Question about Linksys Wireless-G Broadband Router
Hii i have a linksys2.4G broad band router .it
Hii i have a linksys2.4G broad band router .it was not working since 2days .i m not able to open the linksys default page , whn i connected cabel directly to LAN port it showing continously searching however my t wireless router also not detected through my laptop.so kindly provide the solution .how to escape this problem. i m waitng for yr reply.
    Guru:
  • 773 Answers
On the back of the router there is a recessed reset button. You need something small like a paper clip to push it. Push and hold it for 15 seconds. This will completely reset the router to factory settings.<br /><br />You will need to use the default password that came with the router to get in. It should be Admin, but refer to the manual for that. You can find it on the linsys website if you don't have yours.<br /><br />When you plug your computer directly into it, you should go to 192.168.10.1 to access the router.<br /><br />You will have to set up all your settings again.<br /><br />If by chance the default network ID was changed, and the reset did not effect it.<br /><br />Basically the fist 3 sets of numbers in the IP address is called the network ID.<br /><br />Plug your computer into the router and start it. When its up got to run, and type CMD and hit enter<br /><br />Then once the command prompt comes up type ipconfig and hit enter<br /><br />Find the line that says IP address. Take the first 3 sets of numbers from your IP address and type them into a browser, and make the last number 1 and it will access the router.<br /><br />
Posted on Aug 25, 2010
How kan use broad band inter net with window XP on acer loptop
You must instal the software that will enable XP to "talk" to your router and then you can instal the codes for use.
Dec 05, 2013 | Acer Aspire Computers & Internet
How can i connect the router? i got a intellinet 192.168.1.1 there is one wan and 4 ports are there.i have dialog broad band connection.how can i connect it?or iwant to install any software?
This is very easy to do and you should have no problems doing this. The first step to installing it connecting your router to your broad band router through the wan port. All you do it take your Ethernet cable that went from your broad band router to your computer and attach it to your new routers WAN port. next wile your new router is turned off, turn off your broad band router and then turn it back on wile it is booting up turn on your new router this is not always necessary but it will make sure that they sink together properly. And that's it your done just hook up all of your other computers to the remaining ports and they should work with out a problem.
PS. this is just the basics of setting up your router if it has wireless you may want to think about implementing some security measures such as encryption.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Intellinet Active Networking Intellinet...
This network requires a network key.
You will need to check the settings of the router.
Is there any computer connected to the router ?
If not then connect the computer to the router and open the set up page of the router. On the set up page you will find the wireless section.
Click Here to know how to open the set up page and check the wireless settings
Nov 22, 2009 | Belkin (F5D7230-4) Router (587009)
I got the linksys router problem which no problem at all when i connected to sg broad band . currently use it to connect to malaysia streamys broad band and problem occured. when i connect the router to...
For that you enter in linksys configuration page with 192.68.1.1
then enable dhcp .
Aso set WAN settings as your internet service provider settings.
For that you have to set DNS server and other settings as your malaysia streamys broad band settings.
Let me know if you need further assistance.
Thanks.
Oct 28, 2009 | Linksys Wireless-G Broadband Router
The wireless cannot acquire a network address
is your router broad band and do you have install the cd that comes with if so unplug the modem and the router out of the outlet restart pc and plug the router andthe modem back in the outlet see if it works
Aug 05, 2009 | Linksys Wireless-G WRT54G Router
Linksys router model WRT54GX2 SRX200 drops wireless connection on the laptop and the ethernet connection on the desktop. Connection drops for seconds then reconnects in seconds. By-passing the router and...
read on the router if its broad band , if is not , you will not be able to use it , so my advice to you is get aother linksys router with broad band on it .wish you all the best
Aug 04, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
I can't connect internent after resetting modem
you need to re-enter the username and password for the broadband connection. Log in to the router and go through the connection wizard, but you MUST have the name and password that you were given by the provider.
May 26, 2009 | Computers & Internet
Linksys wirless G 2.4 broad band router download driver
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Feb 10, 2009 | Linksys Wireless-G WRT54G Router
Msn sites are not opening
Disconnect your firewall or antivirus firewall to get access to msn.
Sep 28, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Online
Hi GameGirl31,
In order for you to go on-line with the PS3, you will first need either broad band or DSL Internet connection. Once you have that, all you will need to buy then is a wireless router. You will need to hookup the wireless router to your broad band or DSL modem. Once you have done this, you have two option on how to get on-line. You can hard-wire your PS3 to the wireless modem or you can use the blue tooth wireless net-card that is already built into your PS3 to go on-line.
Sincerely,
Agent Xiong
Apr 06, 2008 | Sony Playstation 3 (PS3) Console
Linksys Wireless-G Broadband Router Logo
51 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
