WHEN I TRY TO INSTALL BELKIN G ROUTER TO MY TOSHIBA LAPTOP I KEEP GETTING ERROR 815 CAN YOU HELP PLEASE.
  • 86 Answers
Error 815 means that your ISP server is not responding. The probable causes are that you have not set up your connection properly - correct username and password, check with ISP support for connectivity problems
Posted on May 05, 2008
Hi I have just installed a brand new Belkin wireless router and it works great with all computers and laptops in the family (including Apple products) apart from my daughters laptop...she has a toshiba...
Check the main computer you set up the network router with...you may need to go to the network status and tasks in control panel...click on this...then you will see a map of all the network devices connected...find the belkin router and click on it...in this window there should be a tab called wireless properties..click this...the wireless properties first page should have the wireless SSID name listed here...and if you click the security tab then the security type and network key are displayed here..You need to write down the SSID, security type, and network key and make sdure the toshiba laptop setting for the wireless network are exactly the same. There may be a link on the first page of the wireless securities saying copy to usb drive..you can use this to copy all network settings to and then transfer these settings in to the toshiba by using the network setup wizard.
Jan 04, 2011 | Belkin (F5D8231-4) Wireless Router...
Internet keeps getting disconnected.Computer needs rto restart
there is nothing to do with adapter... you need to check with some other laptop to isolate where is the issue...
if your laptop works fine without dropping connection then get a replacement for your belkin adapter...
if your laptop also looses connection, then you need to check your wireless router...
Jul 24, 2010 | Belkin (F5D8231-4) Wireless Router...
Belkin f5d 7230-4 How can Change Password for Homepage Login?
As you are unable to access the web interface of the device your only option is to perform a factory reset of the router using the reset switch built into it as per link below:-
http://en-us-support.belkin.com/app/answers/detail/a_id/48/kw/password%20f5d/r_id/166
Nov 29, 2009 | Gateway Belkin F5D7230-4 802.11g Wireless...
Download problems with my belkin fsd92304 wireless router
This is because you have too many firewalls installed one on router one on computer
open belkin setup page by typing in 192.168.2.1
on the left hand side you"ll firewall
click on it turn it off click save
remember to keep firewall on computer
If still this does not help download firmware from site www.belkin.com/support
and please let me know
Feb 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Unable to link a wifi enabled laptop to my wired pc and modem
Make sure that the wifi switch is on in the laptop. Look for a sliding switch in the front or side panel of the laptop. Make sure that it is on.
Hope this helps!
Nov 23, 2008 | Computers & Internet
My Belkin Bluetooth USB Adapter is asking for PIN number?
The default pin numbers are 0000 (zeros) or 1234.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 22, 2008 | Belkin (F5D5231-4) Router
Thompson ST Router
try this link, i tmay not be the same but it should help
http://www.youtube.com/watch?v=GJbtE7ZlWVo
Oct 15, 2008 | Thomson Computers & Internet
I have tried to install router strait from modem to router to toshiba l30 laptop belkin shows up on laptop showing excellent signal but when i try to go on web it cannot make contact
access your routers administration by right clicking your network icon and using your gateway IP to access http://*gateway*
un - admin pw - (none), admin, public
look at your status in the belkin administration settings and see if you have an ip and gateway for your ISP.  The ip and gatway on your computer is for your belkin.
Try directly connecting the laptop to the router with a cable and see if it's on the net. If it is then you have wireless settings wrong. See belkin.com for more infor about router.
James Mac
Aug 02, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Problem - Errors on Startup
The process erroring out has to do with the Toshiba wireless settings. http://www.liutilities.com/products/wintaskspro/processlibrary/cfsserv/ "cfsserv.exe is a process belonging to Toshiba's ConfigFree utility and searches for Wireless Devices. This program is a non-essential process, but should not be terminated unless suspected to be causing problems." I would attempt to completely un-install this utility and then re-install it. After re-installing this utility, make sure the wireless setting on your Toshiba and your wireless router match exactly. If you have trouble using the Toshiba utiliy, you can always try the built in Window utility (that is if you have Windows XP Service Pack 2 installed).
Sep 29, 2006 | Toshiba Satellite A55-S1063 Notebook
Computers & Internet Logo
David Payne
David Payne
