Question about HP DeskJet 3740 InkJet Printer
I loaded paper into my printer, but the unit will not print. When checking properties will say the unit is out of paper.
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
MY Epson WF-3520 will not print from the rear paper feed.
Try reloading the drivers for you printer for XP, un-install the windows 7 driver and install xp. check the Epson web site for xp drivers if available.
Apr 06, 2015 | Epson WorkForce Office Equipment &...
Ever time I try to print anything, I get a message saying the printer is out of paper. But it's not out of paper! There is plenty of paper in the tray, which I keep reloading, only to get the same...
Cause
Any of the following issues can cause this issue:
The paper trays are empty or overloaded.
The paper is curled.
The print side, or shiny side, of the paper is not loaded in the tray face down. For photo paper, always load the rougher side of the paper facing up.
The paper is too slick for the product.
The paper might not be engaged with the feed rollers.
The paper-width guide is pressed against the paper stack too tightly.
The paper tray is not completely inserted into the product.
The paper settings in the print driver do not match the paper loaded in the paper tray.
The rubber paper-feed rollers are dusty.
Check the media and print settings
a)While the printer is on, remove the power cord from the back of the printer, wait 30 seconds, and then plug the power cord into the back of the printer.
b)If the printer is not already on, turn it on by pushing the power button.Replace any paper that is ripped, dusty, wrinkled, or bent. If the paper is curled, uncurl the paper by gently bending it in the opposite direction of the curl or replace the paper.
c)Verify that all the paper is the same size and type.
d)Tap the stack of paper on a flat surface to align the edges
e)Verify that the stack of paper to be loaded in the unit contains between 10 and 25 sheets of paper.
f)Insert the stack of paper into the printer and then gently push the paper guides snugly against the paper.
g)Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
1.Open a document in the application in which it was created.
2.Click File
3.Click Print
4.Click Properties . The Printer Properties dialog box displays.
5.Click the Paper/Quality tab.
6.In the Size is drop-down menu, select the size of the paper loaded in the unit.
7.In the Type is drop-down menu, select the type of paper loaded in the unit.
8.click ok.
9.On the Print dialog box, click OK to print the document.
10.Try printing again.
If the issue is not solved, try next steps
1.Turn off the product and unplug the power cord.
2.Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door.
3.Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
4.Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
5.Close the access door and plug in the power cord.
6.Try printing again.
Sep 16, 2010 | HP Officejet 6000 All-In-One InkJet...
"out of paper" error when ther is paper, paper won't feed
Hi ,
Step one: Check the media and print settings
  1. While the printer is on, remove the power cord from the back of the printer, wait 30 seconds, and then plug the power cord into the back of the printer.
  2. If the printer is not already on, turn it on by pushing the power button.
  3. Replace any paper that is ripped, dusty, wrinkled, or bent. If the paper is curled, uncurl the paper by gently bending it in the opposite direction of the curl or replace the paper. NOTE: Use plain paper in the unit until the issue is resolved.
  4. Verify that all the paper is the same size and type.
  5. Tap the stack of paper on a flat surface to align the edges.
  6. Verify that the stack of paper to be loaded in the unit contains between 10 and 25 sheets of paper. NOTE: Do not load too much paper in the printer.
  7. Insert the stack of paper into the printer and then gently push the paper guides snugly against the paper.
  8. Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
    1. Open a document in the application in which it was created.
    2. Click File .
    3. Click Print .
    4. Click Properties . The Printer Properties dialog box displays.
    5. Click the Paper/Quality tab.
    6. In the Size is drop-down menu, select the size of the paper loaded in the unit.
    7. In the Type is drop-down menu, select the type of paper loaded in the unit.
    8. Click OK .
    NOTE: These changes do not change the default print settings. The print settings will revert to the default print settings the next time the application is opened.
  9. On the Print dialog box, click OK to print the document.
  10. Try printing again. If the issue is not solved, continue on to the next section.
NOTE: If the issue is resolved and you want to print on another type of media, change the paper in the unit and then repeat steps 2 through 7 for the new media. Step two: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water. NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
  7. Step three: Service the product If you have completed all the steps and are still experiencing a problem, service your product.
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the tray face down. For photo paper, always load the rougher side of the paper facing up.
  • The paper is too slick for the product.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are dusty.
Hope this would be helpful ....all the best
Mar 18, 2010 | HP Officejet J5780 All-In-One InkJet...
A printer error comes up that the printer is out of paper, when in fact there is lots of paper and you can use the copyier mode. What is the problem?
While the printer is on, remove the power cord from the back of the printer. Wait 30 seconds and plug the power cord into the back of the printer. If the printer is not already on, turn it on by pressing the (c01114458.gif ) button. Replace any paper that is ripped, dusty, wrinkled, or bent. If the paper is curled, uncurl the paper by gently bending it in the opposite direction of the curl or replace the paper.Make sure that all the papers are the same size and type. Tap the stack of paper on a flat surface to align the edges.Make sure that the stack of paper to be loaded in the unit contains from 10 to 25 sheets of paper.Insert the stack of paper into the printer and then gently push the paper-width guide snugly against the paper.
Open a document in the program in which it was created.
  1. Click File .
  2. Click Print .
  3. Click Properties to open the Properties dialog box.
  4. Click the Features tab.
  5. In the Resizing Options area, from the Size drop-down list, select More .
  6. Select the size of paper loaded in the unit and then click OK .
  7. In the Basic Options area, from the Paper Type drop-down list, select More .
  8. Select the type of paper that you have loaded, and then click OK .Click OK to close the Properties dialog box.
Click Print or OK to begin printing.
Step 2:
  1. Turn off the unit and unplug the power cord.
  2. Press in the tabs on the left and right side of the two-sided printing accessory. Remove the accessory by pulling it away from the printer
  3. Gently pull the paper out of the rollers.
  4. Clean the rollers with a lint-free cloth lightly moistened with wate
  5. Close the Two-sided printing accessory cover until it locks into place.
  6. Try printing again. If the issue is not solved, continue on to the next section.
  7. If this does not work need to service the printer ........
Jan 26, 2010 | HP LaserJet 3330 All-In-One Printer
Load A4
A4 is for european size, if you are printing on a letter size this is a mismatched.
you need to change your files printer properties to A4 or letter size, or change your printer paper size.
better yet cancel this document and send it again , this time by checking the printer properties was set to your desired paper size
Jul 28, 2009 | HP LaserJet 2840 Printer
How do I realign my hp photosmart c4480 printer?
To align the print cartridges from the HP Photosmart Software
1. Load letter or A4 unused plain white paper into the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
2. In the HP Solution Center, click Settings.
3. In the Print Settings area, click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
4. Click the Device Services tab.
5. Click Align the Print Cartridges.
When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The product prints a print cartridge alignment sheet.
7. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Have installed new printer a message pops up saying the printer is out of paper even though there is plenty of paper in tray.
Hey buddy,
Follow the below steps:
Step one:
Click File .
Click Print .
Click OK .
Cause of this problem:
Any of the following issues can cause the error message to appear:
The print side, or shiny side, of the paper is not loaded in the input tray face down.
The rubber paper-feed rollers are coated with dust.
Sep 22, 2008 | HP Computers & Internet
8250 hp printer
  1. Open a document in the program in which it was created.
  2. Click File .
  3. Click Print .
  8. Click OK .
hp website
Jan 29, 2008 | HP Photosmart 8250 InkJet Printer
Lexmark t630
Paper size is incorrectly set!.....
Merlin's idea, of what paper Lex has, and Lex's are different or you have loaded Lex's tray with the paper sideways
Your in Oz so it would be A4 standard and I guess your trying to print B5 script. Try these
The printer has been loaded with one size paper but thinks it is another. change printer settings via keypad on printer
The B5 scripts paper is being loaded sideways instead of length ways or visa verse
There is a incorrect setting in the printer driver that is set up for this specific printer that 'merlin' uses, check print driver setting (control panel,printers and fax, right click on lexmarkt642's icon, properties and check properties fully) in windows software that is running under merlin, also check merlin settings if any for this printer
Nov 20, 2007 | Lexmark T642 Laser Printer
HP DeskJet 3740 InkJet Printer Logo
Seeker5211
Seeker5211
