Question about InFocus IN72 Multimedia Projector
Dear support. My system has worked fine for 12 months but occasionally I get a series of vertical lines down the left half of the screen. After a lot of plugging in and out for no apparent reason it then works again. Then last night no picture except the INfocus main screen but no picture from any device. It sounds like it could be the 10m HDMi cable I have. Any thoughts mike
  • vikki389 Aug 25, 2010
    Thankyou but I am not using a laptop and the system has been fine for 12 months. I do use a multi function remote that at times gets itself confused and may switch projector on second. Is it important it goes on first even with blu Ray and media box. Not using with PC or laptop Ty
    Ty but perhaps I am not clear I am using a complicated programmable remote with self repair it remains in a charge bay when not in use. I am thinking it's self repair may have created a situation where projector is not first component to come on. What do you think
  • 3,083 Answers
A cable can always be bad, true. The best way to check that is to get another one, of course. I agree with you, since it makes sense...horizontal lines from intermittency, then it connected and worked, and then it didn't. If you can bend the wires at the broken point in the cable (usually near the plugs), you might be able to cut the bad wiring out and jury-rig a fix, if for no other reason than pinpointing the problem. I have fixed bad power supply cords, and a few headphone wires, but sometimes it's tricky since they're thin and coated with lacquer, to keep them from shorting out.
It's possible that you have a bad component in the power circuit, also, so try to check that out in case the cable doesn't fix it.
Also, I ran across a blog that mentioned someone having a power cord problem, so here's what they said (scroll down a bit to find it):
http://www.woot.com/forums/ViewPost.aspx?PostID=895666&PageIndex=8&ReplyCount=305#post901729
Good luck, hope this helps, and thanks for using FixYa.
Posted on Aug 25, 2010
    Genius:
  • 1,478 Answers
Upon setting up your equipment it is very important that you turn on the projector first. You will see a blank projection image, now turn on the computer, (confirm your cables are connected properly). When using a lap top computer you may need to disable your computer's display screen. First locate the "function" key at the top of your keypad that reads "LCD", "CRT" or it may have an icon that resembles a computer monitor. By pressing the "FN" key and the corresponding "function" key you will be able to obtain the image from the projector only. This is known as "toggling" the image. If the problem still persist, replace the 10m HDMi cable.
Take care.
  • Jimoh Adeleke Muyideen Aug 25, 2010
    Yes, it is important. Weak or dead batteries can cause numerous problems with a remote control.
    To maximize the life of the batteries take them out when the projector is not in
    use. Some projector remotes come with an "on-off" switch for the remote itself
    (not to be confused with the power button for the projector) turn the remote off
    when not in use. You should have a clear line of sight between the remote control
    and the projector's inferred receiver. Any obstructions will interfere with the
    projector's ability to pick up the remote's signal.
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Dell Latitude D505 half of screen is black with colored vertical lines.
Sounds like you have a section of dead pixels. This can happen if the laptop has been dropped a lot or stepped on or some type of impact on the laptop. This is a hardware issue. You will need to have the screen replaced. In my opinion, by the age of the laptop, its better off getting a new one.
Oct 01, 2014 | Dell Latitude D505 Notebook
Two vertical lines on screen
Check its T'Con board and its connections. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1250 posts to different brand TVs now. Pull up older posts there
Nov 22, 2012 | LG Televison & Video
When switched on the screen has a blue background and a series of multi-colured vertical lines in the centre covering approx half the screen. can get o further than this.still has seven months of warranty...
sounds to me like a broken lcd screen. Check if it works on external monitor, if it does the problem is your screen. If it is the same on an external monitor then the fault is with the onboard graphics card. This should be fixed under warranty
Feb 18, 2011 | Acer Aspire One PC Notebook
My 52inch xbr4 tv is 2 years old. Intermitently over past 2 months, when I first turned it on, I get thin vertical lines and double imaging especially over left half of screen. After a few minutes it would...
I have the same issue. Bought the TV 1/08 and it started showing those exact symptoms about 3-4 months ago. It generally progresses and gets worse. You can try to fix it as it's some kind of TAB connector issue, or keep calling Sony so that the 52" owners of the XBR4 and 5 series get the extended warranty just like the 46" owners received for the same series. If enough of us keep calling, they'll have to act.
Jan 18, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
White vertical line
Hi
please clean you machine before you use. it can be a dust inside
Oct 24, 2017 | Optoma EP709 DLP Projector
Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
Horizontal lines obstructing the second half of the ti 83 calculator screen, anyone know repair tips?
I had the same prob with vertical lines on the screen, and getting messed up when there was lots of numbers on the screen.
Solution: Change your batteries. Put some freshies in then adjust your contrast until you see the little black box. If you still have a problem with the lines, darken the screen until it's black (2nd up repeatedly) and let it sit for a couple minutes. Lighten your screen back to normal (2nd down) and turn off then turn her back on.
Jan 17, 2007 | Texas Instruments TI-83 Plus Calculator
Vertical Green/Purple Lines on lower half of screen
I would contact RCA if the repair center dosent know how to troubleshoot this set. But I bet its an eeprom or ground issue. Contact RCA here at 580-634-0151 or At https://www.rca.com/secure/service/contactrca/1,,,00.html Good Luck
Jun 15, 2006 | RCA Scenium HD65W20 65" Rear Projection...
InFocus IN72 Multimedia Projector Logo
64 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
