Question about Mitel 5220 IP Phone
HOW MANY CALLS PER MINUTE YOU CAN GET ON MITEL
    Sergeant:
  • 378 Answers
It really depends on how many trunks you have, how many people you have and how efficient they are. It also depends on the system you have, not necessarily the phone the users are using.
You should contact your vendor for helping set up the most efficient method of setting up call handling.
Posted on May 01, 2011
Random Calls from Nobody "trunk 30 calls"
This might be due to fact of Trasnferring calls. I assume that you have at least 30 numbers to your hotel, meaning that you at least have 30 trunks. When you transfer a call, and if there is no answer at where it is transferred, it will ring on your side, but will not let you answer the call. It is a notification pretty much that there is a call in waiting.
To solve this, simply untransfer your cals for that trunk and it will be okay, I hoep that fixes it.
If you need help with untransferring, here:
1. Press Function Key
2. Enter ATT Function which is F2 on our own
3. Press Trunks which is F5 on ours
4.Enter 30 for (trunk 30)
5. Press ATT Access which is F3 for ours and wait for dial tone
6. Dial *730 and then hang up after the fast beep.
Depending on the system and distributor, ti might vary slightly.
Jan 16, 2013 | Mitel Superconsole 1000
I am configuring a pri ckt in mitel sx200icp i cannot make outbound calls i have programmed pri card as per carrier in form 42 with NI2 - NI2bell have tried all procol variant incoming is fine
It sounds like the outbound Caller ID is not set up properly in form 22. You will need to insert *6 into the dial string. If this isn't set up, many carriers will reject the call as it doesn't see the correct outbound caller ID.
Sincerely,
Mark
Mar 16, 2011 | Mitel PRI Card T1 E1 (9109615001)
Disable external calls on mitel 3300
This is a function your phone vendor will need to complete for you specifically they will need to setup a Class of Restriction for the set that you would like to block from using your outbound trunks.
Nov 25, 2009 | Mitel 5212 IP Phone
I want to block outgoing external calls
Need to program class of Restriction in the phone system. And give COR to that phone.
Apr 16, 2009 | Mitel Superset 4025 Corded Phone...
Mitel SX-200 D PBX generic 1003 ACD- doesn't support ISDN.
You are not going to get the ANI information you need from the current configuration, the only way to get that information is thru the use of PRI.
Apr 08, 2009 | Mitel 9109-021-000 T1 Trunk Card (24...
We have a mitel 3300 connected to cisco CM thru siptrunk
can somebody help me we have a Sip connection between a mitel 3300 and Cisco callmanager only the conference call doesn't work who can help me out
Apr 02, 2009 | Mitel 5212 IP Phone
Want to divert calls from a Mitel Superset 4025.
Under the Blue Superkey, you can find a Call Forward prompt, enter the extension that you want to transfer your calls to and enable it.
To shut the call forwarding off, go back into the Blue Superkey and in Call Forwarding,t here is a disable call fording option
Mar 04, 2009 | Mitel Superset 4025 Corded Phone...
Mitel 5220 IP Phone Logo
Top Mitel Computers & Internet Experts
Martin Murray
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
