Question about Saeco Vienna Espresso Machine
The grinder spins but no beans get grided. sometimes if i push them down it will work for a while.
  • Saeco Master
  • 1,711 Answers
Remove all beans from grinder and with the remain beans adjust the grinder to more gross grinding and the make 3 to 4 coffees.
Then Use a vacum cleaner and absorve as much from the grinder. Wash also the Beans hopper with soap and hot water so all oil remianing go away. Dry it very well and put back in place.
Now add new add some new beans and try to make an espresso and when the grinder spins then rotate back to the original grinding position. Remeber that you must go back to fine one step at a time not at once since this will blocked the grinder blades with grounded coffe and grinder will not rotate.
You should to this often is you use oily dark roated beans beans. I sugest to find also a better quality beans which are more light color thus less oily.
Posted on Aug 25, 2010
Two weeks ago I paid > $100 for a full service (Saeco Magic Deluxe) and now the machine won't grind the coffee beans. Any suggestions so I can be a bit "knowledgable" if I need to take it...
Hi
If the grinder is spinning your grind set is too fine. Push the lever below the bean hopper to the back. It can go to a coarser setting anytime but the grinder has to be spinning to make it finer. They may not have set the grinder correctly. Have them walk you through the process. It also takes about 2 to 3 times before the grinder fills to work.
Apr 13, 2011 | Saeco Magic De Luxe Espresso Machine
Jura F70 Grinder stopped working
The switch or photo sensor is not sensing any beans present.
So it can't continue
Use torch to inspect bean entry area
Small brush etc
Apr 18, 2010 | Jura Capresso Coffee Makers & Espresso...
Jura E8 beans will not pass through grinder resulting in "Fill Beans" error message. Saw reference to Kaffeestudio.com for dissasembly instructions but that link no longer works. I assume that the chute...
It seems withthis model you have a 1 year or 4000 cups warranty with this.
If you are within this, then give them a call - here is the Manual if you don't have it -
MANUAL -
I suggest you start by removing the beans in the hopper and wiping around to remove oils.
Then refill with fresh dry beans.
Plug in and set up as normal
Set to brew a standard large cup - and adjust grinder to coarse setting while grinding.
Do not adjust with grinder quiet - it must be done while rotating.
Make at least 10 cups this way at the coarse setting.
I think what has happened is that damp beans (frozen or cold) have entered the unit and caused the coffee to gum up at the top of the burr.
This will just push fresh beans out of the way instead of starting to grind them.
If you use dry (light loast) beans, it doesn't seem to happen as much.
Just ake sure you refrigerate most of your stocks, but keep a small stock at room temperature in an airtight tin to prevent this kind of thing.
You can actually push down on the bean stack slightly with a wooden object while the grinder is running if nothing moves on the coarse setting to get things moving.
Feb 10, 2010 | Microwave Ovens
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
Spinning but not grinding
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Dec 08, 2008 | Cuisinart Supreme Grind CCM-16PC Grinder
Gaggia Trevi or Spidem Trevi
You may have a legitimate mechanical malfunciton but sometimes the simple solution is the right one! The chute on this (and other) superautomatic does not like the oily residue that beans inevitably leave. All it takes it gently putting one or two fingers into the bean hopper as the grinder motor starts to sound louder/faster (this is caused by the grinder motor being under less load/strain because no beans are feeding) and wiggling for 1-2 seconds. If you do this immediately after hearing the grinder motor's rpms increase you will not get a "fill bean hopper" error message2.gif. No hard pushing is required, just a gentle wiggle. There is a shroud over the actual bottom of the hopper, so you don't want to stick your fingers beyond that. If you are concerned about actually sticking your fingers into the hopper while the grinder is running, you can simply push down on the top of the beans with gentle pressure which will in effect force the beans down and accomplish the same thing. This technique + regular cleaning of the grinder may be all you need. Hope this helps! Tony
Jan 02, 2008 | Spidem Trevi Anthracite Espresso Machine
Incanto de Luxe always tells me there are no beans in container
I do have the same problem.
I have removed and cleaned the grinder mechanism.
Being an electronic technician I did have a look and tried to find what method they use to detect that the new beans reservoir is empty and I did not see any kind of detector.
I suspect that they monitor the motor current to do this. If it is so would'n it be possible to desable this fonction since it is more then evident when the reservoir is empty or about to be?
Any body knows how they do monitor the status of the new beans reservoir?
Dec 18, 2007 | Saeco Incanto Classic Espresso Machine
Gaggia Titaminu
check to make sure the blades are secured to the motor shaft. some have a set screw, some are positioned over a pin in the motor shaft.
Sep 10, 2007 | Gaggia Titanium Espresso Machine
Saeco Vienna Espresso Machine Logo
234 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
