Question about Samsung Digimax D53 Digital Camera
Zooming problems camera will not zoom. it only zooms for a little and the i turns off
    Problem Solver:
  • 10 Answers
Have you tried to put new batteries in use ni-hm batterys it will help
Posted on May 10, 2008
Nikon coolpix lens zooms out by itself and repeats if i try to zoom back in
if u look at the bottom of the screen or something, u will usually see a thing that shows how much u zoomed in or out. if u wait for the thing to disappear off the screen, it should not zoom back out or in when u do it. if that doesnt work then i cant help u.
Aug 01, 2014 | Nikon COOLPIX Cameras
Zoom did not operate normally,insert the battery again and turn camera on again Camera doesn't operate normally
Hi had this problem with my WB100. Zoom would come out then pop back in and say zoom nit not operate normally, please put new batteries in and try again or contact bla bla. What i did when the zoom popped out is i held onto it and didnt let it retract back and turned it back on. It worked after that so i guess the zoom must of been a little forced in when it was in use last in when turned on it wasnt fully going forward. Worked for me so worth a shot
May 27, 2011 | Samsung PL120 Digital Camera
My camera Cybershot DSC-W150 has a problem with zoom
Sounds like your lens might be stuck. Do not force it closed or pull it out for that might further damage parts that are an integral part of its sliding mechanism. http://www.teleplancamerarepair.com/Sony_Cyber-Shot_DSC-W150 can repair this for you and they also clean your camera as part of the repair.
if there were any parts you were not able to put together after you opened it , make sure to very carefully put those back to go along with your camera.
Jul 08, 2010 | Sony Cameras
The zoom won't work on my Canon A460
Your zoom may be turned off, here is how you can turn it back on:
When you are about to take a picture, press the little menu button, then press down until it says digital zoom, if the little black box is over-top of 'off' change it to say 'on'.
Hope this helps.....and makes sense.
Dec 30, 2008 | Canon PowerShot A460 Digital Camera
18-55mm lens won't zoom
I fix it!
This problem is due to bad design (I think)
The problem is cause of the guards/holder/stand bends a little the you turn the zoom.
I bend the guards just a little to the left.
This get the guards to stand straight then you "zooming".
Perhaps a little grease can help too, but what kind do you use inside a kamera?
Jul 09, 2008 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Zoom
My zoom problem was a combination of the software and hardware when it came to the neutral position for the zoom slider. When the camera is first turned on, if the physical zoom slider (hardware) is in the neutral position (you are not touching it) the camera software does nothing, but if you are pushing the physical zoom slider when you turn on the camera, the software resets the "zero zoom" position into memory. The solution to my problem was to push and hold the physical zoom slider towards the wide position and the software realize reset the "zero zoom" neutral position. This may take a few tries to get it right (if you over compensate, do the opposite and push the slider towards "T" when you turn it on), but I hope this will solve your problem and save you a few bucks.
Ryan
Jul 04, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Won't focus when zooming into the subject
It seems that the lense element which mooves while zooming the camera is stucked. normally this happens when the camera suffers a heavy jery, may be by dropping the camera. Resulting into disalingment of the lense assambly. You will need the help of repair shop to solve the problem.
Sep 15, 2006 | Olympus Camedia C-765 Digital Camera
Digital zoom not working
Digital zoom is in the menu and must be turned on to activate it. When you use the zoom it takes 2 opperations to function. First opperation is to zoom all the way in then the camera should stop. This is the limit of the optical zoom. Then you let off the zoom button, and hit it again and then the digital zoom will start. Digital zoom is just a gimic if you learn how it works its not doing anything different then you can do in photoshop. All digital zoom is doing is like cropping.
Apr 24, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Samsung Digimax D53 Digital Camera Logo
24 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
