Question about Kenmore Washing Machines
No hot (or warm) water is coming into my Kenmore washing machine - can only wash clothes in cold water. No problem with hot water anywhere else in the house.
  • 92 Answers
There must be leakage of the hot water pipe or it can be broken or misplaced
Posted on Aug 25, 2010
Cold water comes out very slowly whereas hot or warm is normal
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 27, 2010 | Kenmore 12502 Top Load Washer
No warm or hot water
The easiest possibility is no hot water coming from supply,I have seen the valve turned off,input hose normaly has a filter where it attatches to the machine and they can get clogged.If neither of these solves problem just try hot valve to confirm water supply does work and if so more than likely the valve that hoses are connected to likely source of problem.
Apr 20, 2009 | Kenmore Washing Machines
1994 Kenmore 90 series washer smells musty
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
Mar 30, 2009 | Kenmore Washing Machines
Water not hot on hot temperature setting
BS ....on the back inside the washer are two solenoid operated valves that control the hot and cold water flow. your hot valve has ceased to function...and needs replacement.  also make sure your hot water valve is open fully and that the screen inside it isn't clogged.
Mar 29, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Feb 23, 2009 | Kenmore 46462 Front Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
ZANUSSI ZWD162701 washing always comes out cold - WHY?
Washers are meant to rinse in cold water, so clothes should come out cold.
If you are not sure if it is getting hot, then select a very hot wash, and feel the door glass periodically, it should gradually get hotter, if it does not , then it is washing in cold water only.
This could mean that the heater element has gone.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Zanussi ZWD1270 Front Load Washer / Dryer
Should the washer be hot after the rinse cycle?
Try cycling a cold/cold wash and see how that comes out.. if it comes out hot then your water inlet valve is letting hot water in when it shouldn't.. conversely, try cycling a hot/hot wash and see that it does indeed come out hot... ( quick tests to verify performance)..hope this helps.
Sep 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Whirlpool
Whirlpool
