Question about Unitech MSR 206-33 (msr206-33) Magnetic Card Reader
Msr606. worked fine yesterday , but when plugged in today green light comes on then fades very dim, I can read cards but if I try 2 write it says write error . I been using this machine for a while, I checked all settings hi co lo co nothing is not set write.. Again the lights come on when its first plugged in then instead of the green light staying on it stays dim, could this be a short in the electrical cord,, a kink or or wiring messed up
  • Unitech Master
  • 19,396 Answers
A short on power cord will cause a blow, and the unit would not start, it looks more like a grounding problem or a faulty component in the reader control board.
Check grounding of power cord, and test card reader on a different socket.
Chech also the data connection cable, a contact in that cable may also cause the problem.
If that does not help, then the card reader board should be tested at component level. This units are considered not serviceable and usually they get replaced when this happens.
Posted on Aug 25, 2010
Seagate Expansion 1TB external Desktop Hard Drive (9sf2A4-500) not detected.
Claire,
Have you tried connecting the drive to another computer using Windows 7 or later. You could try chkdisk /f at a command prompt or get the testdisk app to identify deeper issues with the drive.
Chappo07
Oct 24, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
1992 Ford Tempo GL 2.3L. Replaced battery yesterday. Car will not start or crank. Ran fine as of two days ago. There was a wire that ran from the negative terminal to the frame in front of it that was...
is it turning over,have you checked the starter?if so spray some brake cleaner in the throttle body and see if it will start.
TIM............
Oct 22, 2010 | 1992 Ford Tempo
Blingking light on my motherboard, no power.
Chances are your power supply and computer is fine! From other forums on this problem (which I also had), I've learned the following:
1. If you unplug the computer for a half hour or so (the blinking green light will gradually slow down and quit) and plug it back in, the situation will correct itself and the green light will be steady; however if this does not work,
2. a reset that works for a lot of people with the blinking light problem involves leaving the power supply plugged in and unplugging the power supply connection at the motherboard (it usually also has a blinking green LED) and plugging it back in. To read up on how to do this, Google "blinking green light on computer power supply" and read through some of the forums and you'll come on more specific instructions. Usually, you have to wade through everybody telling you to replace the power supply or your motherboard is fried. It's worth a try for a quick fix, just in case those situations don't apply!
May 30, 2009 | Sony VAIO VGC-RB42G PC Desktop
TV wont turn on.
Hi
This case needs to diagnose by a qualified technician
Thanks
Nov 28, 2008 | Mitsubishi Televison & Video
Dark disp-lay
sorry mate,that is dreaded power interter board inside lcd,read about similar benq model dramas here http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
Jun 03, 2008 | BenQ T705 17" LCD Monitor
Plez help
Have problem with my 2-month old Wii. Please see whether you can offer any suggestions. My problem is: Red light comes on no problem when power is connected, but when pushing the power button nothing happens - no green light? is this a sync problem? this happened yesterday and i unplugged everything and when reconnected it worked, but not today? have just installed a new tv, could there be interference from the new remote?
Jan 31, 2008 | Nintendo Wii Console
Unitech MSR 206-33 (msr206-33) Magnetic Card Reader Logo
589 people viewed this question
Top Unitech Televison & Video Experts
Michael Galve
Michael Galve
Are you an Unitech Televison and Video Expert? Answer questions, earn points and help others
