Question about Cameras
Greetings, I have several floppies filled with pictures I took with my old casio camera. They are in .cam format. I have no other copies of these photos. I no longer have the casio camera or software. How can I convert these to jpeg files so that my iphoto software can read them? (I have already copied them onto my hard disk from the floppies, but am unable to open them with any of my current software.) HELP PLEASE -- Sheila Zeddy
    Novelist:
    Champion:
  • 216 Answers
Greetings Sheila Z,
This link should help you to find a way to view those photos:
http://www.liutilities.com/products/winbackup/filextlibrary/files/CAM/
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Posted on May 05, 2008
Will pictures remain sharp when a smart card is reused several times?
No. images are stored digitally, so a one bit remains a one, while a zero remains a zero. The card will wear out eventually, after hundreds of thousands of write cycles, but that's after decades of normal use.
More importantly, you want to format the card regularly, like after each time you download pictures to a computer. If you simply delete the pictures each time, you're all but guaranteed to have a file system error eventually. Formatting avoids this.
Mar 04, 2012 | Nikon Cameras
I took several pictures this morning. Then I plugged the camera into the cradle and pressed USB port and connected the line from the cradle to the computer, an operation I have completed numerous times. ...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Oct 04, 2010 | Casio Exilim EX-S600 Digital Camera
Memory card
If you go into the menu you will run across an option saying " Format "This will remove all pictures off your card if you have one inserted or it will give you a " format Internal memory " option this will erase the contents on your camera's memory. If you can connect it to the computer you can also right click on the device in my computer and go to format. You can usually remove and copy pictures individually through both the computers right click menu or in the camera by entering preview mode and entering the preview mode menu for more options about that file or multiple files.
Apr 05, 2010 | Casio Exilim EX-Z750 Digital Camera
Recently purchased Sony Cybershot DSCW180. Took 3
Yes, you need to have memory stick because camera has limited internal memory that can store few pictures only.
Put new memory card, format it through camera Menu and copy internal memory pictures to memory stick, take our memory card from camera and delete internal memory pictures either one by one or format internal memory through camera Menu.
Thanks.
Dec 02, 2009 | Sony Cybershot DSC-S950 Digital Camera
Can't get the photos to download from Scandisk. Format issue?
if u remove the card while the cam is on then it sometimes occurs the files may get corrupted so copy all the photo to a computer then format the card then copy it again to the card then insert it to your cam all cam pics are in jpeg extension so check the extension of the pics while copying to your card.
Oct 17, 2009 | SanDisk Extreme III 4GB Secure Digital...
Casio Exilim EXZ75 7.2 mega pixels
I have a copy but it sounds like the main board might be defective. repair on this camera runs from 85.00 and up depending on where you have it fixed.
Oct 28, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Recovery menu
You need to make your floppy bootable by formatting with the "copy system files" option set. Then copy your autoexec.bat file to it, or you could simply type NETRUN and press ENTER from the c:> prompt once you've booted. (What's the operating system?)
Oct 27, 2008 | NEC PowerMate 2000 PM2002 PC Desktop
Casio EX-Z1000 camera
You can always format your camera and that would erase everything on your camera. In picture taking mode press menu and go to setup, go down to format and press right arrow and confirm steps through there.
Sep 08, 2008 | Casio EXILIM EX-Z1000 Digital Camera
Memory card blocked!!
First of all with a Casio camera Casio will only guarantee the camera to work with Panasonic, Toshiba and Sandisc memory cards. If it is not one of those three brands I would go buy one of those brands. Make sure you format your memory card with the camera before using it for the first time. As for the other memory card try using a program like cardrecovery.com and see if you can still pull your pictures off that card. I bet they are still there. :)
Sep 01, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Cameras Logo
51 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
