Question about Bose Audio Players & Recorders
I have a 2003 Infiniti G35 with a factory installed Bose radio, 6 CD player and tape player. The radio and the tape player work fine. The CD player (with four CDs in it) has a message that comes up saying "CD Err F0" and will not play, eject or load.
    President:
  • 4,070 Answers
Hi! Most F0 errors are caused by scratched or dirty cds. Try inserting a clean cd if it will work. If not then I strongly suggest that you run a cd lens cleaner for the optical lens may be dirty. Hope this helps and thank you for using FixYa!
Posted on Aug 25, 2010
I have a 1996 Nissan Maxima with a factory Bose CD player / cassette and radio and it will not turn on what's the solution
Maxima Bose Radio ' eBay
www.ebay.com/bhp/maxima-bose-radio
eBay1995 1996 1999 Nissan Maxima Pathfinder Infiniti J30 Radio BOSE CD tape Player ...Will fit and work in these with BOSE audio package only:1995 - 1999 NISSAN .... 2006Nissan Maxima OEM Bose Cassette & 6 Disc CD Player Radio CR13B ...DESCRIPTION Unit is missing some bottons, 3 of them, this item has NOT ...
Nissan Maxima Bose Stereo ' eBay
www.ebay.com/bhp/nissan-maxima-bose-stereo
eBayWill fit and work in these with BOSE audio package only:1995 - 1999 ... 1996 - 2000 NISSAN Pathfinder. 2004 2005 2006 NISSAN MAXIMA FACTORY BOSE STEREO 6 DISC ... Factory NISSAN INFINITI BOSE Radio, Tape, and CD Player. ... 6 Disc AM FM Stereo Cassette Radio Bose OEM LKQ (Fits: Nissan Maxima).
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair .... I have nissan maximal 05..the CD part turns on but the cd won't eject...should ... I have a 2005maxima non-bose radio system. ... my speakers is super in my 05 maxima but my cd player keeps on ...
Nissan - Factory Car Stereo Repair
Feb 03, 2016 | Nissan Cars & Trucks
04 Infiniti sedan w/ factory Bose. Front speakers are not working (no sound at all) and I adjusted fade all the way both ways. Back speakers are fine. What's up?
If the rear speakers are fine, perhaps I can narrow this down. Fuses must be OK. Steering wheel audio controls connect to the audio unit which has a preamp function. The W/BK outputs connect to the left front inputs of the Bose speaker amplifier; the GRN/RED outputs connect to the right front inputs. Your ear test confirms the front door speakers are not working, therefore there is no front door output from the amplifier. The amplifier stages for the front doors may not be working or no front door amplifier input is being received from the audio unit. The fader and balance controls do not show on the diagram so must be on the front panel. They could be defective. There is a remote possibility of broken/disconnected wires
Sep 07, 2012 | Sony 2003 2004 03 04 Infiniti G35 Bose Am...
When I turn my cd player on all i get is CD ERR FO.
This is a common problem on the early year G35s and also on Infiniti/Bose head decks in general.
The stereo can be removed and sent to an electronics repair shop who can replace the damaged components, or you can go with an aftermarket solution.
I believe this problem has somethind to do with the laser going bad, but I could be wrong. I've seen this on numerous Maximas and I30s as well as G35s.
Sep 11, 2009 | 2004 Infiniti G35 Sport Coupe
Infiniti G35 speakers don't work
03 and 04 G35 vehicles had a Technical Service Bulletin issued regarding the audio circuit board. No sound was one of the symptoms of a faulty circuit board. There was a design flaw with the boards on the early model G35's that was corrected in 05.The audio units on those cars consisted of three pieces, the radio itself, which is just a silver box, a circuit board that attaches to the front of the radio and then the outer display. I would suggest contacting a dealership service dept. with your VIN number in hand, and ask if the circuit board has been replaced. Even if it has, It will still more than likely be the problem. It's either that or the radio
Apr 27, 2009 | 2004 Infiniti G35 Sport Coupe
2003 infiniti g35 cd changer won't work-it gives an error message
Had to replace same unit twice in 2004 G35. Seems to be a bad model. Sometimes a dirty disk(s) will cause operation problems so make sure all disks are sqeaky clean, and if they are in unit for more than a month, remove, clean and reinstall. Use plain water and a soft cotton rag for dust, but windex for grease/oil/candy etc. Also vacuum unit face opening when cleaning interior.
Mar 19, 2009 | 2005 Infiniti G35
2003 infiniti g35 cd player
its a very common problem with g35 in dash clarion cd changer head units. a small plastic gear gets worn or brakes and wont eject or change cds. you need a new one, should be covered under your warranty.
and to get your cds out try this.
Feb 03, 2009 | 2004 Infiniti G35 Sport Coupe
I removed my cd player to remove a jammed cd on my 2003 G35 coupe
There are several small "ribbon" connectors that can come loose very easily. They look like a flat ribbon like piece of plastic with a hard plastic piece on the end. They come out really easy. just look around
Aug 26, 2008 | 2004 Infiniti G35 Sport Coupe
CD player (6 disc changer) "locked up"
Take it to the dealership, your G35 should have a 4 year bumper to bumper on it. They'll replace the radio under warranty most likely.
Jul 23, 2008 | 2005 Infiniti G35
232 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
