Question about Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
ON/OFF AND MINI LOAD LIGHTS ARE FLASHING AND THE MACHINE WILL NOT SPIN
  • 6 more comments
  • BOING BOING May 05, 2008
    on off lights flashing fast and mini load light flashing a bit slower
  • Anonymous May 07, 2008
    I have exactly the same problem - HELP!!!
  • MJRumble May 07, 2008
    Yep just had the same light going all funny today. What on earth is going on? Help!
  • redjon71 May 10, 2008
    same prob with my hotpoint aquarius wf540 on/off and mini load flashing together and nothing working to clear it ????
  • fubox Sep 27, 2008
    yep,me too.What does this error code mean?
  • nnppearson Nov 19, 2008
    my washer is flashing mini load and wont work.
  • hayleywelch6 Mar 22, 2009
    flashig lights on the on off switch and mini load and rinse hold
  • Anonymous Mar 23, 2014
    machine wont spin
  • 868 Answers
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
Posted on May 24, 2008
  • dangnang Feb 03, 2011
    where are the balance sensors. Cant find any information on the internet to fix it
You are all a bunch of cocks
Posted on Oct 30, 2008
    New Friend:
Someone help me please! My Indesit washer is flashing one continuous red light! it wont start any cycles what so ever.. Ive tried turning it off and on from the plug but it just does the same.. HELP!
Posted on Dec 10, 2012
Please help any ideas??
my WF 540 hot point is currently flashing 6 lights out of 11
flashing ones are:
wash enhance
reduced creases
rinse hold
mini load
final spin
on/off
but the no extra rise, dr lock prewash, wash, rinse and spin dnt flash.
last week it stopped flashing and i was able 2 use the machine but know it wont stop flashing.
many thanks
melissa
Posted on Oct 18, 2008
Door will not open door light just flashing on and off
washer not spining mini load button flashing on/of buton flashing
Apr 27, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Dec 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Lights flashing on WF320P
i'm having same problem people have said empty filtter but i have done that and the water is running out but still flashing
so sorry wish i could help.
Sep 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I've got a hotpoint wf220 wshing machine which is not spinning the pump is working and the on/off lights and mini load lights are flashing
i have a hotpoint wf321 water comes in and pumps out have flashing mini load light on and start light, but drum does not go round,
Jun 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
On/off button and mini load LED's flashing ON Hotpoint WT540
Make sure there is no water left in m/c, lay hose down to draln completely, try spin again, if still no go, remove motor and check brushes.
Dec 15, 2008 | Hotpoint Aquarius WD63 Front Load...
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Machine freezing with three lights flashing.
HI JOHNNYHEFF,
JUST GOT A NEW HOTPOINT STARTED TEST WASH ALL THE LIGHTS FLASHED SO SWITCHED OFF TRIED AGAIN NO JOY. TECHNICIAN COME OUT SAID THE CIRCUIT BOARD WAS GONE, NOT GOOD NEWS FOR YOU BUT THOUGHT I'D LET YOU KNOW!
Oct 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Feb 16, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
3,043 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
