Question about Lexmark X2500 All-In-One Printer
After installing printer it dealeys the start up
Since installing the printer the computer takes several minutes to find the printer programe.
  • humber63 May 12, 2008
    the os (windows Xp sp3) starts very slowly after the instalation of the lexmark 2500 all in one software.... when i do remove the software all came to normality... why i´ve tried for everything without sucesfull results...
  • Bozzy69 Jun 10, 2008
    I have installed the drivers for my Lexmark printer x1180 but cannot get it to print via usb. Went to mac store and they sad it was installed correctly but still when I print it just sits there waiting for a response from the printer.
    Genius:
  • 1,269 Answers
@humble63
Try to install just the printer driver and not the printer utility. You can do it on Device Manager or Control Panel > Printers and Faxes > Add Printer wizard
Posted on Jul 26, 2008
Alignment problem
  • Turn on your inkjet printer and select the "Printer Assistant" program from your computer.
  • Choose "Utilities" or "Tools and Updates," depending on your software.
  • Select "Calibrate" to start the calibration process. It may take a few minutes.
  • Examine the printout and follow the instructions on your computer for how to pick the best printout. You will have to choose the straightest lines on the page and let the software know which lines are the straightest. Your printer will print out several more pieces of paper and ask you to find the straightest lines. Keep doing this until the lines on the test page appear straight.
  • Jan 13, 2011 | Lexmark X7170 All-In-One InkJet Printer
    My computer doesn't recognize my printer even several attempt of software installation is performed.
    Before you made several attempts to install you Epson Printer Software.Did you Uninstall the software first? To reinstall your Printer Software . The old program that did not work properly has to be uninstalled. Go to your Add and Remove Programs In your Contol Panel and uninstall your Epson Printer Program Software .Then restart your computer.Then try Re-installing your Epson Printer Software.
    Jul 30, 2010 | Epson Office Equipment & Supplies
    Problems with HP Photosmart C6280 All-in-one Printer
    Populate the destination list You must populate the destination list in HP Solution Center for the Scan To function to work. Follow these steps to populate the destination list.
    NOTE: HP Solution Center is the software that came with the product. You must make sure the software is installed on the computer for all the product functions to work correctly. The software is also necessary for completing this procedure. Install HP Solution Center if it is not already installed.
    1. On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center . HP Solution Center opens.
    2. Click Scan Settings .
    3. Click Scan to... Setup .
      NOTE: It might take several minutes for the list to populate. If the appropriate programs are already listed as scan destinations, discontinue this procedure. You must reinstall the software.
    4. Click each program to include on the Scan To Destination list. Figure 2: Add destinations c01404190.gif
    5. Click the Add arrow. The program listing moves from the left side of the screen to the right.
    6. Click OK .
    Jun 23, 2009 | HP Photosmart C6280 Printer
    Can't install, fails every time.
    had this same problem, go to Add and Remove Programs and uninstall "Bonjour" and then run the Kodak Setup and it will reinstall it.
    May 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    How to roll back an accidentaly downloaded windows media palyer SPANISH version
    Rolling back to a previous version of the PlayerWindows Media Player is a feature of the Windows operating system and cannot be removed entirely. However, in Windows XP, you can roll back to the version of the Player that was previously on your computer.
    You must be logged on as an administrator or a member of the Administrators group to perform the following procedure.
    1. Disconnect any portable music or video devices that might be attached to your computer.
    2. Click Start, and then click Control Panel.
    3. In the Category View of Control Panel, click Add or Remove Programs, and then click Remove a program.
    4. Click Windows Media Player 11, and then click Remove.If Windows Media Player 11 is not displayed in the list of currently installed programs, then try the following:
      1. At the top of the list, select the Show updates check box.
      2. In the Windows XP - Software Updates section, click Windows Media Player 11, and then click Change/Remove.
    5. In each of the two confirmation dialog boxes that appear, click OK.
    6. When the rollback process is complete (it might take several minutes), click Restart.
    7. Click Start, and then click Control Panel.
    8. In the Category View of Control Panel, click Add or Remove Programs, and then click Remove a program.
    9. Click Windows Media Format 11 Runtime, and then click Remove.If Windows Media Format 11 Runtime is not displayed in the list of currently installed programs, then try the following:
      2. In the Windows XP - Software Updates section, click Windows Media Format 11 Runtime, and then click Change/Remove.If you installed a non-US English version of Windows Media Player 11, the instructions in the dialog boxes that are mentioned in steps 9, 10, and 11 might appear in English.
    10. In the first confirmation dialog box that appears, click OK.
    11. In the second confirmation dialog box that appears, select the Do you want to continue with the rollback? check box, and then click OK.
    12. When the rollback process is complete (it might take several minutes to complete), click Restart.
    13. Click Start, and then click Control Panel.
    14. In the Category View of Control Panel, click Add or Remove Programs, and then click Remove a program.
    15. Click Microsoft User-Mode Driver Framework Feature Pack 1.0.0, and then click Remove.
    16. Follow the instructions that appear in the Software Update Removal Wizard. If the Wudf01000 confirmation dialog box appears, click Yes to continue. When the software removal process is complete (it might take several minutes to complete), click Finish.
    May 02, 2009 | Computers & Internet
    I tried to install my hp laserjet 3015 several times but I failed
    • It may take a little time for the CD to begin reading. Hit retry.
    • The CD may be damaged
    • The program may not load automatically
    • Go to the Start menu and then click on "Run". When the Run window appears, click on browse. Choose the D drive (or the one that reads your CD). Look for a file that ends in setup, execute, or install (these words my be abbreviated)
    • Double click on the file and it should be displayed next to "open" in the "Run" window.
    • Click okay and the program should begin to install.
    Jan 28, 2009 | HP LaserJet 3015 All-In-One Printer
    Firmware corrupted? Only prints some random computer text
    The printer is in line mode. Do the following to take it out of line mode:
    Turn printer power off.
    Hold the feed button while turning printer power on.
    When the light starts flashing, release the feed button.
    When the light starts flashing again, press and hold the feed button.
    When the light turns steady amber, release the feed button.
    When the light turns steady green, the mode is changed.
    Verify the mode by printing and inspecting a status report.
    This requires good timing and may take several tries. You'll know it worked if no labels are reeled out after you're done.
    Apr 17, 2008 | Zebra LP 2844 Thermal Printer
    Printing Slow
    hi,
    check the length of the usb cable. if it is very lengthy then there would be problems with the speed.
    if not
    > unplug the usb cable
    > click "start-->control panel--> printers and faxes"
    > select the printer icon and delete it
    > restart the computer
    > plug the usb cable
    > wait for few minutes while the driver installations are complete automatically.
    > once that is done, try to print
    thanks and regards
    agnel
    Mar 08, 2008 | HP Photosmart C3180 All-In-One InkJet...
    Epson CX6600 takes up to 2 minutes from when Print pressed to Print
    Hey Zitta, Check to see that you have the latest version of the Printer Driver installed on your new drive. Go to www.epson.com and you should find your way through to your local site. Then head for the support area and look for the driver download.
    Mar 08, 2007 | Epson Stylus CX6600 All-In-One InkJet...
    Lexmark X2500 All-In-One Printer Logo
    23 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
