Question about Watches
I have Titan Octane watch with tachymeter function. There is also time zone function. How do we use the various functions? Obviously, there are no user manuals, or company does not beleive in providing them
  • 17,970 Answers
On some of the analog watches or wristwatches from branch such as Omega and Casio, there is a outer scale bezel that inscribed around the rim and named tachymeter (also known as tachymetre or tacheometer). If you flip through the watch’s user guide or manual, you will not likely to find any explanation or definition on what is tachymeter or how to use the tachymeter functionality. Tachymeter is actually a tool used to compute speed based on travel time over a fixed distance travelled (like one mile or one kilometer). Thus, the tachymeter bezel or dial is a logarithmic scale (actually it’s not, as spacings between the marks on the tachymeter dial are proportional to 1/t where t is the elapsed time) that simplifies the computation of speed of an object, by computing the following function:
Tachymeter Dial = 3600 / Elapsed Time In Seconds
Tachymeter illustration. Depending on on the range of the scale printed on the bezel, tachymetre timer normally works and valid for all elapsed times from about 7.2 seconds to 60 seconds, thus only able to measure speed greater than 60 miles per hour or 60 kilometers per hour.
To use tachymeter, simply start the chronograph or stopwatch when the object measured passing the starting line. When the object reaches the next mile or kilometer marker, stop the chronograph or stopwatch. The point on the tachymeter scale that adjacent to the second hand of the watch indicating the speed (in miles per hour or kilometers per hour) of object traveling between the two points.
For example, we want to measure the average speed of a vehicle is moving. Start the chronometer or stopwatch function when the car passes the starting line, and stop the timer after the vehicle traveled exactly 1 mile or 1 kilometer. Then look at where the chronometer hand (the second hand of the watch) is pointing to, and get the reading or value of the corresponding number at the tachymeter bezel or dial. Let’s say the stopwatch stop at 3 o’clock position, meaning 15 seconds had elapsed for the car to travel 1 mile or 1 kilometer. At 3 o’clock position, the tachymetre value shows that number of 240, which means the average speed of the vehicle was 240 mph or km/h.
Due to the limitation and constraint on the tachymeter scale mentioned above which makes tachymetre measurements works and valid only for certain range of speed, so in order to calculate and measure slower speeds or higher speed, user can decrease or increase the unit of measurement (e.g. change to half-miles or half-kilometers, or ten miles or ten kilometres). However, simple calculation is needed in order to get the correct average speed by using this technique. It’s also true if the length of the distance does not exceed a unit of mile or kilometer, or other unit which the speed will be based on.
For example, if we want to measure how fast the 200m athlete is running. Start the chronometer when the race starts, and stop the stopwatch when athlete crosses the finishing line. Let’s say the athlete used 20 seconds to finish 200m running, so according to tachymeter, the speed of the athlete is 180 km/h. However, the athlete only ran one fifth (1/5) of a kilometer, so we should divide 180 with 5 or 1/5 of 180, which mean the actual speed of the runner is 36 km per hour.
The above example can be used for object or thing that moving too slowly too, as when the object travels 1 mile or 1 kilometer, the duration would have exceed 60 seconds, the maximum limit of tachymeter. So the possible workaround is to measure the time taken for the object to move a shorter distance (such as 100m) and divide the tachymeter value with 10 (as 100m is 1/10 of a kilometer).
What if the object travels too fast, such as a rocket or plane. In this case, user can increase the units of the distance covered by the object to measure a longer period of time so that the duration is greater than at least 7.2 seconds (typically the lower limit). We can measure the time taken by the object to cover 10 miles, let’s say it took 30 seconds, so the tachymeter will tell us the the speed is 120 miles per hour. However, 10 miles have been traveled, so that actual speed is 120 times 10, which is 1200 mph.
I try to find other functions descriptions to send in short time. Good luck.
Posted on Aug 25, 2010
How to use Tachymeter in PL-12777JSBS model
Hi John
this model does not have a tachymeter only day date function on sub dials. there is a similar model 10962j which uses the same case this has the tacho function.
Dec 01, 2013 | Police Navy MF Mens Watch...
Tip
TACHYMETER/TACHOMETER - how to use it.
Many of watch brands has outer bezel ring calibrated as TACHYMETER/ TACHOMETER. In simple words this is SPEEDOMETER on your wrist, like in your car. The only difference is: it does not work automatic, but you have to have some maths basics in your brain to make work it.
The main thing is: As second is taken as measuring point (any wristwatch is moving sec by sec, min by min, hr by hr and so on), there is no actual possibility to measure speeds less than 60 km/h. This is because our time is divided to hours, minutes and seconds (1 hr=60 mins= 3600 secs), but ordinary watch on your wrist can't count smaller than a second, so, the starting point still is 60 for the majority.
The best watch tachymeters are producing/manufacturing BREITLING, as they have very long relationship with aviators all over the world. Braitling watches can count up to 1/10 of second.
OK, here is the link to learn basics of how to use tachymeter:
http://www.mydigitallife.info/2006/12/10/how-to-use-tachymeter-function-on-watch-bezel-usage-instruction-and-definition/
on Aug 06, 2010 | Watches
Tip
Watch glossary: T.
TACHOMETER or TACHYMETER
Function measuring the speed at which the wearer runs over a given distance. The tachometer scale is calibrated to show the speed of a moving object, such as a vehicle, over a known distance. The standard length on which the calibration is based is always shown on the dial, e.g. 1,000, 200 or 100 meters, or-in some cases-one mile. As the moving vehicle, for instance, passes the starting point of the measured course whose length corresponds to that used as the basis of calibration, the observer releases the chronograph hand and stops it as the vehicle passes the finishing point. The figure indicated by the hand on the tachometer scale represents the speed in kilometers or miles per hour.
A scale on the dial, flange, or bezel of a chronograph that, in conjunction with the second hand, gives the speed of a moving object. A tachymeter takes a value determined in less than a minute and converts it into miles per hour. For example, a wearer could measure the time it takes a car to pass between two mile markers on the highway. When the car passes the second marker, the second hand will be pointing to the car's speed in miles per hour on the tachymetric scale.
TANK WATCH
A rectangular watch designed by Louis Cartier. The bars along the sides of the watch were inspired by the tracks of tanks used in World War I.
TELEMETER
Telemeter scale allows to measure the distance of a phenomenon that is both visible and audible. The chronograph hand is released at the instant the phenomenon is seen; it is stopped when the sound is heard, and its position on the scale shows, at a glance, the distance in kilometers or miles separating the phenomenon from the observer. Calibration is based upon the speed at which sound travels through the air (approx. 340 meters or 1115 feet per second). During a thunderstorm, the time that has elapsed between the flash of lightning and the sound of the thunder is registered on the chronograph scale.
THIRD WHEEL
Wheel positioned between the minutes and seconds wheels.
TIMER
Instrument used for registering intervals of time (duration, brief times), without any indication of the time of day.
TIME ZONES
The 24 equal spherical zones unto which the surface of the Earth is conventionally divided, each limited by two meridians. The distance between two adjacent zones is 15░ or 1 hour. Each country adopts. the time of its zone, except for countries with more than one zone. The universal standard time is that of the zero zone whose axis is the Greenwich meridian.
TITANIUM
Titanium is an environmentally friendly, natural metal that is 40% stronger and 30% lighter than stainless steel. It is hypoallergenic because it is nickel-free. It is perfect for water sport enthusiasts as it is extremely resistant to salt water and other forms of corrosion and able to withstand extreme temperatures. Many titanium watches are further enhanced with a glass coating for increased scratch resistance.
TONNEAU
Particular shape of a watchcase, imitating the profile of a barrel, i.e. with straight, shorter, horizontal sides and curved, longer, vertical sides.
TOURBILLON
Device invented in 1801 by A. L. Breguet. This function equalizes position errors due to changing positions of a watch and related effects of gravity. Balance, balance spring and escapement are housed inside a carriage, also called a cage, rotating by one revolution per minute, thus compensating for all the possible errors over 360░. In a tourbillon (from the French word for whirl), the entire escapement is mounted on an epicyclic train in a "cage" and rotated completely on its axis over regular periods of time, usually once a minute. Although this device is not absolutely necessary for accuracy purposes today, it is still appreciated as a complication of high-quality watches.
TRAIN
All the wheels between barrel and escapement.
TRITIUM
Slightly radioactive material that collects light energy and is used to coat hands, numerals, and hour markers on watch dials in order to make reading the time in the dark possible. Watches bearing tritium must be marked as such, with the letter T on the dial near 6 o'clock. It is gradually being replaced by nonradioactive materials such as Superluminova and Traser due to medical misgivings and expected governmental regulation of its use.
TWO-TONE
A term use to indicate that a watch has both "silver" and "gold" tone color which may or may not be genuine gold or silver.
on Jan 11, 2010 | Watches
HOW USE TACHYMETER & WHAT TACHYME3TER MEANS
A Tachymeter helps you estimate the speed you are going.
It uses the basic formula that speed = Distance/time
Here is how to use it: (For the full article see the link below)
For example, we want to measure the average speed of a vehicle is moving. Start the chronometer or stopwatch function when the car passes the starting line, and stop the timer after the vehicle traveled exactly 1 mile or 1 kilometer. Then look at where the chronometer hand (the second hand of the watch) is pointing to, and get the reading or value of the corresponding number at the tachymeter bezel or dial. Let's say the stopwatch stop at 3 o'clock position, meaning 15 seconds had elapsed for the car to travel 1 mile or 1 kilometer. At 3 o'clock position, the tachymetre value shows that number of 240, which means the average speed of the vehicle was 240 mph or km/h.
Source(s):
http://www.mydigitallife.info/2006/12/10...
Apr 02, 2013 | DKNY NY5045 Watch for Men
How do I change the time on my fossil watch dq1185
Time Setting Instructions:First press and hold ST/STP for a few seconds and make sure it says (Time 1). This watch has a (Time 2) to use in other time zones.You change from Time 1 and Time 2 by pushing the ST/STP button for a few seconds.Time 1 setting:- Press and hold the SET button (Light Function will blink) use the ST/STP button to select on or off. Then push the Mode button to go to the next function.- The Chime function will blink. Use the ST/STP button to select on or off and then push the Mode button to go to the next function.- Next will be to select 12hour or 24hour time by using the ST/STP button then press the Mode button to set the Hour, Minutes, and Seconds.- Continue to set the year but when you get to the Month/Day you have the option of putting the day first then the month, use the ST/STP to select then push the Mode button to enter the month and day.- When satisfied with your settings push the SET button and your done.
Time 2 Setting:- Press and hold the ST/STP button it will say Time 2 and then go away only showing the time and date for Time 2- To adjust this time to another time zone you push and hold the SET button.- Use the ST/STP button and the RESET button to move ahead or behind in hours depending on time zone. Push the SET button when done.-Your time 2 is set for a different time zone and your Time 1 is set for your local time. Remember to use the ST/STP button to go back and forth from Time 1 to Time 2.
Jan 25, 2011 | Fossil Watches
How do you use the tachymeter
Follow this link and learn:
Aug 06, 2010 | Timex 22991 Wrist Watch
How do you use the tachymetre
To learn how to use the tachymetre click on link below.
good Luck and please rate 4 thumbs for the free answer
Mar 24, 2010 | Tissot T Race T90444631 Watch
I live in Eastern Time Zone. My atomic clock shows map of USA in top right hand corner and it is set in Western Time Zone. How do I reset to Eastern Time Zone? I have had atomic clock for several years. I...
The "mode" button is there to change the function of the + & - buttons.
If you press the mode button several times you will cycle through the various setting features of the clock.
Look for the one that sets the time zone and use the + or - buttons to select your zone.
Some experimentation may be required!
Feb 25, 2010 | Casio GW1500A-1AV G-Shock Atomic watch
My watch has frozen at a particular time everything still functions it switches between time zones and alarm and all the hands move around but when set it just sits at the same time all day any help?
go to the citizen watch website and look for the e870 instruction manual. Look for the "all reset" function and perform.
The watch must be fully charged, and then perform instructions. It may have been jarred or emf may have hindered its process.
Try it and see if this corrects your problem.
Jason
Oct 08, 2009 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Cannot set the date on the casio tachymeter
wen u twist th big thing do it twice and press the top button to set dates
May 05, 2009 | Watches
Watches Logo
689 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
