My palsonic pdp4275 has started flickering and then loading signal after using for a couple of hours. Not sure if it's heating up or what, though the Tv still functions , menu etc are all displaying fine , Anyone know what this could be ? Thanks Troy
Palsonic 4275 - volume control message keeps appearing on the screen.
Posted on Aug 21, 2011
I have a palsonic model no: TFTV492LED and I can't change it off AV1. I want to put it on HDMI I have no remote either.
Try the front panel button labeled Source; it's the second button from the left. (The first button is the Power button.) All of the buttons are on the right hand side of the bottom frame of the TV. Use the Channel Up/Down arrows to navigate through the list of inputs. Try waiting for the selection to take effect. (The documentation says press OK or the Volume Up button. Sometimes, the Source button on the TV functions as an OK button. This isn't clearly identified for the Palsonic.)
If the HDMI input is greyed out, the TV may not be seeing a compatible signal from the source. Try turning on the device when the TV is off, then turn on the TV. I'm not sure if this TV will correctly see the signal from a computer. However, on some laptops, you'll need to enable the external video first. This is disabled to save power. Then turn off the computer. Finally, turn on the TV before turning the computer back on.
Palsonic has the manual available for the TFTV492LED on the product (discontinued) site under the Downloads tab. See http://palsonic.com.au/archive/led-tv/tftv492led.htm . The direct link to the manual is http://palsonic.com.au/customer_service/led-instruct/Palsonic_TFTV492LED_Manual.pdf .
I hope this helps.
Feb 29, 2016 | Televison & Video
When I try to retune TV to pick up new TV stations I get sound OK but a black screen with message invalid format.
Check stations MPEG format . Check if it is MPEG4 and check if TV can decode MPEG4 . A firmware update may be available on tv and may fix it but it has the risk of turning the tv into a brick if something goes wrong during a firmware update.
suggest contacting palsonic to see if firmware possible and which one to use.
http://www.palsonic.com.au/customer_service/upgrade/default.htm
Feb 23, 2016 | Televison & Video
Problem keeping a charge on my IPad after just a couple hours even though I make sure I shut all the windows that I have used.
please try stopping location based services and also mobile network connection, if the signal is weak
Aug 20, 2014 | Apple Computers & Internet
My ISP is the post office in the uk. they sent me a zyxel 1429lov router. i never received a disk as we had the previous router model. the problem is the signal drops every couple seconds and the green...
I hope the the green Light your are talking is the ADSL light.
If the DSL light flickers and then cuts off that means the cable comes to your home is not good. Please ask the provider to check the cable and VPI/VCI settings/signals
Nov 01, 2010 | Zyxel ZyWALL 10W (91-003-131001) Router
I have an ASUS model X83V and my screen has been flickering (not in brightness, but actually going fuzzy and "jumping"). The flicker can take upwards of 1 hour or more before it goes away, but usually...
my son has this same machine and after a year of almost daily use it developed this same flicker you describe, about every 4 secs, then it got much worse, almost like an old tv rolling. i took it all apart and inspected it all. didn't see anything really troubling.
yesterday it worked fine all day while i installed a bunch of updates for another problem. i left it on all night doing some other things. this morn when i got up it was still ok. then after a while it started in again, every 4 secs.
so i've been troubleshooting the damn thing all evening and have come to the conclusion its from over heating, probably cause of the crappy heat sink connection. i noticed if i take it outside in 40 degree weather and leave it a couple mins on the hood of my truck, it goes away. bring it back in and after 5 mins it comes back. take it back out and its fine again in a few mins. also, yesterday my house as much cooler. my fire was out and it was in the upper 60's in here, today as soon as it got to 76 in here, and it was above that all day, it started acting up
so i think my next step will be to try and make a better union between the chips and the heat sink itself. you should try a test with yours. start it up, make sure its flickering, put it in a cold space for a few mins. just be caustious of condensation.
Oct 23, 2010 | Computers & Internet
Lg plasma
there are 2 types of flicker, one is the lamps that drive the display and the second is the sync signal of the video.
I assume the video sync is the flicker you see,
I would try connecting a different way to make sure it is not the tv,
connect using the aux /rca connectors to cable box.
and or connect using the cable direct bypassing the cable box.
I have seen several complaints about the hdmi cable signal being incorrect in some way,
this is the same issue that the svideo connector had in its early adoption signal was too hot or too low.
another thing to watch out for is the low light sensor on the front of tv if it gets an incorrect reading it can flicker the back light though it should be slow in doing so.
some times the flicker you see is not flicker but ac running through the sides of the picture from an ungrounded cable source.
how does it perform if you play a dvd player , with and without the cable box connected.
Apr 29, 2008 | LG 42PX5D 42 in. Plasma HDTV
Missing Color.
the color wheel may spin but if you hear noise when it spins it's bad. the jumper is used when replacing one type of color wheel for a nother type. so donot remove jumper unless you've replaced the color wheel and the picture is bad. if the color wheel is good replace the DMD board. if the DMD is not available replace the optical engine.
Jan 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Metz CRT TV G3478 color problem in PAL mode
I see from your profile that you have not specified your location which make it tricky to be sure which standard you should be using.
Oct 07, 2007 | Televison & Video
Televison & Video Logo
183 people viewed this question
Top Televison & Video Experts
Electro Med Services...
