Question about Karcher 2500 PSI Pressure Washer
Karcher pressure washer
Washer started to pulse really quite badly.
a blast of water every 1 - 2 seconds.
eventually washer stopped alltogether.
only 3 - 4 years old
and only used 1 - 2 -times a year
  • hammerobscur Nov 23, 2008
    Washer just began pulsating during operation. Checked all connections - everything seems fine. Any ideas where to start looking for solution?
5 Suggested Answers
  • 174 Answers
SOURCE: Karcher K2.94 Overheats
Well, there is a switch inside. It is controlled by the valve that allows the pump to go into bypass when you let go of the trigger. This switch may be worn out or the valve that controls it is sticking. It may also be that your motor is just worn out. There is a heat sensor inside the motor (you cannot get to it) that sometimes wears out and trips too easily.
Posted on Jun 23, 2009
jmgldsmth
  • 1906 Answers
SOURCE: new Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Posted on Aug 31, 2009
  • 608 Answers
SOURCE: karcher pressure washer keeps pulsing when not in
This can happen if the head of the pressure pump has split. You may need a new head, and to stop this happening again, tie the rigger open with a zippy tie. The water will run all time now and automatically bleed any air form the system. When you want pressure, turn it on at the main switch. This will prevent hydraulic hammer, (when you pull the rigge)r, which is what causes the head to split.
Posted on Mar 28, 2010
acehead
  • 107 Answers
SOURCE: My Karcher 2.99 starts and stops, (pulses) when th...
http://www.youtube.com/watch?v=8XDPDhg_acQ&list=UUiF9Qw4CmLuBqWFGanj1KIA&index=14&feature=plcp
Posted on Aug 25, 2012
How do i stop it from pulsing?
Getting to much air to carb probably.
Jul 11, 2015 | Karcher Garden
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
What's wrong when you only get full pressure for the first few seconds and then it stops and won't spray fully anymore?
Air pockets in the supply hose or the supply is feeding the power washer too slowly.
These things can really put out quite a bit of water, so make sure you've got a good supply going to it. No kinks in the hose, spigot opened all the way, etc.
If the problem is air pockets, make sure you're running the feed hose long enough to get a good flow of water before hooking up to and starting the power washer.
Jun 01, 2010 | Karcher 2500 PSI Pressure Washer
Is liquid leaking from the base, when the Pressure washer is on ?
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 21, 2010 | Karcher K2.26MR Electric Pressure Washer
I have a Karcher KB5050 it started to pulse when the trigger stopped
Is there water leaking from the bottom ? If so, then you have a leak in the pump. Bad seal or crack in the Pump.
If under 1 year old and have a receipt, Call Karcher for a warranty replacement.
May 14, 2010 | Karcher 1750 psi Electric Pressure Washer
Hi Bought karcher k5.80 some time ago It didnt work well and I put it away however got it out again its blasts then trickles water on for couple of seconds the off again. What if anything can I do?
I got the same problem as msellar1. Anyone got any ideas to resolve??? medcalf.chris@virgin.net.
Thanks.
Basically, turning the spray nozzle to reduce the pressure works - but this is next to useless for cleaning anything. I fixed the leaky tap in case air was getting into the system but no. It's been like it since day 1, on and off, but now more stop & start than ever! Maybe thats why it was reduced to I think £150 from £275???
May 07, 2010 | Karcher Garden
I purchased a reconditioned Karcher 4000 and upon first use, the spray surges. It will go down to almost nothing then back up to full blast in about 5 second increments. Any advice?
Bleed the system by running water without the unit on, You have an air lock, open the drain cocks and allow water to run slowly for 2 minutes, then close everything and try it
Mar 06, 2010 | Honda Karcher G4000RH Pressure Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Karcher/Winner 11 - motor pulses when hose is not operating
Hi, I had the same problem, Replaced the O rings and the rubber seals and cups inside the pressure washer and eventually the hose itself burst. Turns out the hose was leaking, internally between the inner sheath and the outside plastic cover, for quite some time and this caused the pulse. New hose and pressure cleaner is as good as new.
Mar 15, 2009 | Karcher K2.26 Electric Power Washer
Karcher 2500 PSI Pressure Washer Logo
351 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
