Question about Microwave Ovens
My microwave shows a H98 error code . Does anyone know what that means ?
  • Anonymous Jun 30, 2008
    my microwave shows H98 and I turned it off and then back on
  • Microwave Ovens Master
  • 9,098 Answers
That would be a Panasonic inverter failure code, but please reply back with your brand and full model number.
Posted on May 09, 2008
Trouble code H98
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Error code H98
Hello
Unplug the microwave and plug it back in after 30 seconds to make sure the message did not appear because of a simple glitch. If it does not come up again, use the microwave as normal.
The "H98" error means that the microwave's inverter has shorted out and does not work any more. The microwave cannot transfer power to create heat, and the part has malfunctions and requires replacement. Use your microwave serial number and customer service to find the proper part for the microwave.
Your microwave comes with a warranty that will cover the inverter if the warranty is still valid. Call the number for the warranty department or bring the microwave, with receipt, back to the store you purchased it from. This will save you the hassle of replacing the par
Oct 04, 2011 | Panasonic NN-SD797S Microwave Oven
H98 ERROR CODE ON A PANASONIC M/W NN-SN797S WHAT DOES THE ERROR CODE MEAN?
H98 means that the magnetron or invertor has failed. The invertor is not user serviceable.
Mar 10, 2011 | Panasonic Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Error Code
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming2.gif circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
Sep 15, 2009 | Panasonic Microwave Ovens
Panasonic Microwave show H98 in window
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Jul 03, 2009 | Panasonic Microwave Ovens
I HAVE MIC. NN-SD997S ,IT DOES NOT WORK ,MESSAGE SAYS "H98" .
This displaying indicates a
problem with the microwave
generation system
This is for your dealer to resolve
Mar 11, 2009 | Panasonic NN-SD997S Microwave Oven
Panasonic Microwave
the error code H98 refers to the heating filament on the magnetron, unless you are confident I would not progress further
Feb 18, 2009 | Microwave Ovens
Microwave Ovens Logo
1,239 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
