What is name of housefly having green head? - Computers & Internet
  • 104 Answers
Plz vote for me
i would be thankful to you
plz
Posted on Aug 26, 2010
Leaking antifreeze, have been told it could be head gaskets.
Hello roxanna surf: My name is Roger and I will help you. The problem could be one of several problems. GM has a problem with the intake manifold gaskets leaking coolant useually external but can leak internal also. Check at the corners of the intake manifold where the manifold meets the heads. If you see green or orange drops of coolant or a slimmy build up than the intake manifold gasket is leaking. Idf the leak has been ongoing for some time and the engine has overheatedI would also look at a head gasket, warpped head or even a cracked head as a source of the problem. The engine does not like extreme heat and can have serious issues. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Aug 16, 2011 | 1997 Oldsmobile Aurora
There are 2 sets consisting of 4 wires that I need to attach to the new jack that come from the L and R head phones one set has a green and a yellow wire and the other set has a brown and a white...
After digging and searching and finally getting instant support from Beyerdynamic, the old DT770 Pro Have the following color coding:
Brown: right + (Ring)White: right - (Ground)Green: left + (Tip)Yellow: left - (Ground)
The only competent and helpful information on this particular headphones I have found so far. I hope this is helpful.
Thanks Beyerdynamic support's prompt answer.
Mar 10, 2011 | Beyerdynamic DT 770 PRO Professional...
PRINTER DOES NOT PRNT PICTUES CORRECTLY. THEY ARE RED AND GREEN AND BROWN MOSTLY. CARTRIDGES SHOW LOW EVEN WHEN NEW.
Go to your printer's Maintenance Utility and perform a Head Cleaning or something that is similar. For Windows users:
  1. Click Start => Control Panel
  2. Click on Printers and Faxes (or devices that list printers)
  3. On the printer's folder, look for the printer name and right click on it and click properties.
  4. Select the Maintenance Tab on the dialog box that appears
  5. Then choose something like "Head Cleaning" and perform the test
Jun 23, 2010 | HP Photosmart C6380 All-In-One InkJet...
I have no sound in my head set, but on the speaker.
Hello, To check Audio
  • Go to TOOLS
  • Go to OPTIONS
  • Click on AUDIO SETTINGS.
  • There you will See Microphone Volume and in right Side Sound Card's name (eg:Realtek HD Audio Input).
  • Try to Speak then you will see Indication Signal(Green) according to your Voice near to it
  • There will also See Speakers Vilume and in right Side Sound Card's name (eg:Realtek HD Audio Output)
  • There you will See the indication Signal of Hearing the Sound from Other Side
  • If Signals are OK.You are Configured Sound
Still have Problem to hear Sound you may need to Check your Hardware Working Properly/it might be damaged it...Thanks for Contacting FixYa
May 28, 2010 | Skype IM
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
What is the difference between a slotted round and square screwdriver?
A slot screwdriver may be used for screws with a recessed single groove that stretches across the head of a screw. A square ended screwdriver was invented in Canada by a man named Robertson. These types of screwdrivers are named after him and come in different sizes from 0, 1, 2, 3 and have different coloured handles, yellow, green, red and black to mark the sizes. Number 2 (red) is the most common for wood screws. Square drivers make better contact then slotted ones and don't strip the head as quickly.
Sep 30, 2009 | K-D Tools 1/4" x 4" Square Blade Slotted...
Service Error 5C00 - iP90v Pixma Canon Printer
Clean it out underneath the printhead & cleaning mechanism first (paper towel), then do the fix routine.
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
also there are TWO distinct steps to resetting the TWO ink counters in aan iP90. Enjoy.
3-3. Adjustment / Settings
(1) Service mode
The basic operations are the same as those of the i70 / PIXUS 50i.
In this section, destination settings, how to reset the waste ink counter, and EEPROM information
printing, which differ from those of the i70 / PIXUS 50i, are detailed.
1) Turn off a printer. While pressing the Resume/Cancel button, press the Power button.
The LED lights green to indicate that functions are selectable.
button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the
alternately lights in either orange or green, starting with orange.)
4) When the LED lights green, press the Resume/Cancel button as many times as you need, to
select the preferred function. (See the table below.) Each time the Resume/Cancel button is
pressed, the LED alternately lights in either orange or green, starting with orange.
(The color red indicates the changes from the i70 / PIXUS 50i.)
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting Proceed to step 5) below. Once executing step 5), then, move on to step 6) to select the waste ink counter to be reset. (Different from the i70 /
PIXUS 50i.)
5 times Orange Destination settings Proceed to step 5) below. Once executing step 5), then, move on to step 7) to select a
destination. (Different from the i70 / PIXUS 50i.)
10 times Green Return to the menu selection
5) After the function (menu) is selected, press the Power button. The LED lights green, and the
selected function will be performed. (When the operation completes, the printer returns to the
6) Press the Resume/Cancel button the specified number of time(s), then press the Power button.
Time(s) LED Waste ink counter to be reset
0 time Green Main waste ink counter
1 times Orange Platen waste ink counter
2 times Green Main waste ink counter and platen waste ink counter (at the
same time)
Note: When the waste ink counter is reset, print the EEPROM information as shown below,
and confirm that the value of the counter is 0 %.
8
7) Press the Resume/Cancel button the specified number of time(s) according to the destination
listed in the table below, then press the Power button.
Time(s) LED Destination
1 time Orange Japan: PIXUS iP90
2 times Green Other than Japan (A4): PIXMA iP90
3 times Orange Other than Japan (LTR): PIXMA iP90 (LTR)
Note: After the specific destination is set, print the EEPROM information as shown below, and
confirm the model name.
Print sample:
1:iPXXXX 2:V1.02 3:IF(USB=1) 4:D=004.9 PD=000.0 5:ST=2005/09/27-18:30
6:ER(ER0=1000 ER1=5100) 7:LPT=2005/09/028-09:09 8:PC(M=002 R=000 T=001 D=009 C=009)
9:CLT(BK=2005/09/27-18:30 Cl=2005/09/27-18:30) 10:CH=00002 11:CT(BK=040 CL=013)
12:IS(BK=1 C=0 M=1 Y=1) 13:IC(BK=00000 C=00000 M=00000 Y=00000)
14:Power(SON=00009 SOFF=00009)
15:REG=0 16:UR(A(BKoe)=+01 B(Coe)=-01 C(Moe)=+01 D(SCoe)=-01 E(SMoe)=+01 F(BKbi)=+01
G(CLbi)=+01 H(BK-CL)=+01 I(SCLbi)=+01 J(C-SC)=+01 K(M-SM)=+01)
17:WP=0024 18:CDIN(LG=001 PB=000) 19:MSD(015)
20: PAGE(All=00083 PP=00035 HR+MP=00003 PR+SP+SG=00003 GP=00000 PC=00000 ENV=00000)
21:CDPAGE=00003 IRPAGE=00003 BTPAGE=00003 PBPAGE=00000 22:BAT PAGE=00000
23:EDGE=00083 24:L=00000 25:HEAD Temp=30.0 26:Env Temp=30.0 27:FF(3F 3F 3F)
HDEEPROM
1:V0001 2:SN=0000-3D6B 3:LN(00000 00000 000001 000003 00001 00000 00000) 4:ID=00
5:IL=(BK=000 C=+01 M=000 Y=+01 C2=+01 M2=000 Y2=+01)
Printed items:
1. Model name 2. ROM version 3. Connected I/F (USB1) 4. Main waste ink amount, Platen waste ink amount
5. Installation date 6. Operator call/service call error record 7. Last printing time 8. Purging count
(manual/deep/timer/dot count/print head installation and removal/ink tank installation and removal)
9. Cleaning time 10. Print head installation and removal (change print head) count 11. Ink tank installation and
removal (change ink tanks) count (Bk/CL) 12. Ink status (Bk/C/M/Y) 13. Total ink consumption 14. Power-on
count (soft power on/soft power off/hard power on) 15. Print head alignment implementation 16. User print head
alignment values (Bkoe/Coe/Moe/SCoe/SMoe/BKbi/CLbi/BK-CL/SCLbi/C-SC/M-SM) 17. Number of times of wiping
18. Number of times of camera port connection and removal (Legacy, PB) 19. Number of the maximum printing
intermission in days 20. Number of print pages (total/plain paper/high resolution paper + Matte Photo Paper/Photo
Paper Pro + Photo Paper Plus Glossy + Photo Paper Plus Semi-gloss/Glossy Photo Paper/Card/Envelope) 21.
Number of Camera Direct Print pages (total), number of IRDA print pages (total), number of Bluetooth print pages
(total), and number of Print Beam print pages (total) 22. Number of print pages using battery (total) 23. Number of
borderless print pages 24. Number of print page (L/4” x 6”) 25. Print head temperature 26. Inside temperature
27. Line inspection information
HDEEPROM
1. Version
2. Serial number
3. Lot number
4. Print head ID
5. Ink ejection level (Bk/C/M/Y)
Jul 23, 2009 | Office Equipment & Supplies
Problem with Printer Colour
Hi, My name is Eram, I want to help you with this problem. First, be sure this cartridge is new, because if the cartridge its passed of the manufacturing date, it won't work properly. Secondly, if the cartridge its brand new, might be that you need to perform some printer alignment. You need then go to all programs then your program named Canon printer, then Settings and then align your printer. You also may try to print a test page. If still showing only the green color, you have to procede to re-install your printer, might be that some software conflict is happening.
Dec 19, 2008 | Canon i860 InkJet Photo Printer
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
