Question about Maytag CWG3100A Gas Single Oven
Maytag oven dosen't come up to set temperature
  • Maytag Master
  • 909 Answers
The fact that it heats at all indicates the element is functional. The thermostat will be the problem. Normally there are about 4to6 wires connected to the thermostat. Not saying you are not competent, but each model has a specific no. on the thermostat and must be replaced accordingly (might have auxillery switches which wont be on another etc).Current on the stove is lethal. Suggest a technician, but at least you know what the problem is and wont be charged for other things.
Posted on Aug 25, 2010
How do I replace the bottom oven element on my Maytag CWE5800?
This shouldn't be too difficult. Make sure the power is off. Remove the screws that hold the oven element in place. carefully pull the element out from the back wall without losing the wires back in the holes. Install the wire on the new element push it back in the wall. Reinstall the screws and you are set. Turn the power back on and check to make sure the oven cycles when it reaches the set temperature.
Feb 08, 2014 | Maytag Ovens
MAYTAG OVEN ERROR CODE F3
Hi Janine.
F3 means "Shorted oven temperature sensor" and it is returned when the oven electronic control detects a wrong impedance value from the oven temperature sensor circuit.
The oven temperature sensor is a probe located inside the oven cavity. The sensor can be removed from the oven and tested using a multimeter set on impedance. The impedance reading across the two sensor's contacts at room temperature must be about 1100 Ohms. Impedance increment rate is 100 Ohms more for every 50 degrees temperature increase. If the reading is sensibly different from this value the sensor must be replaced.
Here the replacement part:
Long Oven Sensor Kit
The sensor is indicated as part number 11 in the exploded view available here.
The sensor is held by two screws. In order to replace the sensor disconnect power, disconnect the connector attached to the sensor, undo the two screws and remove the sensor. Perform operations in reverse order to install the new sensor.
Regards.
Ginko
Jan 15, 2012 | Maytag Ovens
My maytag oven is showing a f3 code model #che98oobcb
The "F3" fault code is indicating an oven temperature sensor failure or a temperature sensor circuit failure. The oven temperature sensor could be open or shorted. Test the sensor for proper ohm value, frayed or pinch wiring, or connector damage. The oven temperature sensor probe can be found sticking out from the rear wall inside the oven cavity. It will need to be disconnected and tested with an ohm meter. I added a chart in the image below of the resistances of the oven sensor at specific temperatures. At normal ambient room temperature, the oven temperature sensor should have a resistance value of 1050-1100 ohms. See image below. The oven temperature sensor is part #12001655. richroth_137.jpg
Jul 21, 2011 | Maytag Ovens
F-3 Error code Maytag Wall Oven....
Shorted or open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jun 24, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
T3 electric wall oven - Temperature set buttons
I had the same problem. The entire control panel had to be replaced. That included the display, keypad and all the hardware behind it.. it's one integrated unit. Luckily I had the extended warranty, otherwise it would have cost close to $400.
Jan 20, 2008 | Maytag 30 in. Electric Single Wall Oven...
Maytag oven calibration
Maytag single built in oven model cwe9000bcb beeps intermittenly. Reset stops for about 1 minute. Two control panel boards replaced since 2002 with same problem. Can it be fixed?
Dec 18, 2007 | Maytag CWE4800A Electric Single Oven
Maytag oven will not light
There is no reset button on range. Do you mean your house breaker is tripped? I would check for bare wires shorting to ground.
Look for evidence of mice, as in droppings. If so they probably chewed on wires.
Nov 18, 2007 | Ovens
Have you tried to broil or bake? if only one of them work you have a bad ignitor. let me know and we can go deeper
Aug 23, 2007 | Maytag CWG3100A Gas Single Oven
Maytag CWG3100A Gas Single Oven Logo
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
