERATLY NEED A DIAGRAM OR EXPLODED VIEW OF
take it to a servce centre for air tools ,there is a little neoprene or plasic o ring right up in trigger area ,that gets brittle and starts to break up. bugger of a job, why waste aday they wll do it in a flash (sort of) youdoit
Posted on Aug 04, 2009
john631068
  • 172 Answers
SOURCE: Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
Posted on Nov 17, 2009
Fixing a trigger on an old impact wrench.
You will need to find a spring for the trigger, parts are hard to come by new unless it is a Snap-on or MAC brand.
Sep 07, 2016 | Impact Air Tools & Compressors
STUCK TRIGGER
The I.R. 2135Ti or TiMAX has some known issues with the trigger o-ring (item# 22A) swelling, the throttle valve (item# 28D) bending or breaking, and the throttle valve seal (item# 28E) wearing out or deteriorating. Procedure wise you should not be able to remove the trigger without first removing the inlet bushing assembly (item# 26) the reason is that the reverse valve (item# 24) keeps the throttle valve from tipping forward and releasing the trigger, there is a slot for the stem of the throttle valve to slide into.
Follow this link to the parts list:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
When reassembling the tool first install the inlet bushing assembly and then install the trigger, make sure to lube the o-ring before inserting.
Oct 17, 2012 | Ingersoll Rand 2135Ti Air Impact Wrench
Model 734 1/2 in impact.wont blow air ,wont rotate,no tension on trigger.feel like problem may somehow be in trigger housing....
Yes, if you take it apart you'll find that the trigger isn't allowing air to pass through to the veins of the impact wrench. It's a relatively simple mechanism, where maybe something is broken inside.
If it were blowing air but the veins were stuck, I would say, lubricate it. But, if no air goes through it at all, then the trigger housing houses the problem part.
Have you tried to disassemble the air wrench?
Jan 21, 2011 | Chicago Pneumatic 1/2" Air Impact Wrench
My impact wrench when connected to the airhose stay on even though the trigger isnt pressed
you probably have rust and goo in the line and it has stuck the trigger open,run some air tool oil in and let it soak or better yet some penetrating oil to break up the sludge and then when cleaned out use the air tool oil to lube it
Feb 27, 2010 | Impact Hdc 3/8" Drive "Reversible" Air ...
Need repair diagram ir 2135ti want to reassemble trigger for 1/2" 2135ti
try going to irtechpubs.com nd under industrial tools you will find your model number and can download a breakdown for it. Let me know if you have trouble, I went thru about 15 sites before I found it.
Nov 02, 2009 | Ingersoll Rand 2135Ti Air Impact Wrench
My ir 223 impact trigger doesnt work ,,,I took it apart ,the pin tha goes thru the body is there but the pin in the airlet is missing and it must be missing a spring too ,it just wants to run wide open all...
You can purchase a repair kit from Ingersol that will have the spring and pin. You will need to make sure the fitting on the inlet that has the screen installed is still there or the pin and spring will come out again
Sep 26, 2009 | Ingersoll Rand Ingersoll-Rand 1/2 in....
No pressure when pulling trigger, trigger sticks in handle body
if air sound comes out when you press trigger your pressure regulator pin is stuck-oil gun and attach hose repeate until pin frees or remove pin and clean with brake kleaN oil and replace
May 31, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
Just blows air when trigger is pulled.
Apr 07, 2009 | Impact Ingersoll-Rand 1 Inch Heavy Duty...
Air Tools & Compressors Logo
157 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
