Question about Dryers
I have a portable stacking GE dryer Model D7003KW419. I have to replace the belt. How do I do that? Thank You-----John
  • jphennig161 Aug 25, 2010
    You sent me the wrong repair. I requested the replacement of a belt on a portable stacking GE dryer, Model # D7003KW419. Please respond -John
  • jphennig161 Aug 30, 2010
    This is a stacking dryer, not a full size.The controls are at the front bottom, above the washer. Please respond before 5 PM Monday.
    Thank You------John
  • 10,865 Answers
Hello John. You will need a phillips head screwdriver to do this job, and a new belt.
  • 1 Unplug the dryer and open the dryer door.
  • 2 Unscrew the screws under the top lip, where the dryer's door closes, with your screwdriver. Once these screws are removed, lift the top off of the dryer. On older models, the entire top will hinge upward out of the way, and on models made after 1997, half the top will pull off.
  • 3 Remove the screws on the inside-top corners of the front panel so the front panel of the dryer can be removed and set aside. On models made before 1997, the front panel should be carefully set to the right side; on newer models, the panel should be set to the left side of the machine. Be careful not to damage the door-control wires.
  • 4 Locate two screws approximately 6 inches off the floor on each side and remove them, allowing you to push the sides of the dryer slightly apart so the drum can be removed. Pull the drum slightly toward you and reach around to remove the dryer belt from the motor pulley. If the belt is broken, this step should not be necessary. Once the belt has been removed from the motor pulley, the drum should pull up slightly and out of the dryer toward you.
  • 5 Remove the old dryer belt and put the new one in place, with the ribs of the belt facing the drum. The slack part of the belt should be placed near the motor. Reverse the previous directions to replace the drum, replace the screws that hold the sides in place, replace the front and replace the top.
  • 6 Pull the dryer out from the wall and remove the four screws holding in the panel near the bottom of the back of the dryer. You will see the motor, the drum and the belt you just set in place. Loop the belt around the motor pulley and the idler pulley, and turn the drum by hand to make sure that the belt is straight and will stay in place. Screw the panel back on and push the dryer back into place against the wall.
  • Posted on Aug 25, 2010
      Brigadier General:
    • 8,619 Answers
    Hi
    Thanks for using FixYa. Please check this video on how to replace the belt which also provides you info. on the idler pulley tension. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
    screeching sound
    Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
    Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Disassembling reassembling stacked clothes dryer
    Frigidaire Stacked Laundry with Noisy Dryer
    How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
    Mar 29, 2016 | Frigidaire Washing Machines
    Why is my GE Spacemaker Dryer WSM2780 squeaking?
    It is probabaly the felt bearings at the rear of the machine
    Jan 22, 2013 | GE WSM2780W Stacked Washer / Dryer
    Replace belt on Ge stack dryer
    Over the years there are many variations of GE Dryers. Got a model number for us? We need smnething to work with..
    Apr 20, 2012 | GE Dryers
    Install dryer belt any tricks to make it simple on a GE WSM2700W/WW/AA Top Load Stacked Washer / Dryer
    Nothing on a stackable is easy to replace and no tricks so just take your time and you'll get it on.
    Sep 27, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
    I have a GE Model WSM2700 WSM2780 Spacemaker Laundry stacked washer/dryer combination which is about 8 years old. It worked perfectly until the dryer no longer would turn on. I opened up the unit and...
    i had something similar, did the cleaning and double checked to make sure all the wiring was hooked up and not frayed. i then "jiggled" (technical term) the dryer door button and some sand came out. it has been working ever since.
    Apr 14, 2011 | GE WSM2780DWW Unitized Spacemaker Washer...
    Belt replacement on a frigidare stacked dryer
    Check the below link :-
    http://repair2000.com/wpoolbelt.htm
    Paste and copy it in other browser and click enter.
    Any further help, let me know.
    Thanks for using "Fixya"
    Do rate the solution as "Fixya" if 100% satisfied.
    Jun 01, 2009 | Frigidaire Dryers
    Idler pulley arm
    there is a certain way that the belt is supposed to loop around the tensioner and motor. this picture might help.b00f604.jpg
    Jul 19, 2008 | GE DBSR453EBWW Electric Dryer
    Burning belts
    try taking a flashlight and looking very closely at the holes in the tub with a flashgoht to see if a foreign object such as a nail or screw has fallen through one of the holes in the tub and jamming it try to rotate the tub by hand and let me know
    Jan 19, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
    Dryers Logo
    242 people viewed this question
    Top Dryers Experts
