Question about Samsung OKIDATA - OKI C5200n - Printer
C5200 light stripe down paper when printing in black. Toner and drums all adequate. Assume this is a cleaning issue but don't know where/how to clean?
  • 2072 Answers
SOURCE: Sharp AL-1641CS printer/copier
Most likely you had a toner cartridge failuer leaving some of the ink and developer in the crevices above the paper feeder and its just trickling onto the paper.
It pretty much needs to have the cartrides taken out and thouroghly vaccumed.
Just takes patience and time to get it all removed.
Dont vacuum the cartridges, but the inside of the machine.
Pull your paper tray out and see if there is toner and developer trickling into it.
Posted on Jan 11, 2008
Viriiguy
  • 77 Answers
SOURCE: paper jam on initial feed
It sounds to me like your pickup rollers are worn. You should order a new set and replace them. That should solve your paper jam issue.
Posted on Feb 15, 2009
SOURCE: faded stripe down the printed page
I found a solution that worked to eliminate the faded black stripe down the page thanks to a post by slamfix in another forum. The problem is related to ink build up on the blade edge of the black developer assembly in the imaging unit (the imaging unit contains 4 separate developers - yellow, blue, magenta, and black). The solution involves taking out the imaging unit, removing and cleaning the blade edge of the black ink developer until smooth. It took me about 15 minutes to complete and was fairly straightforward.
Detailed instructions with pictures can be found at http://losingambition.com/clp300imagefix/
Posted on May 02, 2009
  • 14 Answers
SOURCE: printed pages have a light shade of toner left on the paper.
If there is still some kind of residue on the paper. Take the toner cartage and shake it evenly so that the toner inside is not all lumped to one side. Run the drum cleaner on the printer again and if you are still having problems it may be something else. Inspect the drum which should be smooth and not have any blemishes or scratch marks (alot of cartages are refurbished and may not be perfect). Also check your allignment of the toner cartrage inside the printer, if its a little off you may have problems.
Posted on Jun 26, 2009
  • 5 Answers
SOURCE: CLP-500 vertical streaks & a horizontal line with blotches appearing randomly
I've refilled the toner cartridges a few times now and never had a problem with vertical streaks until recently. I refilled both the cyan and magenta and when I ran the test page I had dark vertical streaks on both sides. I fiddled around cleaning things, running cleaning paper through, changing reset resistors but to no avail so eventually decided to buy a replacement refurbished cyan cartridge since the streaks looked mainly blue and bingo... well almost now I just have very light magenta streaks. The issue is obvious when I compared the old and new cartridge, the replacement toner is a much duller cyan and is of the wrong consistency since once it's been in the printer everything gets covered in it which is why I think it causes the banding to occur. I'm just trying to work out now whether to try refilling the magenta again (v. messy) or just go for another refurbished cartridge (£34).
Posted on Aug 12, 2009
HP color laserjet CP 1510 printing stripes on the left
Is this for all colors or just one color? There are three color toner cartridges plus a black cartridge.
Mar 09, 2015 | HP CC378A Color LaserJet CP1518ni...
I'm getting a line that isn't printing through my printing from a Fuji Xerox DocuPrint C3055 DX
Possible reasons are: 1.empty toner cartridge, 2.dirt under one of the toner cartridge's developing roller, 3. dirt on the primary charge roller in the drum cartridge, 4. obstacle on the laser path.
Replace the empty toners first and try printing again. Follow the next steps if it didn't solve the problem.
Print a test page with 4 stripes across the page - black, cyan, yellow and magenta. See if all have the missing toner line or only one of them. If the white stripe is going trough only one color, inspect the cartridge with that color. It has to have the same stripe on the developing roller. See if there is some dust beneath it that makes the stripe and clean it with a brush. If the stripe is across all colors, then inspect the drum unit. The drum itself has to be evenly shining on the light. If there are uneven matte tracks on it, consider replacing. There should be a gap somewhere for the laser beam to pass and the drum is visible trough it. Look trough it for obstacles like piece of paper or hair. The primary charge roller has to be close to that gap inside, touching the drum. Look for dirt on it. Clean if possible.
Toner cartridges last approx. 6500 pages. The drum cartridge lasts between 14 000 and 28 000 pages depending on the color use.
Jul 02, 2014 | Digital Products Office Equipment &...
I have an HP3500 which I've had from new since 2004. On the whole it's been remarkably reliable but recently I have problems with a multicoloured stripe which appears down the lefthand side. It...
Hi Richard,
Dots, Lines and smudges on the printouts are usually due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and inspect them. You may observe the lines on the green drum. Gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer are clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Observing the PCR with the help of a sharp torch light would let you assess the condition of the PCRs at the corresponding location where lines are appearing. Replace the Cartridges one by one and inspect the prints for the changes. I think you would be able to identify the faulty cartridge/ rollers. Also, if the waste toner area is filled and/or the plastic wiper/ cleaning blade removes the leftover toner/ waste from the drum and holds the waste is worn out, it results in spilled toner usually at edges and at early stages lines only.
Moreover, the function of the fuser is to fuse the toner onto the paper and it is usually done at the end of the printing process just before the paper is ejected (and the image/ toner on the paper is just fused - not changed). The fault at the fuser area usually results in smudges, ghosted image or unbind toner (which easily gets erased when touched). The time during the printing cycle when the toner is spread on the paper, additional toner (resulting in lines) is shifted to the paper due to cartridge related issues, which results in lines. Note that after cleaning the rollers, the print quality improves and the lines disappear or lighten. Try and check if the above suggestions work.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 16, 2011 | Office Equipment & Supplies
There is black 1" stripe down middle of page. I
The drum is defective, and leaking, Brother warranties if you are original purchaser (in canada, www.brother.ca)
Dec 10, 2010 | Brother HL-2070N Laser Printer
BLACK STRIP ON THE LEFT SIDE ON MY PAPER??? I HAVE A HP LASERJET 1022NW....WE HAVE CLEANED AND BLEW OUT THE PRINTER....STILL NO IMPROVEMENT....WHAT TO DO NEXT....
Run the 1/2 print test.
Put paper in the manual feed tray. Print a few pages of anything. As the paper gets about 3/4 of the way into the printer, open the cartridge door. Pull out the cartridge and look down at the paper. If it has the black stripe on the left side, replace the toner. In fact at this point, pick up the toner cartridge and gently swing the shutter open and look at the drum. You should be able to see a black stripe on it.
By the way, the toner hasn't been fused to the paper at this point. It will rub off on hands and clothes.
If the 1/2 test shows no stripe on the paper...replace the fuser.
Dec 01, 2010 | HP Office Equipment & Supplies
Light print on side of paper. color black copies, print, internal
Ninty-five percent of all image issues like this are caused by the carona-drum-toner assembly. I have not worked on this model but the only way to diagnose the issue is to try a new drum / toner cartridge and see what impact it has. Then once you resolve the issue you can discuss the service life after the fact.
May 12, 2010 | Brother MFC-9440CN Laser Printer
There is a white stripe (miising writing) in the middle and in the left side of the printed paper. i have changed the toner, but the problem doesnt solve. maybe its the laser motor dirty? thnx for any help
Problem : white stripe (missing writing) in the middle and in the left side of the printed paper
Printer Laser Printer MF5650
Cause of the problem Dust
Solution Cleaning ..
There could be reasons for your problem
1) The TONER CARTRIDGE not clean - i think you replaced it
2) The Imaging Drum
3) Beam Alignment Lance (glass which reflect the rays)
1) there are toner and the drum
2) take out the Toner cartridge
3) there is a black roller on Toner Unit - clean it with the Cotton
4) Take out the Drum clean it (Don not use water or spirit to clean it )
5) Fuser Unit a Hot Unit the Red Color Roller no need to clean ..
Following Video will show you the over view of the Product
Video 1 use full video help you to understand the whole process
Jan 03, 2010 | Canon LaserBase MF5650 All-In-One Printer
Light lines down middle when printing black
try to clean the class of the machine, if its still there, this means the black drum is scratched since its fine with other colors, to test it very good open the document feeder(put it up) and hit start buttom(without putting anypaper on class), black paper will come out, check if the line there, if yeah, change the black drum.
let me know wat happen Regards
Apr 24, 2009 | Samsung CLX 3160fn All-In-One Printer
OKI C5200
Just a thought for others... is this an image drum problem?
Also, if you haven't done this yet - try gently shaking the toner cartridges to redistribute the toner. Just make sure you do it gently and over a newspaper or rugs in case some toner spills. One last idea - turn off the printer and turn back on after a few minutes?
Jan 02, 2008 | OKI C5200n Laser Printer
Samsung OKIDATA - OKI C5200n - Printer Logo
48 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
