Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Jam err 0A12 whech senser problem - Canon imageRUNNER 3300 All-In-One Laser Printer
E000302-0001 err while printing in canon c3320i after that the printing in not working
fuser unit drive or rotation error .
please check lower roller or chane fixing flim
Jan 09, 2018 | Canon Office Equipment & Supplies
Scx 4632f
hi, your printer papper out senser is damaged or papper out senser liver is damaged please check
Apr 02, 2014 | Samsung Office Equipment & Supplies
Kodak i260 paper jam
cluch motor problem or senser probelem,
tray first front side scan only its pass the paper than
scan next back side if not pass problem from fron or back senser
Aug 03, 2013 | Kodak i260 Duplex Color Scanner
Samsung SCX-4521F All-In-One Laser Printer states there is a document jam and toner empty but no documents are jammed and the toner has ink....cannot find the paper sensor to check if its causing the...
hello try to do this
press #1934 and right arrow key disply appear ready tech press menu &left arrow key display new cartridge press enter button twice. then toner empty message is over do previous simulation for go normal condition.
paper senser is located at back side of the machine remove backside cover and see heater unit near the hot roller paper senser is located
Aug 19, 2010 | Samsung SCX 4521F All-In-One Laser Printer
HP P2015dn printer jam light stays amber.......did the engine test and it will print lines.....did the cold reset still will not top expertsfix
Hello sir;
check very carefully all the senser through the paper path, all the senser have to be moving freely, final go to check the senser board.
Oct 21, 2009 | HP LaserJet P2015dn Printer
Printer says,"paper out put slot, paper is jammed" there is no paper jam, paper will not load properly.
Hello sir; Check the paper exit area there have paper exit senser ,check the senser is on right possition.
Sep 26, 2009 | Canon Office Equipment & Supplies
Papar jam
Hello sir; Wherever you clean up the paper jam, right over there have a paper senser ,check that senser is moving freely or out of track, just put it back to right possition.
Sep 25, 2009 | Sharp Office Equipment & Supplies
Has no paper in it but saids it has a paper
Hello sir;
suggest you go through the paper path checkall the senser see which senser come off or have paper chip stuck any where.
Jun 23, 2009 | Office Equipment & Supplies
COPIER WONT COPY AS LITE INDICATES PAPER JAM DON'T SEE ANY PAPER AT ALL
Hello sir; Go back to wherever you pull out the paper, because you pull the paper in opposite direction therefor pull off the senser,go back where the paper jam put the senser back in right position.
May 30, 2009 | Sharp AL-1655CS Copier
Jam problem
Well, the issue seems to be with Printer carriage stall or it could be an issue with Paper feed rollers or with Communication issue between Computer and Printer.
Please open below web link and try the steps that are mentioned in the web page.
http://tinyurl.com/3xyaq9
I hope that this should resolve the issue for you.
Bye.
Oct 15, 2007 | HP PhotoSmart C4180 All-in-One Color...
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
76 people viewed this question
old marine
old marine
