Question about Frigidaire FRT22TSE
Why won't the fridge or freezer get cold enough? We have turned it to the middle, highest settings, on Eco and off Eco...nothing seems to work. We have unfrozen meats in freezer and luke warm milk
  • Frigidaire Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
My freezer is not getting ice
If the freezer is not cold enough you may have a compressor problem. First totally defrost the fridge. then plug the fridge back in and check that the fan in the bottom that cools the compressor is working. the cold control can fail so turn the cold control to the highest setting and note if the compressor stops running before the freezer starts making ice. If the fridge just runs and runs and does not get cold enough to make ice you have a somewhat serious problem. the compressor can be replaced but it is expensive and you might be better off to get a different unit (new or used) that will work correctly. Most used appliance stores will have something that will work well and won't cost that much.
Apr 18, 2011 | LG Refrigerators
Freezer side working fine - fridge side simply not cold enough even at highest setting
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 17, 2010 | Frigidaire FRS3R5EMB Side by Side...
My freezer wasn't defrosting and the fridge wasn't as cold as it should be. I emptied it out and unplugged the fridge for 2 days and plugged it back in. Settings for freezer and fridge are on the highest...
hi how are you...please turn down setting to original setting from factory...in the freezer,does the back panel have ice on it....if so you have defrost problm...if not remove panel...if one one place on coil has ice ,but not whole coil...then has a freon problm....allow 24 hours for settings to readjust....hope this helps...good luck...michael doctor airr appl.repair..843-384-8474...call if need assistance...good luck...
Mar 26, 2010 | Maytag MTB1956G Top Freezer Refrigerator
So my split fridge and freezer broke. the freezer works fine but the fridge doesnt get cold enough, even if i turn the knob to 7 (the highest).
first clean and remove dust and debris from under unit and make sure fan is working properly--next check the fan in freezer section for icing ,damage ,blockage ,or failure repair or replace as necessary the fan supplies the fridge with cold air from freezer
Nov 26, 2009 | Kenmore Refrigerators
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Freezer keeps frosting up and fridge doesn't get cold enough
Your defrost system isn't working. Check your defrost heater, defrost thermostat. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php If they are OK the problem is the electronic control. Part 32 on this diagram. http://www.appliancepartspros.com/sect/i/2/w/i2wajbeu9f.gif
Jul 01, 2009 | Jenn-Air JCB2280HES Side by Side...
Fan is a big issue. New problem though.
good day!first and foremost, in most freezers, the highest freezing point is 7.in regards with the water dripping from the air vent hole, you have to minimize your your freezing setting to the middle.turn it to 3 or 4 freezing point.
Aug 22, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Moffat Freezer
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
Oct 14, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
My fridge is not cooling, my freezer seemed fine until today
THings to check
Check freezer...
Check condenser...
To make sure clean, and the fan is blowing by compressor,
Oct 12, 2007 | Maytag MCB2256HE Side by Side Refrigerator
Refrigerators Logo
42 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
